Fast left turn signal
Hi guys, I'm new to the forum, and also a new Civic owner. I have a 1998 LX version. I bought it well used and unmaintained, and I finally have almost everything into working order, except my left turn signal is blinking very fast.
Here is what I have done and checked.
• Checked all bulbs including brake lights.
• Check the grounds that I could see.
• If the headlights are on it blinks at a normal speed, but it doesn't stay on very long during the blink cycle.
• If I apply the brakes with the headlights on it blinks very slow, but still is not on long enough.
• Applying the brakes with the headlights off has no effect on the fast blinking.
• Right turn signal is normal.
• All lights blink normal with the hazards on.
I'm leaning towards it being a ground problem, but I'm not sure where to look for one that would be causing my problem.
Thanks, Cory
Thanks, Cory
Re: Fast left turn signal
Well I'm glad someone else is having this problem except me. Mine is the right turn signal though. I'm glad you mentioned speed of blinking when headlights are on... I have noticed different speeds but now that you mentioned it I realize it only blinks slow at night (headlights on) and fast in the day (headlights off).
Just letting you know you aren't alone. Sorry I can't help...
Im pretty sure when the light starts to blink fast that means your gona need a switch soon. Its the switch thats on you steering column. Good luck
318 Curves, 11 miles
I've fixed the problem 2-3 times by changing bulbs. Mine didn't appear to be burned out, but I could usually tell that one corner would be blinking darker than the rest.
Changing the bulb on that corner has always fixed the problem for me, even if they didn't look burned out. I've never had to change a switch
ron knows whta he is talking bout change the bulbs, and make sure you get the right bulb cuz if its the wrong bulb it will work but blink fast and if same problem it will be the switch
That's what I'm saying. Mine didn't look burned out, but for some reason, the bulb was effed up in a way that was making it blink fast.
The blinker relay runs off of amperage running through the bulb, so any change in the resistance of the filament will cause the blink speed to change.
I stand humbly corrected. I swapped the right and left turn signal bulbs, and now they both work correctly.
Thanks everyone for your help, the problem seemed much more difficult than a bulb.
Thanks, Cory
Thanks, Cory
Ok, I have a 03 Honda Odyssey that had a fast left turn signal indicator and the interment wiper was not working. I found the cause of the problem, on the driver side in the engine compartment, just left of the brake booster, there is a group of ground connection that are held in place by a 10 mm bolt. That bolt tends to get loose and it causes a faulty ground connection. take the bolt out, clean the eye hole and reinstall the bolt tight. Your signals, hazards, wipers, etc. will work correctly again. That is the real fix everyone has been looking for.
Rick40
03-03-2018 03:33 AM
kr0n1c
04-15-2011 03:34 PM
