Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
p1399 code
Old 05-28-2010, 02:37 PM
92civicx's Avatar
Default p1399 code
hello guys i'm tryin to figure out wuts wrong with my friends car. i already changed a ect sensor and changed spark plugs after getting a missfiring in cylinders 1,3,and 5. erased all those except for p1399 code.
the car shakes at random times and it sounds the like the manifold makes a hming noise like from a stereo which is weird and thats all i gottta go by. does anyone kno what i should look for?
tranny fluid is low
engine oil looks really dirty
one of the cables on the throttle isn't their.
and i don't think i'm leaving anything out lmk if u guys have any ideas. on where to pin point this problem thnx
Old 05-28-2010, 04:36 PM
GDD Member
slomofo's Avatar
Default Re: p1399 code
Sounds like you have a vacuum leak.
Grab a can of carburator cleaner and spray around the intake manifold area with the car running. If the idle surges, you've found your leak.
Old 05-28-2010, 05:00 PM
be professional
Targa250R's Avatar
P1399 is a temporary code for multiple misfires and is usually not listed in the manuals. What year and model is the car and have you run a compression test and checked the timing? If this is a J-series V6, have you checked the valve lash?
Old 05-30-2010, 10:17 AM
92civicx's Avatar
its a 2001 tl 3.2 l the j series v6 vtec. today i'm gonna do a valve adjustment and do a compression test, but how do i check timing, i got a timing gun but how do i do so without a dizzy ?
Old 05-30-2010, 11:12 AM
92civicx's Avatar
would the car b ticking if it needed a valve adjustment >?
Old 05-30-2010, 11:21 AM
be professional
Targa250R's Avatar
Usually, but not necessarily. A loose valve will tap, but a tight valve won't. The exhaust valves are known to tighten up while the intake valves loosen up in these engines.
By timing, I meant camshaft timing.
Old 05-30-2010, 11:37 AM
92civicx's Avatar
aright thnx man that was a big help i'll let u kno how it goes....
Old 08-09-2010, 04:50 PM
kwahamot's Avatar
I had this problem...turned out it was the intake manifold leaking, but I couldn't tell with the carb cleaner test. I had to do a smoke test.
Old 08-21-2010, 05:42 PM
CD_Ridge's Avatar
We had this code plus other misfire codes for specific cylinders. The problem was that the ignition coil pack for the #6 cylinder had failed. After the coil pack was replaced, runs as good as new.
CD
catchdz
12-02-2011 07:01 AM
Corksil
36
02-17-2011 10:29 PM
OBDII Integra
06-14-2010 12:25 AM
TheHatchHog
16
05-15-2003 11:26 AM
Quick Reply: p1399 code
