are the rear drum brakes supposed to drag slightly?
Old 05-08-2010, 10:15 AM
ra64's Avatar
Default are the rear drum brakes supposed to drag slightly?
I took the drums off to check the wear on the shoes. I put them back on and noticed they are dragging a bit. I went to adjust the parking brake and even when the bolt is all the way loose, the brakes still drag. Actually the parking brake was a little loose before. The service manual says the parking brake should be adjusted so there is no drag.
so is some drag normal? do I need to adjust something in the drum assembly to stop them from dragging?
Old 05-08-2010, 10:20 AM
ra64's Avatar
Default Re: are the rear drum brakes supposed to drag slightly?
also, one side seems to drag only during part of the rotation. does this mean the drum is warped and I need a new one?
Old 05-08-2010, 10:35 AM
knightsef-eg's Avatar
there is supposed to be a slight drag nothing serious just a slight sound... your shoe could be off kilt a little or the drum isnt on right
Old 05-08-2010, 10:40 AM
ra64's Avatar
how do I adjust the shoe and/or drum to make sure they are on right?
Old 05-08-2010, 11:04 AM
ra64's Avatar
i think i figured it out - i pushed the brake pedal while the drums were off and the thing self adjusted out. I found the adjuster bolt gear, turned it a few times, put the drum back on, and pumped the brake pedal to re self adjust. now it seems good.
Old 05-09-2010, 08:37 AM
that happens alot or sometime the drum gets a lip on the inside and it catches on that glad you figured it out
Eighty-Nyne
30
06-12-2009 10:34 PM
pimpwagon
02-11-2009 11:32 AM
Pootie
05-10-2006 05:43 AM
Power Rev Racing
01-21-2006 04:13 AM
flymecourageously
12-01-2001 11:04 AM
Quick Reply: are the rear drum brakes supposed to drag slightly?
