Interior AC/Fan Noise
Old 04-20-2010, 11:38 PM
jaebekae's Avatar
Default Interior AC/Fan Noise
When I turn on the air for either AC or Fan, it makes a loud noise near the passenger side. I think something may be clogged? It sounds like an old airplane about to take off (of course not as loud). I was wondering what place I can check to see where the air comes in from? I tried searching but didn't find anything on this.
Thanks!
Old 04-21-2010, 12:21 PM
F150guy86's Avatar
Default Re: Interior AC/Fan Noise
Mine makes the same noise sometimes. If I have my blower motor on "1" and I make a turn or hit a bump it starts "brrrrrrrrrrrrrrrrrrrrrr." I'll turn the motor up to "4" and then back to "1" and it stops. I just moved into a house with a garage so it's on my list of things to take apart and put back together. . . .
I am assuming it is the blower fan getting caught on something but I'm not sure. That's what's fun about tearing things apart though.
Old 04-21-2010, 01:00 PM
318 Curves, 11 miles
Vindicator9000's Avatar
That's what it sounds like to me.
It's not hard to pull the fan out. It's sort of a round looking thing above the passenger footwell. Take it out and see if there's anything stuck in it.
Old 04-21-2010, 05:59 PM
jaebekae's Avatar
Yea! That's the exact sound I have. Except it'll always do it on 3 and 4. Anyone figure out what's causing this?
Old 05-09-2010, 11:48 AM
jaebekae's Avatar
ttt
Old 05-09-2010, 03:27 PM
nota944mechanic's Avatar
Pull the fan and check for leaves. This is typically the culprit. If there are no obstructions, then the bearings may be on the way out.
Old 10-20-2010, 11:36 AM
F150guy86's Avatar
Well I finally had time to pull my fan out and found a few small leaves in there. I cleaned them out and put it back in and it still makes the same sound. Might be the bearings I guess. . .
Old 05-21-2017, 07:52 AM
bonbon7981's Avatar
The fan in my pilot is loud and annoying. Does not matter how high or low you set it....it still sounds like some kind of whirly sound. The higher you set the fan the louder it gets. And now it doesn't seem like the a/c is putting out cool enough air. I have a 2008 Pilot.
.hawaii
08-07-2009 11:15 PM
Brian Hinson
01-19-2005 11:40 AM
pandacivic
06-07-2004 07:42 PM
ninja8oi
03-28-2004 04:39 PM
Quick Reply: Interior AC/Fan Noise
