Magnetic transmission oil drain plugs are worth using.
Magnetic transmission oil drain plugs are worth using?
I have only been using this plug for 6 months. I can only imagine how bad it is having that much steel fillings floating around in there. It has got to reek havok on the bearings.
Anyone else ever get that much?
____________________________
10/27/11 UPDATE ON PAGE 2
H-T White Ops
Re: Magnetic transmission oil drain plugs are worth using.
It's even more fun when you tear apart your old transmission and find the fuzzy stock magnet along with ball bearings everywhere.
Bye bye ISB.
Bye bye ISB.
Go Tigers!
you can get blox ones for like 20 bucks for both.
and even though there is the stock mag in this case why wouldn't two be better then one?
Go Tigers!
If I were to pour the noodles into an additional second strainer, would it do me any good?
only if the first one got clogged by noodle.
eh i already have it so too late now.
lol funny story though.
(in googling around i found my way to this thread on the second page of google results)
Your illustration is not good.
I should check the parts store though, thanks! M14 bolt with 1.5 pitch
Go Tigers!
My point being, there are certain cases where more isn't better, or beneficial.
The fluid flow within the transmission isn't turbulent enough to pull the fragments off the magnets. I have cleaned several magnets, and couldn't BELIEVE how much stuck to the magnet.
The drain plug magnet wouldn't hurt, I just stopped running mine.
i suppose at some point one crosses the line between over obsessing about keeping the car clean and minty fresh and just enjoying the damn car. after all, eventually it will get sold or crashed or wear out... right? (type r's excluded since they're garage queens for life! lolz)
Thanks for the comments/thoughts people.
Go Tigers!
For those that are interested, here's some pics of the stock magnet
removed
lipgloss ready
As you can see, the stock magnet does an awesome job grabbing the particles. Oddly enough, you can see in the 'squares' in the second pic, there's only magnet. in the older trans honda placed a magnet in each of these 'squares' But in the newer ones, they just have one magnet (like in the pic) Honda must have found that one magnet was sufficient enough.
removed
lipgloss ready
