any one know how to wire a toggle switch to a radiator fan?
Old 04-21-2010, 05:51 PM
  #26
eg:R's Avatar
Default Re: any one know how to wire a toggle switch to a radiator fan?
which diagram can i use if i want to put on a switch and plus it still run on the automatic mode?
Old 04-21-2010, 06:24 PM
  #27
madblkscientist's Avatar
Originally Posted by madblkscientist
this is the way i would do it
Attachment 123063
this one but instead of the ign key use a toggle
Old 04-21-2010, 06:31 PM
  #28
read post 11 on 1st page and if u dont want to use the ign as a swicth then use a toggle swicth instead then find the thermostat housing it sound have a sensor and a thermostatic swicth u can use or purchase one from the parts store and install it
Old 04-22-2010, 04:40 PM
  #29
Blue00Si's Avatar
i didnt read the whole page so sorry if this has been repeated. i just unplugged the plug thats on the thermostat housing and cut a 1inch piece of wire and jumped the plug. now the fan is on constantly when the key is turned onto the ON position.
Old 04-22-2010, 06:28 PM
  #30
explain jump the plug
Old 04-22-2010, 06:33 PM
  #31
Organization's Avatar
seems this is turning into a big deal
Old 04-22-2010, 06:51 PM
  #32
i understand where u are getting at, his wire harness to the fans are missing
Old 03-03-2013, 11:45 AM
  #33
Juan Lemus's Avatar
Hey, so does anyone know how to connect an electric fan to the oem radiator wiring? I just bought an electric fan but I just want it to plug into the stock fan plug..
Old 03-03-2013, 12:25 PM
  #34
fcm
Old Fart
fcm's Avatar
Cut the plug off your stock fan, connect it to your new fan, [make sure fan runs in the correct direction].
Here is how I did it, about 1/2 way down...
https://honda-tech.com/forums/showth...zu+rad+install 94
Old 06-24-2015, 01:19 PM
  #35
thehustler's Avatar
Default Ok a little illiterate on things like this, well alot but
First yes this is an old thread but has helped me tremendously or will have one question though.
What size of relay is that, 30 amp? asking cause someone said I needed a 70 amp relay for a 1999 Acura cl 3.0 and I would think one fan on the radiator might use 8 amps at most and maybe 20 to 25 on a draw starting. Thanks, just want to get the right relay to work with your diagram.
Old 06-26-2015, 05:30 AM
  #36
thehustler's Avatar
Okay i did the hookup as in post 11's diagram but when I connect to the battery the fan comes on without the key turned. I double checked all wiring and everything is where it should be.
Eg.ls.turbo
12
11-27-2013 10:34 AM
High-DC2
01-30-2010 11:15 AM
BanEL
05-09-2007 04:46 AM
4DRmafia
09-06-2004 05:19 PM
NuclearB18B
10-28-2003 09:22 AM
Quick Reply: any one know how to wire a toggle switch to a radiator fan?
