AC question
Old 04-12-2010, 12:38 PM
GAngulo7's Avatar
Default AC question
Hey guys, I have an 02 civic lx, my AC used to run great and blow cold but lately it will blow air but it won't be cold anymore... I thought, either frion or something is up with my compressor. Then I realized the heater works perfectly, does this rule out the suspicions of a ruined compressor? I'm hoping its just frion... how can I know?
Old 04-12-2010, 01:12 PM
97twodoor's Avatar
Default Re: AC question
To check refrigerant charge pressure you need to hook it up to a set of AC gauges. They should be around 70 psi, with the car not running, and at around 70 degrees F.
Old 04-12-2010, 01:34 PM
Plead da Fif
It Wasn't Me's Avatar
Since it isn't an intermittent problem, I'm willing to be that it probably just needs to be recharged.
Does the compressor still activate?
Old 04-12-2010, 03:31 PM
GAngulo7's Avatar
you know, when i posted this i thought to myself, i bet It Wasn't Me is going to give me a good answer about this... you are like the king of this forum dude! lol
but anyways, how do i find out if the compressor activates?
Old 04-13-2010, 02:27 AM
Plead da Fif
You can see and hear it activate.
What are the radiator and condenser fans doing? (condenser fan is next to the radiator fan) Do they both run when you turn on the A/C, or are all three components failing to work?
Old 04-13-2010, 08:50 AM
GAngulo7's Avatar
Everything is running fine, I can hear it activate and both fans are going
Old 04-13-2010, 01:05 PM
GAngulo7's Avatar
I just checked the frion, and the gauge read that the pressure was fine, it didnt need anymore frion... but its still not coming out cold. soooo, i have no idea what it may be...
Old 04-13-2010, 02:17 PM
GDD Member
slomofo's Avatar
It could be a number of different things. It could be low on freon and you're checking the gauges wrong or low on freon and your gauge is reading all the air in the system. It could be the orifice tube, it could be a dirty condensor, it could be many things. To be quite honest, I wouldn't even mess with it if I didn't know anything about A/C, I would just fork out the $55 to have a shop check/charge the system.
Mike Rongo
06-22-2019 02:19 PM
TurboEM1
Acura TSX
08-18-2018 02:56 PM
Panoply
08-13-2010 04:51 PM
808jdm_profileEG6
09-25-2007 02:14 PM
Arsenal
08-22-2006 11:32 AM
Quick Reply: AC question
