how do i tell if my ecu is bad?
Old 02-25-2010, 04:11 PM
fenix4o9's Avatar
Default how do i tell if my ecu is bad?
hey guys i think my ecu might be shot when im on the free way going about 60 mph rpm at 3 i start getting alot of miss fires. only when i smash on the gas does it over come the bogging down feeling then after that if i hold the gas steady it will bogg down again i have to keep smashing on the gas... im not getting any check engine light
im guessing its my ecu but i wanna be for sure before i drop that kind of cash on a new one. and no i dont realy have anyone i know with a p72 ecu so just swaping in another one is not realy an option
please help guys
Old 02-25-2010, 04:21 PM
romierome's Avatar
Default Re: how do i tell if my ecu is bad?
it might be your distributor thats close to going out already.
had the same problem on my crx and didnt fix it so my distributor went COMPLETELY out and now my car wont start at all
Old 02-25-2010, 04:35 PM
fenix4o9's Avatar
how do i test/tell if its my distributor?
Old 02-25-2010, 04:37 PM
EFB055
~sp33~'s Avatar
You'd be having more severe problems if your ECU was fried.
If your spark plugs aren't foul, i'd try a spare distributor to see if it clears the issue.
Old 02-25-2010, 04:51 PM
fenix4o9's Avatar
hmm.. i dont have a spare distributor there has got to be a way to test it
Old 02-25-2010, 04:55 PM
fenix4o9's Avatar
besides the cap or rotor what else can go bad its mostly mech. isnt it? what would cause it to go bad
Old 02-25-2010, 04:58 PM
chivid's Avatar
if the car doesn't go over 3000 rpm its usually the distributor going out.the crank position causes this affect and most of the time it won't throw a code. you can take the distrbutor to your local shop who knows how to test your distributor.
Old 02-25-2010, 05:08 PM
miguey310's Avatar
check the coil they get messed up fast
Old 02-25-2010, 05:10 PM
fenix4o9's Avatar
it does go over 3000 rpm thats just the rpm when it starts to mess up at
Old 02-25-2010, 05:35 PM
chivid's Avatar
oh , thats really is weird.. well i still get the distributor checked out. theres no guessing in diagnosting a problem . gotta test out the possible problems.
Old 02-25-2010, 06:28 PM
fenix4o9's Avatar
could it be cam position sensor ?
Old 02-25-2010, 09:48 PM
miguey310's Avatar
coil
Old 08-25-2010, 02:37 PM
SouthMSDelSol's Avatar
if your having problems with it hitting a rev limiter type effect it could be the ect sensor(engine coolant temp) my delsol was doin it and that helped but the ecu on mine just went so hope this helped some
Old 08-25-2010, 03:03 PM
hondawhiz's Avatar
the cam position sensor is inside the distributor. honestly get another dizzy at the junk yard and try it out.
Old 08-25-2010, 06:48 PM
ef_cowboy's Avatar
i had that same problem when i put my car together.i took of the cap and off and the contact points had **** all over them.so i took a file and cleaned it up,ran like a champ...them i just got a new one cuz there so cheap
Old 08-26-2010, 07:37 AM
CRXguy_88's Avatar
IT IS YOUR DIZZY.. you had an internal sensor go out most likely. I would say its the crank position sensor it envolves the first cylinder and messes with the first fuel injector and everything is thrown off.. causing it to bog. I would just get a new dizzy. I had the same thing when I put an a6 in my crx. It bogged real bad and I had a used dizzy from ebay on it ($45) and I went and bought a brand new (130) one from advance auto parts and viola problem solved! good luck! :thumbsup:
Old 08-26-2010, 07:52 AM
Cameron R's Avatar
Get a copy of the FSM and check the resistance for the three sensors in the dizzy, all you need is an ohmeter. If problems occur when the engine is hot, then test the dizzy under those same circumstances.
The last owner of my car through parts at the same sort of problem (ECU, wire, plugs) turned out to be bad cap/rotor, and dizzy in my case.
gomer124
07-01-2015 08:36 AM
dtran
Engine Management and Tuning
11-04-2010 01:04 PM
415Hatch
08-29-2010 08:30 AM
fenix4o9
07-07-2007 11:35 PM
Quick Reply: how do i tell if my ecu is bad?
