Head Gasket. Is OEM Best? AND: Torque Specs? (ARP)
Old 01-14-2010, 08:22 PM
88CRXJ's Avatar
Default Head Gasket. Is OEM Best? AND: Torque Specs? (ARP)
its going on a GS-R block and will be squished down with ARP head studs through a B16 head.
so OEM or aftermarket or whadda?
and, does anybody have the torque sequence i should use with ARP head studs? do you do them all at 25, then go back and do them all at 45, then go back and do them all at 80? (that is just an example, not actual numbers)
was told ARP head studs should be tourqued to 80ft-lbs. correct/incorrect?
Old 01-14-2010, 08:26 PM
p28yaj's Avatar
Default Re: Head Gasket. Is OEM Best? AND: Torque Specs? (ARP)
Search ^^ or can be googled!
Old 01-14-2010, 08:54 PM
88CRXJ's Avatar
ACTUALLY. when you search "best head gasket" it comes up with a billion finds... that i really dont feel like searching through for a simple answer. its because everybody puts what kind of bad *** head gasket they have when they describe their vehicle. i too one day would like to be able to do this, as soon as i find out with head gasket is the most bad ***. haha. any opinions?
Old 01-14-2010, 08:57 PM
KPPPowa's Avatar
Typical HT response.
your welcome.
https://honda-tech.com/forums/forced-induction-16/arp-torque-spec-pattern-2279128/
Old 01-14-2010, 09:10 PM
88CRXJ's Avatar
Originally Posted by KPPPowa
seriously. i hate it when people see the oppurtunity for a "use the search button" and abuse it to sound cool. i know SOMEBODY out there knows where the thread is. thanks for helping.
can you suggest a headgasket? been told OEM is best...
thanks again!
Old 01-14-2010, 10:41 PM
mouab18c1's Avatar
OEM is best for a stock or semi builds. If you're ordering a new set of ARP headstuds, it should come with torque specs.
Old 01-14-2010, 10:42 PM
Spawne32's Avatar
fel pro gaskets are perfectly fine, call ARP for the proper torque sequence and specs though, not the same as factory at all
Old 01-14-2010, 10:57 PM
mouab18c1's Avatar
i torque mine in OEM sequence and using the lube ARP provides i torque them to 68lbs and have never had any come loose. I've double checked after a few months of driving and beating on it and they're still tight like they should be.
Old 01-14-2010, 11:00 PM
SoTexDC2's Avatar
When it comes to torquing any mating surface separated by a gasket, I like to take as many steps as possible. Use the Helms manual for the proper sequence. Better safe than sorry.
Old 01-14-2010, 11:17 PM
88CRXJ's Avatar
ARP studs are already in there but i dont remember or have the papers.
Helms manual. ill hjave to look that up. thanks.
no turbo is going on this. just all motor poormans type r. may end up getting cams idk. so OEM is sounding fine.
Old 01-15-2010, 09:26 AM
mouab18c1's Avatar
yes OEM will be fine for your poorman's type r build
DrkHrse
54
02-10-2013 03:55 AM
lsvtec_cp
07-01-2009 06:22 AM
rick_rabies
04-15-2009 12:49 PM
b17 rolla
01-12-2009 09:01 PM
DaYZeD.1
03-28-2008 09:19 AM
Quick Reply: Head Gasket. Is OEM Best? AND: Torque Specs? (ARP)
