| Welcome to Honda-Tech! | ||
#1 |
ugh,
i noticed that my heat gage didn't move from cold after driving for about 30 mins. opened the hood and saw that neither of the cooling fans were running. replaced the cooling fan relay and still nothing. noticed that the fans only turn on while a/c is running. weird. any suggestions? thanks. 1991 honda accord lx |
#2 |
The fans only come when they need to to save on electrical power. There is one (or more) heat sensitive switches that will turn the fan one when the coolant temperature gets to a certain level. For the most part when driving, the car moving the air is sufficient. When the AC is used, it overrides the temperature switches and turns the fans on to assure there is sufficient flow through both the radiator and the AC condenser. If your heat gage doesn't move off cold, sounds like your thermostat it stuck open or the sender circuit for temperature indication is bad.
90 LX 4dr 5 spd 304,000 . . . . . . . . . . . . . . . . . 93 LX 4dr 5 spd 113,000 93 EX 2dr auto 156,000 . . . . . . . . . . . . . . . . . 93 LX Wagon auto 160,000 99 Ford E350 164,000 . . . . . . . . . . . . . . . . . . 05 Town Car 58,000 |
#3 |
| Tags |
| 1991, 2002, 90, ac, accord, cooler, cooling, fan, honda, lines, lx, radiator, trans, turn, working |
