92-93/94-95 glove box
Old 12-25-2009, 11:15 AM
93preludeh22's Avatar
Default 92-93/94-95 glove box
I just swapped my 92 dash out of my civic into my 95 civic. It appears the glove box is different between the years?? I assume this is because of the pass airbag. (Yes, the plastic inside the dash did break on install, this should've been my first clue..)
Will a 94/95 glove box fit my 92 dashboard? I'd prefer not removing my dash again.
Anthony
Old 12-25-2009, 12:16 PM
kdog1818's Avatar
Default Re: 92-93/94-95 glove box
I had the same situation all i did was zip tie the bottom of the glove box and it worked fine.
Old 12-25-2009, 02:54 PM
Do you mean ziptie the 94/95 glove box?? The 92/93 physically will not fit.
Old 12-25-2009, 04:20 PM
Gunmetal_B20_Hatch's Avatar
Why not just get the correct year glove box to match the rest of the dash???
Old 12-25-2009, 04:24 PM
Did you even read my post? The glove box doesn't fit because of the brackets behind the dash from the passenger side airbag.
Anthony
Old 12-25-2009, 04:29 PM
remove all the airbag **** then.... You cant have a pass side airbag with a 92-93 dash anyways.
Old 12-25-2009, 05:14 PM
There's a metal frame behind the dash that is blocking the glove box... There is
no airbag
Old 12-28-2009, 03:15 AM
Anyone know?
Old 12-28-2009, 06:32 AM
Oh look, I can change this
deschlong's Avatar
Anthony
In a word: No. Here is a diagram (courtesy e-hatch.com):
He probably means the 94/95 box. Does it fit in the 92 dash? Will it close properly if you can rig it up with a zip tie?
Can't do this - the 92 won't fit.
no airbag
What about removing the metal frame? This is the "airbag ****" he's referring to.... check a parts diagram and note the p/s dash parts that are different. Remove the ones related to the airbag and your 92 box will fit again.
Old 12-28-2009, 08:29 AM
Argh, F YOU HONDA. I guess that's what I'll do... but not now. I'll pull the dash out some other time for that.. Or, I can just take a grinder to it or something.
Old 08-16-2010, 07:59 PM
mattyfo0z's Avatar
I'm sure those latches the glovebox uses are similar to like, the door latches you could buy at Home Depot right? Probably 1" or something. I bought my car without a glovebox, and bought one from the junkyard a while back but still haven't installed it. But now that I know for sure it's gonna fit, I wanna get it installed ASAP.
rayrayx11
10-14-2013 05:18 AM
90civichb
02-19-2005 09:22 PM
92SiB18C1
11-15-2002 09:27 AM
Quick Reply: 92-93/94-95 glove box
