Desmond MP / Enkei RPF1 valve stems
Trying to find a set of valve stems and seals for my Desmond Regamaster MP's. They are the same as what comes on Enkei RPF1's, i.e. the rim has a very small hole so normal stems do not work. Any tire store I've tried has never seen this style of stem and vendors that sell RPF1's want $25 per stem!
Figured there's gotta be a cheaper alternative. Any help is appreciated!
Re: Desmond MP / Enkei RPF1 valve stems
which size motocycle valve stems did you order? the 1.2 or the 1.58. and would rubber valves work with rega mp instead of the metal ones?
and those 2 sizes you mention only refer to the length of the stem. measure your existing ones. im pretty sure the majority of the time its only due to preference(look). sometime you need a longer stem to clear a multipiece wheel center.
know anywhere else to order? i cant seem to order from prestige wheel because order is too small.
would enkei valve stems work or will i need the motocycle valves for my regamster MPs
Don't judge or question
http://www.prestigewheel.com/cgi-bin...ion&key=2920XS
Edit:
These are actually closer to the right length but since there isn't a image of them I'm not sure if all the other dimensions are the same. If they are they will work.
http://www.prestigewheel.com/cgi-bin...on&key=2920XXS
