Old 11-19-2009, 06:46 PM   #1
fcjohnny
Default Clutch pedal goes to floor
I was driving to bring my friend home and my Clutch pedal loses a lot of pressure. I have to press the clutch all the way to the floor for I to engage. What the hell cause this? Drive a 94 rs
fcjohnny is offline   Reply With Quote
Old 11-19-2009, 07:00 PM   #2
gabe768
gabe768's Avatar
Default Re: Clutch pedal goes to floor
check to see if your topped off with brake fluid, that happened to me and that was the problem
gabe768 is offline   Reply With Quote
Old 11-19-2009, 07:11 PM   #3
seanbev24
seanbev24's Avatar
I'd start by inspecting for leaks and bleeding the system with new fluid since it'll only put you out a few bucks.
If that doesn't work, it could be a bad master cylinder, slave cylinder, maybe pressure plate?
seanbev24 is offline   Reply With Quote
Old 11-19-2009, 07:33 PM   #4
ILS_09
ILS_09's Avatar
Check for any leaks from your slave cylinder and clutch master cylinder. Typically, the clutch/brake fluid for the clutch reservoir wouldn't go down unless there is a leak somewhere. Make sure your clutch reservoir (or whatever it's called) is full.
ILS_09 is offline   Reply With Quote
1994, 92, 98, acura, civic, clutch, floor, honda, integra, loses, pedal, prelude, press, pressure, work
