radio code not working
Old 11-02-2009, 06:45 PM
xcb7x's Avatar
Default radio code not working
my car got stolen recently
and i wanted to put my stock radio back on
soo it said code with red light blinking...
i called honda and they gave me a code...
but it dont work at all....it just keeps saying code...
i tried disconnecting the battery negative for like 15 mins and tried it again
but nothing yet
idk whats up
any help here
Old 11-02-2009, 07:10 PM
xcb7x's Avatar
Default Re: radio code not working
any help here?
i think i should just hit up cb7tuner
Old 11-02-2009, 07:15 PM
redbull-1's Avatar
Assuming the 5 digit code is correct, these are the instructions from the owner's manual:
Old 11-02-2009, 07:19 PM
xcb7x's Avatar
well do i leave the key on one click for the radio to atleast be on???
and leave the radeio on with the code light on for a hr?
Old 11-02-2009, 07:22 PM
redbull-1's Avatar
You turn the ignition to accessory 'on' so the radio is on, then enter the code. Once the code works, you can turn it off. Even if the radio didn't accept the code after 3 tries, you do not have to leave it on.
Old 11-02-2009, 07:26 PM
xcb7x's Avatar
the thing is that i clicked my key once for the raido to be on...i tried it already and it doesnt work at all..
i did the battery thing and nothing...
i called honda 2 times and they said thats the code for that radio....
soo i am saying should i leave the key on witht eh radio on for a hour?>
Old 11-02-2009, 07:30 PM
redbull-1's Avatar
No, you do not need to leave the key on with the radio for an hour. You only turn the ignition to accessory 'on' and the turn the radio on when you are entering the code.
Old 11-02-2009, 07:33 PM
redbull-1's Avatar
Also, sometimes grime builds up around the buttons and they do press in that well. You might want to use a slightly moistened q-tip with rubbing alcohol to clean around the buttons first.
Press each button firmly; but not too fast or slow while entering the code.
Old 11-02-2009, 07:34 PM
xcb7x's Avatar
wellwhy does that thing say leave the key on to accesory for a hr to restart it?
Old 11-02-2009, 07:36 PM
redbull-1's Avatar
Well, I guess the owner's manual for the CB7 does say to leave the radio on for an hour. When I had a 5th gen Accord, I never had to leave it on for an hour if it didn't accept it.
Old 11-02-2009, 07:41 PM
xcb7x's Avatar
well idk...the dum code dont even work at all...
idk what to do!
Old 11-02-2009, 07:49 PM
redbull-1's Avatar
Wait a bit, and come back tomorrow when you're rested up and try again.
Press the buttons firmly; but, not to fast or slow.
Old 11-02-2009, 07:57 PM
xcb7x's Avatar
hahhaha i am koo dude itsjust taht dam code haha
but yea i press them u know calm not with anger.
i been having the battery off for a good30 mins already if that dont work imma just leave ignition on for a hr
Old 11-02-2009, 08:27 PM
fleetw00d's Avatar
You do need to leave the key in the accessory position with the radio ON (showing the word "CODE") for an hour before you attempt to enter the code again. I had the same problem (I was dyslexic when entering the code).
Old 11-02-2009, 08:35 PM
xcb7x's Avatar
dang
i gotta wait that long..???
can i be driving around also?
Old 11-02-2009, 08:52 PM
fleetw00d's Avatar
Yes, you have to wait that long. Driving around is OK, as long as the radio is on for an HOUR. Don't shut the power off before you enter the numbers.
Old 11-02-2009, 08:53 PM
xcb7x's Avatar
say i drive...and i get home i just leave it on assesory?
Old 11-02-2009, 09:21 PM
stereo69's Avatar
or just disconnect the negitive battery cable for 30 seconds and it will accept 3 more codes.
Old 11-03-2009, 05:23 PM
fleetw00d's Avatar
I'll apologize ahead of time - what part of "you have to leave it on for an hour" don't you understand? Driving, not driving, driving then leaving it in the accessory position, it doesn't matter. As long as the radio is powered for at least an hour continuously, it will then let you enter the code. Stop trying to second guess it - just do it.
Old 07-31-2011, 05:40 PM
Accord94 man-dr's Avatar
All the forums I have read are complaints about lack of codes I have this same problem and couldnt find the manual anywhere thank u for posting it on you have answered all my questions hopefully it works if not I'm buying A new radio lmfao not dealing w this evertime my battery is removed
mrsnj20
09-05-2007 03:35 PM
manyakiexpi
Honda Civic (2006 - 2015)
28
03-05-2007 11:24 AM
crx_ef8
Acura TL, RL & ZDX
10-03-2003 09:03 AM
jaczs
01-07-2003 10:21 PM
Quick Reply: radio code not working
