November FS Sticky
Old 11-18-2009, 04:50 AM
  #76
jasonp's Avatar
Default Re: November FS Sticky
B-16 Head By Endyn Complete Springs Valves and Retainers $1000.00
Full Race Twin Manifold $1000.00
Precision Water To Air Intercooler $600.00
Tial BOV $150.00
jasonp is offline
Old 11-18-2009, 05:33 AM
  #77
RPRacing's Avatar
I'm selling my helmet since I no longer race. I have had this thing about 2 years. I bought it brand new for $400 back then.
It is a large.It comes with a black bag, smoked visor and clear visor.
It has black decals, but they can easily be removed.
http://www.bimmerworld.com/html/bell...met-sa2005.htm has all of the information on it.
I want $200 for it.
-Francisco
757-575-2416
RPRacing is offline
Old 11-18-2009, 10:49 AM
  #78
YZFR6's Avatar
Spearco 1000 HP water to air intercooler with -12an bugs and 2 gallon tank. 4 gallons thru-out complease system. Asking $ 750.00 OBO.
YZFR6 is offline
Old 11-18-2009, 02:41 PM
  #79
jdm knight's Avatar
inlinepro t4 turbo manifold.
I made 770hp with this manifold using a s372r turbo at 37lbs.
I'm asking $350 for the manifold
jdm knight is offline
Old 11-18-2009, 07:27 PM
  #80
Poootie's Avatar
Well new year= new project!!
Up for sale is my BABY!!!!
Asking $9000
11.0@126mph on 15-16psi (boost by gear)
10.6@137mph on 22psi (everygear)
My Build Thread... Feel free to PM with ANY questions.
http://forums.vwvortex.com/zerothread?id=3927753
Poootie is offline
Old 11-19-2009, 08:07 AM
  #81
miller's Avatar
bullseye comp R 72mm turbo, brand new.
$1650 shipped.
miller is offline
Old 11-20-2009, 07:53 AM
  #82
Swipe'd's Avatar
looking to sell the whole setup!
ok so im selling every baller piece i got... motor, tranny, axles, turbo kit...
pm for details, prices are priced high for negotionation purposes...
D16Y8 Fresh Motor machined sunnen honed, lightly decked, fresh OEM Honda headgasket, fresh Y8 crank, TOGA High Volume Oil Pump, Honda Water Pump
Wiseco Pistons, Crower Rods, ACL Race Bearings, Crower Springs & Retainers, Crower Stage 3 Cam, AEM Cam Gear, Mugen Valve Cover powder coated gold with 2 -10AN fittings, steel oil pan with -10AN retun bung
D16A6 CRX Si tranny w/shimmed OBX LSD
fresh synchros, bearings, seals machine sliders
Turbo Kit $2000
Custom Ramhorn Manifold
PT67 Stage 5 Wheel turbo
Tial 38mm Wastegate
V-Band 3'' downpipe
Drive Shaft Shop Axles 3.9 600hp+ w/upgraded hubs $500
[IMG]http://i146.photobucket.com/albums/r270/MAXRAY2628/0b1a926d]
Skunk2 Pro-Series (removed badge, port matched)
$600 with the thermal barrier gaskets and 68mm tb!
GM 3BAR Map Sensor $50
SX Fuel Pressure Regulator & Fuel Filter with lines and fittings $200
D16 Distributor MSD Cap, Rotor, Coil, Wires $300
Innovative D16 Mounts w/ Race inserts $200
custom backdoor intercooler & Tial BOV 50mm $400
TurboSmart Boost Controller (this one is far superior due to the control on it. You can guage how much by how many clicks it makes) $75
Swipe'd is offline
Old 11-20-2009, 11:16 PM
  #83
88ED8's Avatar
AEM Fuel Pressure Regulator for sale!!! $85 shipped
!!!Gauge not included!!!
88ED8 is offline
Old 11-21-2009, 04:08 AM
  #84
velocitytrends's Avatar
Few parts we have laying around the shop for sale; Condition is new and used:
Prices do not include paypal or shipping.
Aeromotive 1000 Fuel Pump (Used) - $250
Log Style Turbo Manifold B-Sereis (New) - $280
K20 RSX/S2000 Coils (used) - $20 a piece
Fuel Pressure Regulator (Used) - $80
GSR Eagle Rods (New) - $300
ITS 61mm Turbo T3 Flange (New) (heat coated both sides)- $800
02-03 RSX Lowering Springs (New) -$100
S2000 Trans - bad (Used) - $100
2003 Si Gauge Cluster - (Used) - $80
Supra Turbo Maf (Used) - $150
D-series Trans 5 speed - Good (Used) - $100
GSR Venom Intake Manifold (New) - $250
Pictures:
velocitytrends is offline
Old 11-22-2009, 11:16 AM
  #85
Coffey's Avatar
I have a Borg Warner S372 for sale 1.25 turbine housing and Race Cover. I used it on the dyno it is practically brand new. Comes with a T1 Turbo blanket. It is way too big for what im trying to do. $1100 shipped takes it.
Coffey is offline
Old 11-23-2009, 04:24 PM
  #86
DJsilkyjr's Avatar
have a set of precision 1200 cc injectors, used for about 1 mile total in my dsm considered brand new, paid $340 new, will take $280 shipped.
DJsilkyjr is offline
Old 11-23-2009, 04:54 PM
  #87
85mmek9's Avatar
Up for sale is a very nice Pro Drive spool for GSR. Comes with good honda bearings.
$250 OBO
85mmek9 is offline
Old 11-24-2009, 06:15 PM
  #88
boosted hybrid's Avatar
We recently moved to our new shop and uncovered alot of parts from our old location. Here is the list of parts so far:
AEM replacement wideband sensors, part number: 30-2001. Brand new, 3 available. These are the replacement wideband sensors for any/all AEM products that use a wideband sensor including the "U" versions of the AEM EMS. 60.00 each.
AEM 3.5 bar map sensor, part number: 30-2130-50. Brand new, never used. 110.00.
ACL Race bearing sets. Main/Rod/Thrust bearing complete sets. 3 sets available for GSR, 3 sets available for B16a/LS. Brand new in the packaging. Standard size, not oversized. 115.00.
Billet aluminum catch can. Brand new, never used. Comes with mounting bracket and filter. Great for all motor, supercharged or turbo applications. 50.00.
Brand new 1 quart catch can with drain. Has single -12 a.n inlet fitting. Great for high boost/high power turbo engines. 50.00.
T3/T4 Turbine blanket. Brand new, never used. Makes a HUGE difference in under hood temps, as well as faster spool. 125.00
AEM EMS 30-1052. Brand new in the box AEM EMS for 00-05' s2000s. 950.00.
AEM/Bosch style injector clips. Works with any obd-1 style injector both stock and aftermarket. 15.00.
AEM 0-2000 psi pressure transducer. Brand new, 2 available. Great for use with AEM EMS or Hondata for full throttle shifting. 110.00
Aeromotive compact EFI fuel pressure regulator. Brand new, never used. Has -6 inlet/outlet. Adjustable from 30-70 psi base fuel pressure. 150.00
GM 3 bar map sensor and pigtail harness. Brand new, 3 available. 50.00.
Garrett GT3582r: Brand new never used. The turbo comes with the special order anti-surge compressor cover and twin scroll T4 1.06 a/r turbine housing. The center section and turbine housing are high temp ceramic coated. The twin scroll housing allows this turbo to spool faster than a gt3076r, yet make an additional 100-150whp. This is the best street turbo hands down. 1100.00
Iceman Civic Eg (92-95') headlight scoop kit. In like new condition, and not produced anymore this Iceman headlight scoop makes the best power hands down for b/d/h series engines on the street and at the track. I have personally seen 20 whp gains on the dyno, and 3-4 mph gains at the track with it. 275.00.
Not interested in trades of any kind. Pics available for any of the parts, just shoot an email to jeff@evans-tuning.com.
boosted hybrid is offline
Old 11-24-2009, 08:12 PM
  #89
Civic89stdB16's Avatar
FS Richmond Spool for B16/LS Trans. Used and needs new diff bearings. Price is $300 shipped or Best offer. But willing to trade for OBX LSD for B16/LS Trans. Pm Me. Thanks
Civic89stdB16 is offline
Old 11-25-2009, 04:18 AM
  #90
FRernesto's Avatar
I have a set of brand new Skunk 2 pro 1 cams for sale. I'm trying to sell them for a buddy who had purchased them and now wants a milder cam like the Skunk 2 tuner series. The cams were taken out the box and put on the motor but NEVER turned. Would also be interested in a trade also for the tuner's. Sale price 500.00
FRernesto is offline
Old 11-25-2009, 05:58 AM
  #91
tuan_turbo_dc4's Avatar
FS: Full Race Top Mount B-series Turbo Manifold T3 Flange w/ Polydyn Coating : $800.00 (Downpipe is not included)
Only picture I have of it for now.
Omni Power Street Coilovers 92-95 Civic and 94-01 Integra
Front 10k and Rears 8k: $450.00
tuan_turbo_dc4 is offline
Old 11-25-2009, 10:09 AM
  #92
jdmsponsor's Avatar
I got a 94 eg bubble si shell for sale. The car has been sitting for a while but is still mint. Just needs a quick prep. Car is milano red and no body damage besides a slight crack on the front bumper. A while back was a 9 second turbo car from the previous owner.
Here is a list of the mods,
6 point roll bar
4 point racing harness( good till 2012)
avid b series motor mounts
sumped fuel tank
duck bill
three piece wing
polished rear diffuser
full lip kit
braided brake lines
amber corners
black housing headlights
hids
50/50 tails
peak and hold injector driver box
dual stage boost controller
gauge pod on pillar and in the center console.
car needs a hood, seats, fuel system, and swap.
perfect for a turbo setup or good all motor build.
asking 2000 obo
hit me up (908)494-6005
pics up in a few
jdmsponsor is offline
Old 11-25-2009, 02:43 PM
  #93
JDM JEFFREY's Avatar
gold vpd lenso's full set
13inch front ans 15inch rear
no tires pm me 600.oo shipped
JDM JEFFREY is offline
Old 11-26-2009, 05:35 AM
  #94
Autoworks's Avatar
F.S
Freshly Rebuilt by Bullseye, T4 S372R $1250
Precision Air to water 1000HP intercooler $500 oboMeziere Water Pump $150
GO-AUTOWORKS Catchcan:2 filters, 4 -10 fittings $130
GO-AUTOWORKS Custom Ice box. $350 obo
This box will fit behind the stock 96-00 Civic bumper. It clears the 24.5 tire w/ plenty of room to spare, a 26" should b eno issue wither. The inlet also clears the stock headlight.
I'd Love to sell the Box, Intercooler and Pump together,( $900 all together) but wil seperate if needed. All parts have maybe 1/2 mile street time and 10 dyno passes. The turbo has not been used since the rebuild a few months ago, it is fresh, in the bag and ready to go.
Intercooler will come w/ the fittings and hoses.
Water pump will come w/ bracket
Ice box brackets are welded to the box to bolt up to the frame.
Autoworks is offline
Old 11-26-2009, 07:45 AM
  #95
rmercado's Avatar
i am selling few parts from my car/pictures included i have more pictures from all the parts any questions please let me know////
skunk2 stage 3 cams $450 + shipping
sls top mount manifold setup,dump tubes for 44mm,and 4inch down pipe $800 + shipping
custom vibrant 900hp front mount intercooler with 3inch custom piping for eg $800+shippinng
i can sell the complete set up complete intercooler and top mount manifold for $1500+shipping
custom headlamp turbo inlet made for eg $200 + shipping
hondata s300 already installed in p28 in perfect condition $550 + shipping
rmercado is offline
Old 11-26-2009, 07:27 PM
  #96
south-central's Avatar
Im selling inlinepro b series lug t4 flange stainless steel manifold for $350
Made 750hp with 35 psi with a s372r with 125 exhaust housing, also selling it for 1400 firm.
I only dyno this turbo one time and only race the car at 2/1/2 event b/c broke tranny in one of them.
south-central is offline
Old 11-26-2009, 08:05 PM
  #97
naylor16's Avatar
Aeromotive FPR
110 shipped
OBD1 P28 ECU with eCtune already chipped
165shipped
Bosch 1600cc Injectors
used with about 200miles on them
225 shipped.
Fresh HMO OBD1 Vtec dizzy with 40,xxx miles
210 shipped
naylor16 is offline
Old 11-27-2009, 12:19 AM
  #98
SwappedTURBOegg's Avatar
Im thinking about going back to B series
This is for long block/trans. its 100% ready to run. every part in this engine was bought brand new.With the right turbo this engine can make 1000+ HP
-Darton MID sleeved K24 "CRV" block
-manly turbo tuff rods [real rods. not cheap eagle ****]
-CP pistons 87.5mm 9.0 comp, upgraded wristpins [biggest ones offered by CP]
-ACL race bearings
-golden eagle HD head studs
-k24 CRV head [flows more than k20 heads.VTEC locked]
-Supertech springs/retainers
-skunk2 stage 3 allmotor cams
-type s oilpump
-chains tensioner gaskets everything is brand new OEM form honda
-EP3 5speed act clutch
i want 5k as far as trades SERIOUS b series parts....
No trash no dreamers.
im in michigan
how it sits now
SwappedTURBOegg is offline
Old 11-27-2009, 05:07 PM
  #99
IN VTEC's Avatar
Full-race ProStreet non-AC 3" downpipe
.4-bolt
.has 2 oxygen sensor bungs
.no dents
Asking $200 shippped
IN VTEC is offline
Old 11-28-2009, 09:33 AM
  #100
turbotypeR@SPEC's Avatar
13x8 Weld Magnum w/ M&H 26x8.5x13 and tubes. These tires have plenty of runs left on them and still cut 1.5 60 ft.-$700 plus paypal and shipping:
\T1 g-force shift lever with strain gauge- $700 shipped:
turbotypeR@SPEC is offline
Quick Reply: November FS Sticky
