November FS Sticky
Old 11-02-2009, 07:45 PM
  #26
BLKTeg94's Avatar
Default Re: November FS Sticky
Motor is as follows: $3400 SHIPPED!!!! Will Come with everything listed below.
Motor has 7 passes and 1 dyno session. Made 773HP@30PSI.
LS block
GE Sleeves w/Orings
CP 84mm pistons with upgrades wrist pins (flat tops 10:1 cp)
Manley rods (LS)
LS crank
Clevite Bearings
OEM Oil/Water pump
LS oil pan Tapped
GE LS/Vtec Kit
GE 84mm head gasket
GSR Head
Fully Ported and Polished by Ryan@Warr heads
GSR Cams
Supertech Springs/Retainers
Supertech Inconel Exhaust valves
Bronze guides
Valve Job
High Amp Alternator
Taking interest in parting out the block and head seperate. $2500 SHIPPED on the block and $900 SHIPPED on the head!
LS OBD1
***Will Sell Distributors seperate for $130 shipped each.***
Del Sol Dual Core Radiator w/slim fan $100 shipped
Full Racing Suit $250 shipped
Shroud Pants - SFI Cert 3-2A/5 - Large
Shroud Jacket - Double lined SFI Cert 3-2A/5 - Large
Simpson Shoes - Size 12
Shroud Gloves - SFI Spec 3.3/1 - Medium
Shroud Neck Brace - SFI Spec 3.3
Paypal address is SupraTT_T78@hotmail.com
Jason
801-879-4940.
I do have texting so. Text me if ya got questions.
BLKTeg94 is offline
Old 11-02-2009, 09:45 PM
  #27
rota92
Guest
Posts: n/a
Brand new AEM Injector Driver
275 Shipped
Old 11-03-2009, 04:33 AM
  #28
Big Teggie's Avatar
Contact Info
E-Mail – BigTeggie@gmail.com
PayPal - BigTeggie@gmail.com
Please Email as my PM’s fill up quickly
Please click on the thumbnails for larger images
Brian Crower Stage Cams and Valvetrain K20A2/Z3
-All Parts are brand new in the box, only opened to take pictures.
-BC Stage 3 Cams (BC0043)
-BC Spring Retainer kit BC(0040)
$750 Shipped
Type S shifter box, cables, and Karcepts kit
- Great Condition
-Includes instructions, hardware, and template to install.
$400 Shipped
Hondata IMG
-Brand New
$45 Shipped
T1 Catch Can
- Great Condition, Brand New, Only installed on the car for mockup
-Designed for my K engine, 2 -16an on the top to the valvecover and -10an return
$225 Shipped
Aeromotive Fuel Sample Valve
- Great Condition
-Installed on the car for mockup only
$65 Shipped
EG Civic Custom Cluster
-Autometer 10k rpm tach, and SW water temp and fuel pressue
-Includes all sensors
-I have a wiring diagram I will include so you can wire it up
-Great working condition
$250 Shipped
EG Front Knuckles with Circuitworx Hubs
-Originally off my 94 VX, no miles on hubs, bearings, and balljoints
-Brand New OEM HONDA wheel bearings and new ball joints
-Circuitworx 36mm Hubs
-ARP extended wheel studs
-Hubs cost me $300, bearings $100, balljoints $80, plus the knuckles themselves and labor to install…
$500 Shipped
Lucas 440cc High Impedance B,D,H Injectors
-Great working condition, less than 5k miles
-Upgraded to bigger injectors so no use for them
$175 Shipped
Big Teggie is offline
Old 11-03-2009, 09:12 AM
  #29
TheWickedOne's Avatar
Mickey Thompson 26x10x15 Slicks - Used 10 passes on them, theres a TON of meat left.
$180.00/Pair
TheWickedOne is offline
Old 11-03-2009, 12:10 PM
  #30
00ITR #543's Avatar
Skunk2 Pro1 Cams New $550
Custom catch can setup with lines and JDM ITR valve cover $300 Sale Pending
GSR Transmission with Quaife LSD, freshly rebuilt $1400
2 sets Used CTR Cams $200 (1 set sold) Sale Pending
Black Lenso VPD rear skinnies with 24" MH tires $500
0 miles Stock port GSR head with Crower springs and retainers and Supertech valves, fresh 3angle etc.. Head has not been milled. $850
Sale Pending
0 Miles GSR Head with Stock Valves, Supertech springs and retainers, fresh 3 angle, port matched to gasket and mild polish (no chamber work) $950
B Series T4 Full-Race twinscroll topmount Jet Hot chrome coated with 4" DP and downturn. The manifold was recently recoated and has about 10 dyno passes and 3 passes on track. $950
S372R with 1.25 ar. $975 30 dyno passes and 20 passes at the track
Custom Matching Garrett Core 28x4.5x12 Backdoor intercooler with tial 50mm bov flange, 2.5" inlet and 3" end tank to tb. Matching 3" cold side piping jet hot coated with GM IAT bung welded. $750
Summit -8an 10 micron fuel filter $40
00ITR #543 is offline
Old 11-03-2009, 11:22 PM
  #31
Redline130's Avatar
Spin Werkes wheels
-SOLD!
Precision 350HP intercooler
-Brand new, never used or installed
-$175 + shipping
RJS window net
-Bought from Summit, but ended up using another net
-$20 shipped
Aluminum coolant overflow container
-Brand new, never used it
-Didn't fit in my application, ended up using an OEM one
-Includes a mounting bracket, nuts and bolts
-not sure on capacity, I'd say about 1/2 quart, maybe more
-$25 shipped
InlinePro T3 cast-iron manifold
-SOLD!
Also have:
Yonaka Motorsports EF B-series mounts, brand new-$100 shipped
MSD 2-bar map sensor, brand new-$40 shipped
MSD Blaster SS coils, used less than 300 miles each-$25 shipped each
Chipped PW0 ecu, 9200rpm revlimit, 5200 vtec-$75 shipped
PM me
Redline130 is offline
Old 11-04-2009, 05:09 AM
  #32
FRernesto's Avatar
F/S Used but in good condition Precision Turbo PT74B (Dual ball bearing) with .81ar turbin housing. This turbo is a 74mm. Selling for a friend turbo does not smoke or have shaft play, must go asap switching to Twin Scroll $600.00OBO
FRernesto is offline
Old 11-04-2009, 11:42 AM
  #33
vietjdmboi's Avatar
I have a Freshly built B18C5 bottom end im trying to get rid of. It has zero miles on it since it was built.
ITR block bored .020 over making it a 81.5mm bore
micropolished and balanced ITR crank
Crower billet rods *NEW*
Golden eagle blockguard (installed first, then bored) *NEW*
Supertech pistons 10.1:1 CR *NEW*
ACL Race main/rod and thrust bearings *NEW*
OEM ITR oil/water pump *NEW*
OEM Headgasket, front and rear main seals *NEW*
comes with baffled OEM oil pan
Bottom end ONLY $2200obo
I also have a brand new CC stage 5 four puck clutch for sale for hydro b-series. $325
vietjdmboi is offline
Old 11-04-2009, 03:57 PM
  #34
Autoworks's Avatar
BNIB: D16Z6 CP 9:1 75.5mm Pistons $$515+$15 shipping
BNIB: (2) sets of H- Beam D series Rods w/ ARP 2000 rod bolts $255+14 shipping each.
(Pistons and 1 rod set $750 shipped)
BNIB Innovative Steel 92-95 Manual Tranny mount $75+$14 shipping
__________________________________________________ ___________
USED B Series 92-00 Civic Aluminum Radiator $60+25shipping
USED GO-AUTOWORKS Back Door FMIC:
Tial flange (BOV not included)
3" coldside/2.5" hotside inlet
PERFECT shape $350 shipped (coldside will be made to accept standard 3" coupler at the tank)
USED 3" Vibrant Aluminum velocity stack (see above pic) $45 shipped
USED AEM Electronic boost solenoid (MAC) $55 shipped
MORE PARTS WILL BE ADDED
Autoworks is offline
Old 11-04-2009, 06:16 PM
  #35
88ED8's Avatar
Sold!
88ED8 is offline
Old 11-05-2009, 01:34 PM
  #36
trevor72's Avatar
92 Honda Civic Si, turbo, hatchback, 5spd, 218,000km, 305whp professionally dyno tuned by Dave Lee, still gets 40mpg, factory black paint, interior excellent (black cloth-no tears), sunroof, new tires, very fun street car. $6500obo
Built Motor fresh at beginning of the season. I-beam rod and vitara piston combo. Professionally built and machined. All new water pump, oil pump, timing belt, seals, gaskets, rings and bearings...t3/t4 turbo, Stock head, ported intake and upgraded Throttle body. 1000cc Injector Dynamics injectors. Custom fabricated 2.5" aluminum charge piping, 30"x10"x3" inter-cooler and custom down pipe with multiple bungs for O2 sensors. Complete with catch can and evac system.
Car has been in: Pinks all out and Div 6 Et finals in Woodburn OR. Consistently puts down 12.4x passes and is a blast on the street.
Car is located in: Williams Lake, BC, Canada. Shipping and or delivery is negotiable.
Please contact:
Trevor
250-267-8738
trevormathis@hotmail.com
phone and email contact are preferred
trevor72 is offline
Old 11-05-2009, 03:03 PM
  #37
VTECJUN's Avatar
Default AEM EMS 30-1040
We have a brand new in the box EMS Unit for OBD1 Honda for sale. We were going to use it this year but have decided to go a different route. All accessories are included as you can see from the pictures. Please email me with any questions. Thanks
Matt@SpeedFactoryRacing.net
Asking $900
VTECJUN is offline
Old 11-05-2009, 08:46 PM
  #38
siguy2's Avatar
I am parting out my 6 year project or the entire car all together! The motor has 5 passes at the track and approx. 30 dyno pulls which made 350 whp. LMK if you would like anything on the car. I am going to put up a couple pics, but there is to many parts to list. All prices are wanted and negotiable! I am going to leave my phone number and email, because that is the easiest way of getting ahold of me. 559-679-2055 or cnk4eturn@hotmail.com
Update NEW LOWER pricing (items with *)!!! pics on a requests basis and some items are pick up only.
*-2.2 liter B20 botttom end with 95mm crank, manley rods, circuit works oil pump, and custom JE pistons (block has 4 half track passes) $1200 pending sale!
*-93 integra YS1 tranny with all new seals, gears, and bearing with Quaife LSD $1000
*-LS Vtec line kit $60 sale pending!
*-Ken's Custom chassis wheelie (bars twin wheel design, brand new, never been mounted!!) $450
*-NOS 15 lbs. nitrous bottles filled with nitrous pressure guages and switches (I have 3) $175 each
*-Spearco intercooler 30x3.5x10.5 (brand new) $300
*-GSR throttle body (cable bracket, map and TPS sensor included) $30
*-DSM 440 injectors with resistor box $50
*-92-95 EX 2 door facotry wing with factory wiring $50
SOLD ITEMS:
*-Skunk cam gears SOLD
*-Custom Web Cams (12mm of lift and 319 degrees of advertised duration IN cam) SOLD
*-B16 head custom port job by Vernon at Raver motorsports with Vtec solenoid and custom powder coated valve cover! SOLD
*-Ferrea valve springs and retainers SOLD
*-SI stainless steel 1mm oversize valves SOLD
*-Bosch 1600cc injectors $200 SOLD
-OBD 1 B16 distributor SOLD
-ARP head studs SOLD
-scatter shield SOLD
-Walbro 255 liter high pressure fuel pump SOLD
*-2 Gallon fuel cell with brackets SOLD
*-catch can with breather SOLD
-26x8.5x13 M&H slicks (brand new) SOLD
-24x3.5x15 front runner skinnies (4 passes at the track) SOLD
-Bogart rims 13x8.5 GSR spacers SOLD
-Bogart rims 15x4 skinnies SOLD
-P28 computer with hondata S300 SOLD
-ATI dampner (brand new) SOLD
-Stanley parachute (brand new) SOLD
*-Clutch Masters twin disk clutch 4 passes on the track SOLD
*-JG Fab top mount exhaust manifold with T4 flange SOLD
*-Turbonetics GT42R single ball bearing .78AR with P-trim wheel (brand new) SOLD
*-Turbonetics swing valve wastegate 60mm SOLD
*-Turbonetics Godzilla BOV SOLD
-RPM 76mm throttle body SOLD
-AEM 5 bar map sensor SOLD
-****SMOKIN DEAL****-85 CRX Chasis with custom 10 point cage with front end caged for B or D series motors. The wiring is complete and has a rear safety switch. Drop in a motor and go. Custom stage 4 Drive Shaft Shop axles. GSR front and rear brakes with EBC pads and Brembo rotors. Lexan windows with tow clip. set up for parachute and wheelie bars. has Tokico shocks with Eibach springs and custom pan hard bar with traction bar mounts. MSD 6AL box with 2 step and blaster coil. Guages included are tach, oil pressure and temp, water temp and voltage. Rear hand brake with line lock. custom fiberglass front end SOLD
And if you are wondering I know the pics are all sideways. Don't have time to fix them. Sorry! LOL
siguy2 is offline
Old 11-06-2009, 04:15 AM
  #39
DaveF's Avatar
***asking 12,000***
(this does not include suspension/wheels/drivetrain / NO extras, besides whats listed below)
will entertain trades for "street car" type vehicles. let me know what you have
1992 honda civic si racecar chassis
* 10pt chromoly cage with parachute mount/wheelie bar hookups_ just certified this year_
* Custom aluminum dash, door panels and interior panels
* chromoly wheelie bar with wheeleze wheels
* stroud window net
* omp race seat
* FAL lexan windows (race kit) * Lexan sunroof *
* MB Products fiberglass doors with chromoly frames and lexan window with stainless allenhead bolts/nylock nuts
* G-Force seatbelts, brand new last year (2007)
* Tube front end with midplate & solid timing belt side mount
* clearanced for 28" tires
* Acura sundance gold pearl paintjob
* entire chassis was sand/bead/media blasted before paint
* Carbon fiber front nose
* spare tire well is cut out, with flat aluminum panel covering
* CNC master cyl / cnc staging brake with line lock
* OMP steering wheel with quick release/line lock button
DaveF is offline
Old 11-06-2009, 05:23 AM
  #40
jdm_ef9's Avatar
For sale...
SSR Stainless Custom H2B header w/ megaphone and reverse cone.
V-banded. Will support 300whp. $975 shipped.
Skunk2 PRO3 H22A camshafts.
$575 shipped.
H22A valve cover. Cut for adj cam gears, and has AN bungs welded in for breather setup.
$75 shipped.
Supertech H22A block guard - brand new.
$75 shipped
Skunk2 PRO2 B16A/B18C camshafts
$500 shipped
Eagle B-Series 89mm knife-edged crank
$500 + s/h
Additional pics available upon request. PM me if interested.
Paypal verified.
Pic below is before the header was installed. It's a nice heated color now.
jdm_ef9 is offline
Old 11-06-2009, 05:40 AM
  #41
T4 Neon's Avatar
Chalk it up to the 28% unemployment rate in SE Michigan, and the daily fears that my company / my job might be next.. Chalk it up to starting a family.. Chalk it up to not having the time or patience to work on it anymore.. There just seem to be more reasons to sell it than to keep it at this point. I've owned and worked on this car for 12 years, and its just time to find a new project. Time to hand the reigns over to someone else with more drive, more determination, more interest than I currently have.
The Car:
SFWD 1997 Plymouth Neon ACR, 45k original miles before it became a trailer queen.
10pt Chromoly Cage NHRA Certified to 8.50
-Window Net
-Parachute mount
-Brand New Stroud chute - never been pulled
Matching Kirkey aluminum race seats with covers
RJS 5pt harness set
Fiberglass deck lid (dzus mounted)
Chassis / Suspension:
Custom Truechoice revalved Konis
Ground Control coilover sleeves
450# front springs, 800# rear springs
Machfly Spherical Bearings in front control arms
DSS Stage 3 Axles
Weld Draglite 13x8 front wheels, 15x4 rear wheels, 5x100
M&H Slicks, 25x8.9 front
MT Skinnies, rear
Powerstop cross-drilled 4-wheel disks
Manual brakes with prop valve for rears
Engine - one season of racing & about 30 dyno pulls
Darrell *** Racing "Option A" 1000 HP Bottom End
Darrell *** Racing "Pro Series" Cylinder Head
-Crane 18 Cams
-Fidanza Cam Gears
Front mount alternator setup
ATI Superdamper
Turbo:
Borg Warner S372, 1.10 AR Turbine
R/T Ernie sidewinder manifold, ceramic coated
Dual Tial 44mm Wastegates
Tial 50mm BOV
Full 4” Stainless Exhaust
3” Aluminum IC piping
Treadstone Big FMIC
Custom Intake Manifold w/ 6” plenum, CNC’d throttle body flange
MTX Trans:
Brand new rebuilt by Drakito – 0 miles – all new internals!
T350 3.55 final drive
Tim Kish Spool – special unit with VSS gear ring added for VSS Boost Control
Modified Synchros – all 3 hubs have been pro shifted
Dual teardrop chamfer on oiling passages
Stress risers removed from case
Hydro bellhousing machined for HTOB kit
Tilton HTOB
Brand new – 0 miles – Clutchmasters FX800 twin disk clutch – custom sintered iron disks from Clutchmasters to hold 800whp
ATX Trans:
Custom built by Steve Lockett – 2 passes
Includes ATX shifter – also modded by Steve for quick 1-2 and 2-3 shifts
Includes DSS Stage 3 passenger side axle for ATX
Torque converter spec’d for drag application, can be reworked by Pats Converters if you determine a higher or lower stall is required, for no additional charge.
Electronics:
AEM Standalone Engine Management System with complete custom wiring harness
AEM 4 channel CDI box
AEM Pencil Coils
AEM UEGO
AEM Boost Control Solenoid
Painless Wiring setup with 8 relays
Custom gauge cluster – Tach & two AEM Serial Gauges
Fuel System:
Kinsler matched 1200cc injectors
Kinsler / Weldon 2025 fuel pump
Kinsler Monster Mesh fuel filters – pre and post
Custom sumped stock steel fuel tank
-8 braided feed and return lines
Aeromotive 1:1 regulator
Asking $17,500 for the complete car.
Project Log - lots of photos & build history: http://forums.neons.org/viewtopic.php?f=51&t=300924
Also comes with website - www.project-neon.com!!
T4 Neon is offline
Old 11-07-2009, 03:10 AM
  #42
Mr. Em1's Avatar
Located in Yorktown Heights Ny 10598
contact = sjlutwyche@hotmail.com
aim = jiggajdashockr
or Private Message
Brand New Bronze Drag dr16's w/ 235/60/15 Mickey Thompson Street Radials (1000 miles, 75% tread left and 2 Rota Gt3's 205/50/16 (95%)
- $700obo
Brand New 26x10x15 Mickey Thompson on 15x9 Weld Magnum - $1000obo
Fastline Shifter - $150 firm
Tilton Fluid Control Valve - Brand New Took 2 months to receive (Just changed the orifice and decided not to use) Come with all 3 orifices. - 160 shipped with Paypal fees
Mr. Em1 is offline
Old 11-07-2009, 07:27 AM
  #43
velocitytrends's Avatar
WTT: DSS K20 (in EG/DC/EK) 3.9 Axles with hubs for DSS B-Series High-HP axles. My axles have less than a 1000 miles on them.
I have these:
http://www.driveshaftshop.com/pdetail.php?pid=310
Civic Level 3.9 600HP K-series swap----------------------KG36
Description:Level 3.9 Axle/Hub system 600HP for Civic (non-ABS) with K-series swap (1 year warranty). This axle/hub system is made and designed for the real fast street car or drag car with up to 600HP. This was our older Level 5 (2004 and older) system and we have brought it out of retirement due to the fact a 600hp street car is now a normal thing. This has been one of the best known systems for a Honda platform to date and is still a staple in most tuner shops around the world. The kit comes with both axles made from 300M with billet inner housings. The outer cv is 20% larger than a factory one and is made from a Proprietary material that is brutally strong. The kit comes with a custom hub that is an exact replica of the factory one it just has the larger spline inside. The kit can be ordered here with either long ARP racing studs or a set of standard length ones. This set is considered extreme for an extreme car. Sorry no ABS Rings on this system (can be installed for an extra $100.00 if needed) $1299
velocitytrends is offline
Old 11-07-2009, 08:08 AM
  #44
BILLY_BAD_A$$'s Avatar
Freshly built 84mm Sleeved M.I.D. ERL Block(0 miles since rebuild) $2200
10:1 JE forged pistons, Crower rods, new acl race bearings, new pickup, new oil pump, new gaskets
Sparco seats $550 or $300 each
Kirkey aluminum racing seats $450 for both or $250 each
Avid shift linkage for ef $100
15lb bottle $150
Innovative traction bar for ef(upgraded bushings and front trans mount included with stiffest insert) $180
AEM short ram $40
N1 replica muffler $50
Stewart Warner blue led digital tach $75
BILLY_BAD_A$$ is offline
Old 11-07-2009, 10:03 AM
  #45
Andy@AMR's Avatar
Skunk2 Tuner Series Cam Gears. Excellent Condition. Gun Metal. 135 shipped.
B-series oil pan. P72. Drilled for oil drain flange. 30 shipped.
Andy@AMR is offline
Old 11-08-2009, 03:40 PM
  #46
evo916's Avatar
Default JG Pro series H22 Head
I have a Jg Pro series H22 head in excellent condition for sale. Comes complete with everything except intake manifold. This head has only dyno pulls on it. Parted out the rest of the motor already.
-dual valve springs
-Ti retainers
-SS valves
-pro series portwork
-new valve seals/guides
$600
Thanks,
Jack
evo916 is offline
Old 11-08-2009, 06:33 PM
  #47
scoop's Avatar
Sold.
scoop is offline
Old 11-09-2009, 09:14 AM
  #48
KrazyLuEg8's Avatar
obd 1 aem ..still warrantied with aem,have papers for that too..600 obo pik'd up
located union city,nj 07087
KrazyLuEg8 is offline
Old 11-09-2009, 11:03 AM
  #49
legomytego's Avatar
comp stage 4 clutch with plenty of meat left around 4k.
gsr trans with ITR lsd rebuilt and bought from another member a few months ago trans only has 4k on it shifts like its brand new
legomytego is offline
Old 11-09-2009, 11:23 AM
  #50
PRO1's Avatar
sold
PRO1 is offline
Quick Reply: November FS Sticky
