b series transmission to engine block bolts
Old 10-29-2009, 03:50 PM
AfTeRhOuRs209's Avatar
Default b series transmission to engine block bolts
alright so ive been to honda and acura and i have even talk to the honda distribution center. I need the part numbers for the transmission housing to engine block bolts that attach the tranny to the engine... im guessing all of the b series are probably the same considering they are all interchangeable but for sake of the post im using a b16a2 si tranny on a obd1 ls block. thanks a head of time... this is literally holding up the whole project.
ive been to autozone, kreagen etc etc.... they say to go to honda or acura directly.
Old 10-29-2009, 03:53 PM
night's Avatar
Default Re: b series transmission to engine block bolts
yes, get honda bolts. they are called bellhousing bolts.
just find someone at the parts counter that isn't stupid.
Old 10-29-2009, 06:00 PM
ok so go to honda and not acura and ask for bellhousing bolts, thanks a bunch!
Old 10-29-2009, 07:40 PM
night's Avatar
honda/acura. whatever. just B series. about 3.5 or 4" long.
Old 10-30-2009, 04:31 AM
kyden's Avatar
if you go to honda its #33. under ALTERNATOR BRACKET-ENGINE STIFFENER
90051-PE0-000 BOLT, FLANGE (12X70) 3 of those. one of the starter bolts also hold it on.
if you go to acura, its #24. System Name / Component : ENGINE WIRE HARNESS-CLAMP (2)
Old 10-30-2009, 09:07 PM
thanks!
Old 04-26-2011, 09:51 PM
tronic's Avatar
I've never been able to find these bolts until now!
They are also listed under
ENGINE WIRE HARNESS - CLAMP
about $20 for all 5
23 90050-PG7-000 BOLT, FLANGE (12X65) qty 2
24 90051-PE0-000 BOLT, FLANGE (12X70) qty 3
(parts lookup for 2001 ITR)
EJ8chu
09-15-2006 11:49 PM
killerpenguin21
14
07-13-2006 04:37 PM
275Performance
01-05-2003 07:16 PM
Quick Reply: b series transmission to engine block bolts
