Why is my timing belt slipping off?
Old 09-18-2009, 04:47 AM
Sherm's Avatar
Default Why is my timing belt slipping off?
Just did a headgasket job on a 94 civic w/ a d15b7. I fire it up before putting on the crank pulley, accessories, timing cover and motor mount and literally as soon as I start it up the belt slides over and almost comes off. It came about 1/4 of an inch from coming off completely after running for 5 seconds. The belt was put on tight and was still tight when I shut the motor off. Does the crank pulley and/or timing cover have to be on to prevent this? Or what should I adjust or tweak to prevent this from happening?
Old 09-18-2009, 06:09 AM
jdmwannabee's Avatar
Default Re: Why is my timing belt slipping off?
did you put back part #12.
did you change your tensioner too?
Freemananana
10-24-2015 10:22 AM
us31wking
08-21-2014 04:50 AM
Rost
07-03-2009 09:51 PM
omgwtfbbqcrx
02-16-2006 09:38 PM
vrrodri
07-02-2002 09:19 PM
Quick Reply: Why is my timing belt slipping off?
