B20 VTEC oil leak !!!! HELP
Old 07-05-2010, 11:02 PM
  #26
leochilo's Avatar
Icon4 Re: B20 VTEC oil leak !!!! HELP
Originally Posted by FMN716
Yes my suggestion read over the Reliable guide to building a ls/vtec
you might get some other answers there but I think its also a good Idea to do the following
*Check that the block and head is not warped
*Use the GE dowel pins and get the OEM Gasket for your block which you will have to modify slightly, GE uses the vtec gaskets which are incorrect as you have the ls/crv block
*You need an oil catch tank/breather tank as the ls/crv head had its own kind of breather kit and the vtec head does not use this system in the head, your motor needs to breathe so give it lungs lol
all this makes sense... check for the above possibilities and keep us informed .. im really intrested cause im going ls-v and i dont want to have this problem. good luck man.
Old 07-05-2010, 11:06 PM
  #27
FMN716's Avatar
Default Re: B20 VTEC oil leak !!!! HELP
I am busy making a doc with all the question and answers from the ls/vtec reliable thread on page 45 so far pm me with your email address to send a copy to you guys
Old 07-07-2010, 12:45 PM
  #28
itr1244's Avatar
https://honda-tech.com/forums/tech-misc-15/why-golden-eagle-uses-vtec-gasket-our-kits-2235725/
yes i have the breather kit from endyn . and a 19row oill cooler .
i did not try the oem gasket yet but man. that would be my 3rd h/g change. so much F king work.
i might just go back to my B18c5 .. which has spun bearing . i need to fix that and just F the B20 Vtec
Old 07-07-2010, 01:00 PM
  #29
itr1244's Avatar
i do have a breather kit for the block. are you talking about a breathing system for the head??
i got my head decked so i know it's straight.
but i did not check the block. but for me to check for wrappage . i am going to have to remove my engine again and send it out to machine shop... if i were to do that i might as well fix my B18C5 with spun bearing and put it all together.
i might give this a last try with oem gaskets for the B20B. not the vtec gasket. that would be the last thing i'm gonna try before i call it a quit.
i hope it works . otherwise i need to spend bunch of money lol
Old 07-07-2010, 01:11 PM
  #30
itr1244's Avatar
and i'd like to know. for those of you who have this leak. what headgasket are you guys using?
the GE one? or the oem
Old 07-07-2010, 09:04 PM
  #31
itr1244's Avatar
and where is the location of your oil leak?
Old 07-07-2010, 09:44 PM
  #32
FMN716's Avatar
Ok dude quickly tell me what has been done here
What dowel pins do you have as if they are incorrect your cylinder head might be moving causing this leakage
Check the block for warpage this must be done
What head do you have
Have you used the correct torque settings for your head
What machine work has been done to your motor
What is the highest you have revved the motor to
Keep us updated
Old 07-07-2010, 09:57 PM
  #33
FMN716's Avatar
read this post
https://honda-tech.com/forums/showth...676914&page=50
Old 07-08-2010, 02:12 PM
  #34
itr1244's Avatar
using GE headgasket/ GE dowel pins
have the head plugged
i have used correct torque settings for the head
ITR head
B29B block.
my redline is set below 8000
i have itr head stud
i have ge sandwhich adaptor
got the head cleaned/ decked
have replaced vtec gaskets, 2 head gaskets, dizzy o ring, cam seal
this is one thing i didnt do.. check the block for warpage, i got the block used. the guy before have it built with forged internals and blah blah blah all the goodies. he say he never had any oil leak problems when it was on his car.
Old 07-08-2010, 02:26 PM
  #35
itr1244's Avatar
IF the block is warped. why would everyone have the oil leak on same spot.
the block can't be warp at same spot for everyone
i know exactly where the oil leak is.
"I want everyone with this leak to perform a simple test.
i'd like to know if we all have the same spot leaking.
grab a paper towel and shuv it right under the intake manifold where the block and head meets. . cloesest to the leak.
which is where i have it circled in the picture
in my case the oil leaks from there and finds its way down to the left corner of the block like the picture on the first page.
go for a drive and cool down the car to grab the paper towel and see if its wet.
mine was little wet and it also had a hint of gas in it.
that is werid."
Old 07-12-2010, 11:29 PM
  #36
SMOOTHN's Avatar
I have the same OIL leak in the same corner. I thought i could live with it til the summer was over but since i got off early me and my nephew took it all apart.
I am about to make my own thread about my experience and will link you to it when Im done. I hope it will help you out.
HERE IT IS SMooTHN OIL Problem
kid.dynamite
01-24-2016 09:32 AM
davey5300
05-07-2010 06:01 PM
dirk digler
01-30-2009 04:15 PM
NaVamous
03-08-2005 02:05 AM
Quick Reply: B20 VTEC oil leak !!!! HELP
