#1 | |||||
flickr Last edited by red96civicex; 09-08-2009 at 11:01 PM. |
#2 |
The ELD is built into the under hood fuse box.
Do you have an ELD CEL code? Do you have any CEL codes? Is 7.5A fuse #15 under the dash blown? Is the dash charge/battery light on when you are driving? Your problem sounds more like a bad voltage regulator in the alternator.
Don't guess, troubleshoot |
#3 | |
like i stated above i replaced the alternator a few months back thinking that was the problem but it didnt fix it. EDIT: there is NO battery light on while driving, its nothing out of the ordinary, no weird lights or anything, just dimming lights, and all the lights on the car dim, outside & inside.
flickr |
#4 |
Is the alternator belt good and tight? If so, take the car to an auto parts store like AutoZone, where they will test the alternator free of charge. Some of those rebuilt alternators come bad right out of the box.
Did you check fuse #15 with a multimeter. Also try replacing it with a known good fuse. Does the CEL work? Is the battery ground wire clean and tight?
#5 | |
and yes the CEL light works. EDIT: took all the grounds off last month, cleaned them up, made sure they were touching metal, and re-installed them, didnt fix the problem. ive been researching this for quite some time and fixed everything on my car i thought could be causing the problem...but yet, the problem is still there.
flickr |
#6 |
my next step is to replace the ELD itself, and since its part of the under-hood fuse box i guess im going to have to get a whole new unit...
flickr |
#7 |
You would indeed need to replace the entire hood fuse box. My recommendation would be that you delay this purchase because a bad ELD is a very rare cause for the type of problem you are having. I'd first have the alternator tested and also test all of the alternator wires and connections. Let us know how it turns out.
#8 |
ok so im gonna go and get the alternator tested tomorrow at advanced auto...but how can i check the other alternator "wires and connections"?
flickr |
#9 |
You would unplug the hood fuse box connectors, relevant ECU connectors, and alternator connectors and then check all of the alternator and ELD wires for opens and shorts using a multimeter. But first have the alternator tested.
#10 |
got alt and battery tested...they are fine.
flickr |
#11 |
During the alt testing, did you reproduce the brightening and dimming of the lights? If not, the test could have missed an alt problem.
#12 |
i didnt test it...advanced auto parts did. they told me to turn my high beams and heater fan on...i couldnt see if the lights were dimming or not cause it was light outside
flickr |
#13 | |
Does your alternator have a lifetime warranty?
#14 |
it happens whenever the lights are on...and im pretty sure is lifetime warranty
flickr |
#15 | |
I guess your options are (1) to replace the alternator because it would be free, (2) to multimeter check the alternator system wires, or (3) to replace the under-hood fuse box/ELD.
#16 |
well im eventually going to replace the whole unit...
if anyone who has replaced their fuse box because of this problem please post up!
flickr |
#17 |
bump for more useful information
flickr |
#18 |
bump for trying to get some input
flickr |
#19 |
Im having this problem to, if the ELD is bad, would it have anything to do with sending power back to the battey from the alternator?
#20 |
thats a good question...have you gotten your battery tested?
flickr |
#21 |
Is fuse 15 blown?
#22 |
battery is good, going to check fuse 15
#23 |
i'll post but i have a eg so yea, i got cel 20.... ELD, im guna replace my fuse box cuz since i got that cel my radio hasnt been working, and to the OP is your idle like really low, cuz if it is it could be your alternator always running which is not good for the life of it
PSN : Ingram10 |
#24 |
1994 Honda CivicJoin Date: Nov 2008
^^ batallic, FYI Canadian 5G 92-95 Civics do not have an ELD, AFAIK. (Not shown on the wiring diagrams.) It's possible, of course, that you don't have a CDM Civic.
»LINK« to ALL my DIYs for 92-95 Civics| Headlight Washers | Rear Wiper | Trunk Light | Cruise Control | Power Folding Heated Mirrors / Locks / Windows | Rear Fog Light | Cabin Air Filter | JDM->USDM Fog Harness Conversion | Heated Seats | Walk-in Rear |
#25 |
checked fuse it was blown, yaaaay
| Bookmarks |
| Tags |
| 1990, 2000, accord, alternator, bad, check, detector, eld, electronic, honda, integra, load, location, replace, signs, test, unit |
