Re-installing axle -- is it in far enough?
Old 04-23-2012, 09:01 AM
stepheneb's Avatar
Default Re-installing axle -- is it in far enough?
I'm putting the car back together after replacing the rear beam and I'm having a hard time getting my left-side axle in far enough. This is a 1991 Accord automatic wagon:
I'm pretty sure it's supposed to go further in ???
Old 04-23-2012, 10:50 AM
stepheneb's Avatar
Default Re: Re-installing axle -- is it in far enough?
Ahh ... watching this video from ericthecarguy (at 12m) makes it perfectly clear -- it is NOT in far enough!
How To Replace a Front Wheel Drive Axle
Old 04-23-2012, 10:57 AM
F20B_accord's Avatar
indeed it is not far in enough some times its as simple as taking it out and really lining it up good and then just giving it a good push in, not difficult at all.
Old 04-23-2012, 11:10 AM
djkurious's Avatar
Sometimes I lightly tap the end with a rubber mallet lightly. That usually does the job.
Old 04-23-2012, 05:32 PM
usdmftw's Avatar
on really stuborn ones i have took a wood block and place it against inner axle housing right where boot clamp is and tap with hammer, but got to be carefull b/c can bust boot. i have had some axles that is was a must. its the little c clip on end of axle that usually stops them.
Old 04-23-2012, 06:17 PM
stepheneb's Avatar
I first tried sliding it in with a firm push, then rotating it slightly and trying again.
When that didn't work I put the axle nut on, lined up the whole axle as straight as possible and tapped GENTLY with my little sledge hammer. It popped right in.
rainman3223
Transmission & Drivetrain
08-15-2010 01:13 PM
DiscoLemonade
10
07-10-2010 06:20 PM
Rooftop voter
Suspension & Brakes
04-09-2007 08:38 AM
philipkrotch
01-22-2003 10:46 AM
Aron Parsons
04-15-2002 01:17 PM
Quick Reply: Re-installing axle -- is it in far enough?
