98 Accord no dash lights
I recently installed a new Alpine stereo in my daughters 98 Accord and now the dash board lights are not working. Door open and all other instrument notification lights work, just not the back light on the instrument panel. They all worked fine before i put in the new radio. I also tried putting the factory radio back in and still no dashboard lights. All tail/brake lights work fine, all fuses fine in both panels? Any ideas? Thanks.
Re: 98 Accord no dash lights
Tail lamp Fuse
Dash Illumination fuse
Check that your tail lamps illuminate. If they do, check the dash fuse.
If they don't ......
P
Ok, so I've checked all the fuses again and they're all fine. Is there a relay for the instrument cluster/dash lights? Also, the light for the clock, which sits above the A/C controls, lights up until you turn the lights on, then the clock light turns off. I am at a loss.
P
that's what I thought when she called and told me it didn't work, but I've turned it both ways numberous times with no luck. I will check the fuses one more time tomorrow, but I've already checked them all about 5 times, so I don't think that's gonna be the problem. Anyone know how much the multiplexer is and what exactly and where is that?
As mentioned previously, you most likely blown the driver's side multiplexer (i.e., a component of the multiplexer is blown).
It is kind of expensive from the dealer, so try to hit up a salvage yard for the driver's side multiplexer if costs is a concern.
Here is a thread regarding the multiplexer replacement.
http://www.honda-acura.net/forums/ac...help-swap.html
distra
04-20-2017 11:32 PM
peachykeenwight
04-12-2007 04:52 PM
wsuozzie
11-15-2006 07:06 AM
