Not that fast, but finally a 10!
Well, I've been trying to run 10's in my ek for oh iono about 4-5 years now haha. It's never been an issue of making the power, just not having the right combination of parts and driving skills haha. But this past wednesday that long time goal of mine finally was met and with it, a new one.....9's!
I've had the car 7 years nows and it has gone through many motor setups and turbo setups to try n find the right one. And being a husband and father of 2 with another on the way, I just can't afford to throw all my money into the car which is why it's taken me so long. In fact, as a rule with my wife, I don't use my paychecks on the car which is fine since family comes first. But enough of that, and onto the car.
'97 civic dx
-Golden Eagle sleeved b18c1
-Golden Eagle head gasket
-Arias 9.7:1 pistons
-Manley turbo tuff rods
-polished stock crank
-gsr head w/5angle valve job, stock ports and cams
-Supertech h100d springs/ titanium retainers
-JG Victor X mani
-Str 70mm tb
-Str fuel rail
-Venom regulator
-Magnafuel EFI 600 proseries fuel pump
-Competition engineering fuel tank sump
-Tial 38mm MVS wastegate (2)
-Tial 50mm bov
-Custom 4" aluminized exhaust
-Stock gsr trans w/type r lsd
-COMPETITION CLUTCH TWIN DISC
-DSS stage 3.9 axles
-BullseyePower S372R (tony1 Spec)
-Tony1 Turbine blanket
-LINDER POWER SYSTEMS divided top mount manifold (thanks Justin)
-LINDER POWER SYSTEMS intercooler couplings
-HorsePower Connection custom intercooler w/PTE core
-HorsePower Connection 3" aluminum ic piping
-Twin Tial 38mm MVS wastegates 1bar springs
-Speedfactory stainless dumptubes (thanks ricky)
-Golden eagle head studs
-Innovate LC1 wideband
-Hondata S300
-Tuned by James Kempf @ speedfactoryracing.net
James (JFK98) from SpeedFactory tuned the car on Q16. Made 816whp 493tq @ 39psi. We stopped here as my duty cycle was near max, deffinatly could use an injector driver. This was done with a stock port gsr head and gsr cams so I'm sure theres more to be gained at this boost level, especially in the midrange.
And heres the vid. Drove it 45minutes to the track, ran my 10's and drove it home This is the first time I've ever driven a car with this much power so I'm desperately in need of some more seat time. We should have dropped the boost levels as well, as the track was not holding the 35+psi haha. Hopefully, we can get the car into the 9's before BOTI next month.
http://www.youtube.com/watch?v=wh_XsTYUayI
-James, Matt, Kevin and all the guys at Speed Factory for all the help on the car and getting it to where it is now.
-Brian Macy @ Horsepower Connection for all the fabwork.
-Justin Linder @ LPS -sick couplers and manifold-deffinately made a huge difference this year.
And my personal friends Brian and Steve(reactiondc2) my engine builder
That's all for now guys, thanks for viewing.
-Zol
'97 civic dx
-JG Victor X mani
-Str 70mm tb
-Str fuel rail
-Venom regulator
-Tial 50mm bov
-Hondata S300
-Zol
Re: Not that fast, but finally a 10!
holy crap i would say with that kind of HP you should have ran a ten, you could miss 2 gears and still run a ten with that power.
good ****, i'm in for 9's!!
We have the same catch can set up.. Does the one by the battery hit the hood?
Watch the track official at :45 seconds.... :D
Last run very nice. You need to launch maybe 500rpm to <1000rpm higher. I bet you'd have a little better 60ft.
-Zol
Cool deal. If you listen to your last run you can hear the revs drop. You'll figure it out quick. Pretty good driving for your first time in a high powered front drive car.
i was going to go big and get one. But i have a kid and another on the way . So budget build FTW (it will go 10's tho ;-)
By the way congrats on your kid on the way..
weight of the car? and do you have the breakdown of the 10.6 pass?
O **** Zol.. you got the beast down the track! looks good man! congrats on the time!! not too bad at all for only driving the car down the track a few times!! Hope too see you at BOTI man!!
Myles, I wouldn't miss it man.
-Zol
Holy **** man that thing is heavier than my POS!?!?!?!
On a side note i heard it is only a 1 day event this year at woodburn... woodburn website says 2 days...
Rear bumper support? (but then again you do seem to drive this thing on the street, i'd hate to see the back of your car taco if a old lady gave you the wooptie doo)
