Pre polished weld "L"s....
Old 08-19-2009, 04:02 PM
antireversion's Avatar
Default Pre polished weld "L"s....
Where can I get them and what do they cost ??
Old 08-22-2009, 03:37 AM
ROTARY's Avatar
Default Re: Pre polished weld "L"s....
http://www.stainlesstubular.com/poli...s_fittings.htm
not sure if they have a minimum order amount but give them a call and then let us know what they say.
Old 08-22-2009, 08:59 AM
Agtronic's Avatar
Are you looking for polished schedule pipe elbows, or polished tubing elbows?
Old 08-22-2009, 03:14 PM
ManBearPig4silly's Avatar
Weld els are pipe elbows.
I've never seen nore used them.
Lazy much?
Old 08-22-2009, 08:23 PM
Originally Posted by ManBearPig4silly
Lazy much?
Not Hardly....not as much about being lazy as being more efficient.. I have a full time (60 hr /week) job and try to knock out 2 or 3 manifolds a week for a local speed shop that sells them mail order.. I will usually spend between 4/5 hours polishing the runners and collector on each manifold...with the 10/15 hours a week I spend just polishing ,I could get more manifolds finished if pre polished L's were available......
Old 08-22-2009, 08:27 PM
Pipe elbows... 1.5 sch 10...90's, 45's and even straight sections by the foot..
Old 08-22-2009, 08:35 PM
ROTARY's Avatar
IF polished elbows are available why would you want to sand and buff them your self?
Old 08-22-2009, 08:37 PM
exactly...lol ^^^
Old 08-22-2009, 11:20 PM
RC000E's Avatar
In for a source here. While I definitely am not willing to polish any, I did think of doing another manifold for my own car and I'd be willing to spend a little more to get a nice finished product.
Even if I could get some weld els that are worked in a tumbler to pretty them up. Wasn't AFI or someone doing that before finishing...maybe it was lovefab?
Old 08-24-2009, 09:30 AM
Former Vendor
PSI2HI's Avatar
Tumbling still takes hours to polish it just eliminates the hassle of having to do it, so really he wouldn't be gaining.
How many parts are we talking here? I may be willing to do them if theres a decent quantity.
Old 08-24-2009, 09:38 AM
91jdmhatchback's Avatar
plus tumbling is loud as ****.
Old 08-24-2009, 09:43 AM
Former Vendor
PSI2HI's Avatar
Yes and no. Large cutting media is loud, plastic and polishing media isn't bad.
Old 08-24-2009, 12:17 PM
OG Fabricator
russianvr4's Avatar
i just purchased a tumbler from eastwood, put in some sched 10 90's in there overnight and they barely changed at all. tried several different media types and no luck. looks like i'll be returning the tumbler unless psi2hi can share what kinda media he uses etc.
Old 08-24-2009, 01:00 PM
hootiehoo's Avatar
you could probably make a tumbler....
Former Vendor
PSI2HI's Avatar
Idk what kind of finish your after or what machine your using but if your looking for a polished finish its a multiple process ordeal. What we use here is a ceramic cutting media w/ a cleaner soap which will basically smooth the surface and leave a bit of a shine, then to a porcelian polishing media w/ a burnishing compound if you want a polished shine look. Its a timely process and like what i said earlier if your not doing quantity your not going to save yourself any time/money.
Old 08-24-2009, 01:55 PM
OG Fabricator
russianvr4's Avatar
what soap do you use?
if you could PM me to the links of that stuff i'd appreciate it.
Old 08-24-2009, 03:30 PM
AceRaceParts's Avatar
We can provide #4 finish (180 grit) straight lengths of pipe as well as tees, el's and 45's...however, they will be quite pricey compared to the standard mill finish fittings and pipe we stock. If there are enough people interested I'm sure we can get the price down a bit.
If anyone is interested let me know.
Old 08-24-2009, 07:51 PM
RC000E's Avatar
Personally, it wasn't something I wanted to do in terms of multiple pieces, just for my own personal project. Would be a nice option to have to really make something nice.
Old 09-06-2009, 04:30 PM
RickyLee53's Avatar
If you work 60 hours, and spend 4-5 hours polishing each manifold thens surely each manifold most take you 15 hours plus making a manifold, (5 to cut, 5 to weld) thats 105 hours working in a 168 hour week.
Personally I spend less time polishing than I do cutting/welding.
What polishing method do you use?
Old 09-06-2009, 05:29 PM
you need a vacation.
Old 09-07-2009, 03:31 PM
ALL IMPORT's Avatar
do u guys polish the pieces before u even start mocking them so u can just put them on a wheel? or do u tack everything up then takeapart then polish ? or what process exactly is the best u found.
Old 09-07-2009, 05:37 PM
i polish and bevel every piece prior to tacking it up. but i spend a good amount of time holding bends in place/cutting to fit.
hoochhenry
Welding / Fabrication
10-26-2011 12:03 AM
all_motor_mike
08-18-2010 09:10 PM
brandobot89
06-02-2008 11:12 AM
FURACERMAN
01-06-2006 06:32 PM
ChainbreakR
27
02-24-2005 08:44 AM
Quick Reply: Pre polished weld "L"s....
