Old 03-25-2015, 09:11 AM
How-Tos on this Topic
Last edit by: IB Advertising
Print Wikipost
Fuse Box Diagram 94-97 accord
Old 07-19-2009, 08:37 PM
smoov_w4gon's Avatar
Default Fuse Box Diagram 94-97 accord
I am looking for a fuse diagram for a 94-97 accord, under the dash fuse box. any links or pics will be very helpful. thanks
Old 07-19-2009, 08:42 PM
The-Kid's Avatar
Default Re: Fuse Box Diagram 94-97 accord
I believe I posted one up before. Search for it.
Also if you have the owners manual, it's in there.
Old 07-19-2009, 08:46 PM
The-Kid's Avatar
Since I cannot find it in the search results.... Here it is.
Old 07-19-2009, 09:32 PM
i dont have an owners manual. cant seem to find anything with the fuse box diagram.
Old 07-19-2009, 09:36 PM
The-Kid's Avatar
http://picasaweb.google.com/lh/photo...eat=directlink
I guess the pix didn't show up.
Old 07-19-2009, 10:21 PM
thanks kid! thats exactly what i needed.
Old 01-13-2012, 10:12 AM
starbux57's Avatar
I just bought a 97 Accord and could really use a diagram of the internal fusebox if anyone has one they can post, link, or email to me. Thanks.
Old 01-14-2012, 07:10 AM
Lost Again's Avatar
Not sure exacly what you are wanting......of course you could always register you car with Honda owners link and download the owners manual in a pdf that would have this information (www dot ahm-ownerlink dot com).
This is from a 94, should be the same.
Old 10-22-2013, 01:49 PM
Directaudioent's Avatar
Just bought a 97 honda accord was told the radio did not work. I took out the radio checked all the fuses everything worked I used a multimeter to test current everything was fine I pluged back the radio and jiggled the wires around...it came on for a few min then cut off. Then I went to check the fuses under the hood none of them make my light on my tester light up so I checked under the driver side fuses they no longer light up my tester.. The power windows and lock still work and when I test the wire for the radio it lights up my tester and the light on the radio stays on but now the turn Sinhals don't work along with the fues need help ASAP
Old 02-28-2014, 09:59 AM
mikeKwilson's Avatar
I need to know what fuse controls the signal lights on the car. my signal lights inside the car or outside work but the hazard lights work and the high beams and head lights. is it the fuse?
Old 08-06-2015, 11:28 PM
drm gncazually's Avatar
Bradlyn Jae
06-24-2012 07:20 AM
starbux57
01-14-2012 07:43 AM
maineduckhunter
11-14-2008 09:41 AM
Quick Reply: Fuse Box Diagram 94-97 accord
