How To Reset SRS Light
Old 07-12-2009, 08:56 PM
EricJS's Avatar
Default How To Reset SRS Light
I noticed the SRS light was lit up after I had my transmission worked on. The radio presets were erased, so I believe the battery had been unhooked.
I had read where the SRS would light up after batteries had been replaced or certain fuses had been pulled.
Can anyone tell me how to reset the light? It is listed on the Accord FAQs, but the link no longer works.
Thank you!
Old 07-12-2009, 09:35 PM
95EG690022's Avatar
Default Re: How To Reset SRS Light
http://tor.in.honda.com/Rjanisis/pub...096S23316A.pdf
Old 07-12-2009, 10:17 PM
striker81's Avatar
Good looking out.
Old 07-13-2009, 05:38 PM
EricJS's Avatar
Great! Thank You.
Old 07-13-2009, 06:36 PM
dbl-htch's Avatar
Where exactly do you find that SCS service connector? Would this apply to OBDI (95 Accord)? Thanks...
Old 07-13-2009, 06:46 PM
He knows where you live!
TheMuffinMan's Avatar
It should be in an identical location as the one for the 96.
You can also refer to my FAQ on how to Bypass SRS for an aftermarket steering wheel. I have the reset instructions and some pictures in there.
Old 07-13-2009, 08:27 PM
dbl-htch's Avatar
nevermind, figured it out...the "SCS service connector" is a seperate tool, not something that's on the car somewhere...and thanks for the help, read the how-to's, gonna try tomorrow on my friend's car...
Old 07-14-2009, 01:17 AM
95EG690022's Avatar
it should be on the side of the firewall, thats where i found mine, eventhough i followed the isntructions and the srs blinks twice indicating it got reset, my srs wont go away
Old 07-22-2009, 06:30 AM
sgriffiths's Avatar
STRIKER81 is a thief! WHERE IS MY ENGINE?!?!??!
Old 07-22-2009, 10:59 AM
MissJPhatEphex's Avatar
i bypassed mine after having installed a momo wheel
Old 01-15-2010, 04:14 PM
meandino's Avatar
This info helped me out. Got my light to turn off. We'll see if it stays off.
Old 08-15-2011, 04:06 PM
361 accord's Avatar
the damn link is broken
Old 08-16-2011, 12:14 AM
mudpuppy4life's Avatar
where is the FAQ at? i cant find it
Old 08-16-2011, 02:39 AM
It says
Sticky: ► 1990-2002 Accord FAQ
At the top of the section...
Old 07-06-2012, 02:34 AM
2stripeAccord's Avatar
thanks worked like a charm
Old 09-07-2012, 02:40 PM
EKrazy91's Avatar
Icon3 Re: How To Reset SRS Light
OK heres the situation with my DD auto 96 DX hatch... im new on here and having a really hard time finding what i'm looking for.
so about 2 weeks ago i rear ended someone, smashed my front end up, and deployed both air bags ... SRS light came on of course. over the next week i pulled the radiator support out and straightened it back up, fixed cosmetics, and then i replaced both air bags. i had to replace the 15A fuse under the dash for the SRS and fuel pump because it popped in the wreck. It runs and drives like nothing ever happened. but my ******* SRS light will not shut off!!!!! i've checked wiring, plugs, seatbelt buckles, resistances, and tried jumping and resetting the control module (it won't even get to the first step where the light cuts off the first time!). After all that, i decided to thake the one out of my 97 turbo LS coupe and try it.... SAME THING !!!
ANY IDEAS PLEASE?!?!?! its driving me nuts!
Old 09-08-2012, 08:09 AM
Lost Again's Avatar
The 96 "should" still have the two pin service connector under the glove box. Try jumping it and see what code(s) you are getting from the SRS....works this way on the 95 - yes, I know there were changes in the 96-97.
Old 09-08-2012, 10:32 AM
EKrazy91's Avatar
I thought the 2 pin under the glove box was for check engine? my srs has its own 2 pin plugged into the fuse panel just like all the reset threads show. idk. i'll give it a shot and let you know. that's really about the only thing i havent tried. thanks
Old 09-08-2012, 10:57 AM
EKrazy91's Avatar
tried it. still nothing. i'm almost to the point of just disabling the whole system, the only reason i havent is because i wanted to keep the dd clean and just like from the dealer.
Old 09-08-2012, 12:07 PM
BrotherAli's Avatar
I followed this and it worked:
You didnt really give good details though. Have you tried resetting the connector that is under the driver dash with the yellow connector (NOT THE ONE IN THE FUSE BOX)? You might have to try a few times. If you have then what is the code after you reset it?
Old 09-08-2012, 02:49 PM
EKrazy91's Avatar
the connector that i tried it with is the only connector that isn't connected to anything. it just plugs into a dummy slot in the very top of the fuse panel, kind of up there by its self. and it's the only 2 prong connector under the drivers side, unless i use the plug that the actual air bag plugs into. it looks exactly like the one the guy is holding in his hand in that video. i jump it, cut the ignition on, wait for the light to turn off......... it never turns off..
Old 09-08-2012, 03:05 PM
BrotherAli's Avatar
I could be wrong but I think it should at least go off and give you a code then come back on. I had to do it like 3-4 times because I wasnt getting a good connection but kept trying because I had done it before and knew I was doing the right method.
Old 09-08-2012, 03:12 PM
EKrazy91's Avatar
thats what i'm saying. it is supposed to do something, but it's like it doesn't even realize it's jumped out. i've tried everything, wires, paper clips, even took off the insulation and crossed them... idk
Old 09-09-2012, 08:58 AM
Lost Again's Avatar
When you jumped the wires - the CEL and D4, what did they do? Again want to be sure you have the correct connector and that the "jump" between the two wires is complete.
Old 09-09-2012, 07:15 PM
EKrazy91's Avatar
The cell just came on when I switched the ignition on and stayed on. I haven't noticed d4 doing anything. Ill try again tomorrow and let you know.
PaulRi
12-08-2015 05:29 PM
kornerk12
11-10-2008 04:11 PM
bowerskd
09-30-2008 11:26 AM
technine
05-25-2006 03:05 PM
TOMSBLUEHONDA23
09-03-2005 02:32 PM
Quick Reply: How To Reset SRS Light
