1995 accord ex vss location
Old 06-05-2009, 12:04 PM
smokimon001's Avatar
Default 1995 accord ex vss location
hi, everyone, i have problem looking for the 95 accord ex vss, anyone know where exactly it is, a shot of picture would be awsome, thanks
Old 06-12-2009, 04:24 AM
95EG690022's Avatar
Default Re: 1995 accord ex vss location
pull out ur gauge cluster its the orange wire on the right hand side. u can find out for sure by putting a volt meter to it. put it on Ohms, put the car on drive let go of the gas ( DONT GIVE IT GAS) just let it go on its own and when the car starts to move the ohms should go up. Thats where I found mine for my GPS.
Old 06-12-2009, 06:02 AM
GhostAccord's Avatar
The sensor itself is located on the top of the transmission. If you remove your air intake tube you should be able to see it bolted on the top of the transmission. It's to the rear of the engine compartment closer to the firewall.
Old 06-12-2009, 08:50 AM
accord99power's Avatar
are you havin tranny problems? i got suckered into al long time ago on my 96 accord by autozone. my engine light had a vss code,so they told me to replace my vcc, but it was still the tranny failed. just a heads up if your goin through tranny problems.
BHNTech
04-24-2006 07:59 PM
JMK3rd
03-27-2006 04:08 PM
Dorikamu
01-18-2002 08:29 PM
Quick Reply: 1995 accord ex vss location
