Grinding noise from brakes while driving
Old 06-02-2009, 08:41 AM
kattmarl's Avatar
Icon3 Grinding noise from brakes while driving
Hello!
I recently purchased a used 2007 Civic EX, and it was driving without a hitch for a couple weeks. After we started getting humidity and rain - when I start the car and get it moving, I began hearing a grinding noise coming from the brakes. I would stop the car with the brake and start again.. and it began scratching again. Eventually, the sound just vanishes...
I can be driving along a freeway when out of the blue the scratching starts up again... I can tap the brake and sometimes it goes away.... sometimes not. Often, the sound just vanishes again. I'm concerned it may be a rotor issue or brake pad deformity. The brakes are relatively new 4k miles on them. So this can't be brake dust or something can it?
Any ideas?
~ Katt
Old 06-02-2009, 08:55 AM
Road House
FijiBlueFG2's Avatar
Default Re: Grinding noise from brakes while driving
It is grinding while not braking? That is peculiar. Still under warranty? Get it checked out, either way.
Old 06-02-2009, 09:18 AM
kattmarl's Avatar
Correct, it doesn't grind while braking. It only happens while driving.. When I brake, the sound goes away completely. When I compress the brake hard, the sound goes away and doesn't seem to come back for a while.. then, out of the blue while simply driving straight down the road... it will start in an instant.. GRRRRRRR! I tap my brake, then harder... sometimes this gets the sound to disappear.. sometimes it doesn't. Usually I pull over, hit my brake pedal hard, and start driving again... that seems to "clear" it.. but.. then while simply driving straight again... it might just start all over.
Old 06-02-2009, 09:37 AM
ironworker's Avatar
Sounds like you just need a brake job. My fronts were doin that and got new one's they dont grind anymore. Now my backs are grinding getting them fixed 2morrow. The pads have a metal tab built in them and when they get low enough that tab hits the rotor and makes a grinding noise.
Old 06-02-2009, 09:58 AM
kattmarl's Avatar
A brake job? That's it? It sounds so much more scary than that.. and why doesn't it scrape when I depress the brakes? Seems like a very worrisome sound... more scary than helpful.
What kind of price should I find a standard front brake job costing? I've seen quotes for $60 on up to $250. I saw the price of bake pads to be only like $30.. is that for one wheel or 2? If so, how come some places charge $250?? Does it cost them money to treat the rotor?
Forgive me.. it's my first Honda.
Thank you!
~ Katt
Old 06-02-2009, 10:12 AM
ironworker's Avatar
Thank you!
~ Katt
It stops when you hit the brakes because the pressure bends that tab back a little and then it goes back to normal and hits the rotors. My gf is a service adviors so i got hooked up. The labor for front brakes and pads should run you about 115 for labor and about 60 for pads. The back is 115 for labor and around 50 for pads (honda oem pads). The labor might be a little different were you live and i think i got a 10 or 15% discount on my pads. They turn the rotors as a part of the brake job.
Old 06-02-2009, 10:37 AM
kattmarl's Avatar
Thank you sooooo much!
My Mustang never had such noises so I'm getting used to this little shuttle. I love it! Very smooth ride and great on the pocket book.
Your suggestions and thoughts have been wonderful.
Thank you again!
Katt
Old 06-02-2009, 03:24 PM
chiggin's Avatar
Sounds like your pads could be low causing the tab to hit like others have said. Also, sometimes there is not enough grease on the break pad. This can cause it to vibrate in the caliper which can sound like a grinding noise. Just change the brake pads and you should be fine.
At $60 per axle for oem brake pads, I would suggest going with Hawk HPS pads instead. They are around $60 per axle and provide much better braking performance than oem pads (IMO).
I would highly recommend learning to change brake pads yourself. It is very easy and it will save you A LOT of money. With a little practice, it takes no time at all. When I recently change the rear pads on my Si, it took me 10-15 minutes to do both sides....and I was taking my time! If you lived in my area, I would offer to change your brake pads for half of what the shops are quoting you....maybe less!
Old 06-02-2009, 03:59 PM
kattmarl's Avatar
WOW,
Thank you all for such helpful information!
I agree with you - it would be best to learn how to do the job myself.
Are there any resources online showing how to do it?
I don't have a user's manual - does it explain in there how to do the job?
Maybe somebody could do the job and record it on video for others to view and learn?
If anyone knows any online links to learn how to replace brake pads, please post them and let me know!
Thanks again to everyone for your wonderful support and replies.
Sincerely,
Katt
Old 06-02-2009, 10:17 PM
CiViCaDDict's Avatar
I recently had the same or similar issue. When I turned, the scrapping was worse. I found out that the axle bolt was not put back onto my car tight enough after getting some work done. However, the ride also felt rough and the tire would catch funny sometimes causing the car to jerk over. It basically caused the rotor to be loose and rub the caliper.
Old 06-03-2009, 11:03 AM
ironworker's Avatar
I put all oem pads back on the honda i stop alot better. I remember reading about hawk pads whats the difference? Anyone else using hawk pads want to put there 2 cents in? Id like to see what the difference is between the two,and how many miles have you got out of oem,or aftermarket pads. I got 55k out of my stock brakes.
Old 06-03-2009, 11:06 AM
Road House
That will happen. Even on OEM. Usually when turning through a pothole or on metal surface.
Old 06-03-2009, 07:55 PM
Yeah, I was really meaning on smooth road. I evaded potholes and bad roads like the plaque. Now I just have to replace the rotor and brake pads. Sucks because I only had them done a few months ago.
Thinking of going to slotted rotor anyway. Already had the racing brake fluid which works like a champs.
Old 06-03-2009, 09:01 PM
SunsetSi's Avatar
My sister's 06 sedan had this same problem. She took it to the dealer and had them drive it around. The guy at the dealership said he didnt hear anything, when i was sitting in the back seat and clearly heard it coming from the back rotors. He said to bring it back when the noise gets louder. Doesnt sound like quality service to me
Old 06-03-2009, 10:33 PM
Dealers are a pain with stuff like this. Always saying, "we have to create the noise or issue." I think they are trained to use selective hearing.
Old 06-04-2009, 05:07 AM
chiggin's Avatar
No real need to. Regular rotors will be more than fine. You won't realize the full benefits of slotted rotors unless you do a lot of the heavy braking you would see on track. Also, with slotted rotors you will go through brake pads significantly faster.
ultima.maniac
06-14-2009 10:50 PM
Secret Chimp
07-01-2007 08:35 PM
GeekinEK
11-02-2006 09:40 AM
lv6l
01-04-2005 11:42 AM
Quick Reply: Grinding noise from brakes while driving
