Joining Aluminum Tubing
Old 05-27-2009, 07:54 AM
B18C_EJ8's Avatar
Default Joining Aluminum Tubing
I posed this question late last night in GDD, because I forgot all about this section. Copy & pasted below are my posts:
I have two 5 foot sections of aluminum tubing that I need to connect end-to-end in the strongest manner possible.
Dimensions of the tube is 1.75" OD, 1.575 ID.
Which would be stronger?
Connect the tubing with a 12" section of piping, on the outside, bolted/nutted through both "layers" on both sides of the joint?
Or, connect the two pieces with a section of piping inside of the two sections, bolted/nutted through, on both sides of the joint?
<questions were asked, and my answers follow:
It will be loaded on one end, attached at the other, 10 feet away, parallel to the ground.
The two ends will be butted up against each other as close as possible.
Wall thickness of the 12" section is TBD, but probably equal to or greater than the .089" wall thickness of the tubing being joined.
The general consensus was to use larger tubing around the outside of the piping to be joined. What do you experts think?
Also, how much trouble would it be to make this whole assembly screw together with threads? More trouble than it's worth, I suppose...
Old 05-27-2009, 07:55 AM
B18C_EJ8's Avatar
Default Re: Joining Aluminum Tubing
Forgot to add that I can't just weld the two pieces together. I need to assemble & break it down in the field for transport, since 10' of pipe won't fit in my 2 door Accord.
Old 05-27-2009, 10:25 AM
k24em2's Avatar
What is it going to be loaded with?
Old 05-27-2009, 10:31 AM
B18C_EJ8's Avatar
Stuff.
Miscellaneous equipment not exceeding 10 pounds.
Old 05-27-2009, 11:20 AM
Stachi's Avatar
Why not weld a bolt into one and a nut into another on?
Marc
Old 05-27-2009, 11:28 AM
B18C_EJ8's Avatar
^^^ Like end to end and screw them together?
Definitely a good idea, but I'm also trying to do this for free.
I don't weld, nor do any of my friends, so I'd have to pay to have it done.
Old 05-27-2009, 12:14 PM
k24em2's Avatar
Just slip the 12" piece over both and put a bolt through each end
Old 05-27-2009, 01:43 PM
Bailhatch's Avatar
camera mount?
I say use a sleeve over the outside also.
Old 06-01-2009, 01:43 AM
i drive a honda's Avatar
just 10LBS ?
bolt and a nut combo, also drill extra holes in the smaller one so it's adjustable, if you still don't feel safe ad another bolt. best way to do it is to weld them together, but you're on a budget/no welder so best way you're getting it
Sprockets
09-04-2005 10:04 AM
DIY_Racing
Welding / Fabrication
04-27-2005 08:28 AM
sporkcrx
51
01-21-2005 11:06 PM
adseguy
10-04-2004 04:07 PM
mike1114
06-03-2003 06:23 PM
Quick Reply: Joining Aluminum Tubing
