Old 03-25-2015, 10:40 AM
How-Tos on this Topic
Last edit by: IB Advertising
Print Wikipost
5th Gen Radiator and thermostat install and how-to
Old 05-08-2013, 05:03 AM
  #26
djkurious's Avatar
Default Re: 5th Gen Radiator and thermostat install and how-to
Originally Posted by scomstock55
same question for me except mine is a 2001. thanks
Same procedure.
Old 06-17-2013, 09:14 PM
  #27
MM Gruppe B
MAD_MIKE's Avatar
The thermostat in the '95 EX has failed open... yaaay.
While I was under the hood I could not help but notice all the thermo/temp senders.
37750-PH2-014 015 THERMO UNIT (DENSO) 36.15 24.94
37760-P00-003 016 SWITCH ASSY., THERMO 52.97 36.55
37773-PT3-A01 018 SWITCH, THERMO (A-106) 60.82 41.97
37870-PK2-015 019 SENSOR ASSY., WATER 38.20 26.36
I thought there was a break down/labeling of each sensor in the FAQ but didn't see it.
What I think the senors are
#15 Temp gauge
#19 ECU temp sensor
#16/17 Fan switch
#18 fan switch
TIA.
Old 06-17-2013, 09:33 PM
  #28
holmesnmanny's Avatar
You got it, mike. Obviously make sure you don't install 16 and 18 swapped.
Old 06-17-2013, 10:47 PM
  #29
MM Gruppe B
MAD_MIKE's Avatar
Do they act as ON and OFF switches for the fan relay controls?
Or is one for normal temperature threshold switch and the other is for emergency going Chernobyl, need both fans on, activation?
Old 06-18-2013, 02:21 AM
  #30
16 controls the fans with ignition on 18 controls fans with ignition off
obviously 16 has a lower threshold for heat approx 190 degrees vs 205 or so... est.
16 will run both fans 18 will run only radiator fan
mattyfo0z
08-11-2010 09:35 AM
MadCityLude
11-03-2006 06:13 PM
bmwlrj
07-21-2004 01:16 PM
blacks2000
07-28-2002 05:12 PM
Quick Reply: 5th Gen Radiator and thermostat install and how-to
