Old 05-18-2009, 06:05 PM   #1
FormulaIntegra
FormulaIntegra's Avatar
Send a message via AIM to FormulaIntegra
Icon2 Engine Coolant Temp (ECT) sensor questions
1995 Civic EX, D16Z6. So, looking at my shop manual, and under my hood, there are 3 sensors:
1. Engine Coolant Temperature Switch, which is located at the thermostat housing, and tells the radiator fan relay to turn on, via the ECU.
2. Engine Coolant Sending Unit, which is the single wire post under the distributor cap that goes directly to the temp gauge on the dash.
3. Engine Coolant Temperature Sensor, also under the distributer cap, and looks suspiciously just like the ECT switch....which I can't seem to find in my Honda factory manual, and is labeled in one of the pictures in the back of my Haynes manual, but no explanation for what it does, where it goes, etc.
It doesn't seem like my radiator fan is coming on when it should, and I'm trying to track down whether it's a bad sensor, and if so, which one, or if the relay is bad. Anyone know what the Temp sensor does, as opposed to the sending unit or temp switch, on this engine? The factory manual doesn't have a pin out for the ecu, so I don't know if it's looking for info from the switch and the sensor, or what. Any info would be helpful. TIA.
#05 ITA Honda Civic EX - 2005 SCCA Cal Club Reg ITA Champion
FilterMAG http://www.filtermag.com
Advanced Waterjet & Engraving http://www.advancedwj.com
FormulaIntegra is offline   Reply With Quote
Old 05-18-2009, 06:22 PM   #2
speedracer9k
speedracer9k's Avatar
Send a message via AIM to speedracer9k
Default Re: Engine Coolant Temp (ECT) sensor questions
unplug the sensor off the t-stat housing and take a paper clip and jump to 2 terminals on the connector. the fans should come on. if they dont the fans dont work. if they come on, then you have another problem. try that and let me know.
-93 prelude - just sold 9-17-08 http://is.rely.net/1-92-65076-l-NREc...mLFY3DaZnA.gif
my newest ride = 96 civic coupe
Originally Posted by Alude99
you probably just need to re-charge your A/C fluid.
speedracer9k is offline   Reply With Quote
Old 05-29-2009, 11:09 PM   #3
FormulaIntegra
So, first of all, I wired straight from the battery to the radiator fan, and that worked, so I know the fan motor itself is not the issue. Next, I tried your suggestion to pull the ECT switch connector at the thermostat housing, and jumpered it with a paperclip. I could hear the fan relay clicking in the engine fuse box, but the fan wouldn't come on. What does that mean?
Also, the other sensor, the one underneath the distributor, what does it do, and how does it factor in to the system?
Old 05-30-2009, 02:50 AM   #4
robbys89
robbys89's Avatar
sounds like your fan relay is gone. replace and see what happens. the sensor under the distributor is the temp sensor that tells you the temp of the engine on your cluster thats all
robbys89 is offline   Reply With Quote
Old 05-30-2009, 03:04 AM   #5
TsunamiR
TsunamiR's Avatar
Send a message via AIM to TsunamiR Send a message via MSN to TsunamiR Send a message via Skype™ to TsunamiR
You should check if there are sensors in the 5 volt control!
I LOVE MY COUPè EC1
TsunamiR is offline   Reply With Quote
Old 05-30-2009, 05:32 AM   #6
civic_driver
civic_driver's Avatar
The ECU doesn't control the ECT switch on the thermostat housing. The temperature controls it. Once it reaches a certain temperature (can't remember off the top of my head, around 80 degrees celsius) the switch activates which in turns activates the radiator fan. The ECU controls the radiator relay though, maybe that's what you were thinking of.
I think you have a loose wire between the relay and the radiator fan.
Right.
This is not a switch. It's a sensor that reports the coolant temperature to the ECU. The ECU uses this to find out if the engine is cold in which case it adds more fuel so the engine can warm up faster. The ECT sensors is also used to adjust spark, EGR function, open/closed loop feedback, idle speed and so on.
For Sale Thread
civic_driver is offline   Reply With Quote
Old 05-30-2009, 07:51 PM   #7
FormulaIntegra
Awesome info, thanks guys.
I love when I get to do a whole ton of troubleshooting, tracing wires through the harness, looking for a broken wire or one shorting to ground, taking apart the underhood fuse box because I wasn't getting continuity on one of the connections to the fan relay. After doing all that, it ends up simply being a blown fuse in the underhood box. I swear I thought I checked them all before I started, but as soon as I replaced the fuse and jumpered the t-stat temp sensor connection, the relay clicked and the fan came on. I love it when I get to learn a bunch about a system, and the fix ends up being something inexpensive and easy.
I usually believe in trying the easiest things first, but you don't learn as much that way. Sometimes the hard way is more rewarding.
Old 05-30-2009, 07:57 PM   #8
civic_driver
Isn't that the truth... Great stuff
For Sale Thread
Old 08-13-2010, 02:40 PM   #9
hondatango
ok i have followed all this in to a t and replaced all sensor except under the distributor and still gauge works but fan still not kick on should i replace that sensor too? i also replaced relay just incase and jumped the pins to test fan and the fan runs but when car gts hot it not kick on help please lol
hondatango is offline   Reply With Quote
Old 08-13-2010, 02:45 PM   #10
RonJ@HT
Moderator
2000 Honda Civic
My Garage
RonJ@HT's Avatar
Bleed the cooling system.
Don't guess, troubleshoot
Useful tech links: FAQs; Codes; Check Spark; Test Fuses; Fuse 15 TSB; Clean IACV or FITV
Please don't PM me tech questions. Create a thread.
Old 03-15-2011, 10:06 AM   #11
roze1981
I've had the same problem and my car's light was on for 2 years. I have been to Honda dealer and other mechanics but couldn't fix it.
Last month I went to this guy in downtown toronto and he could fix it.
anybody has the same problem go to this guy he can do miracles.
PM me for contact information.
cheers,
Roze
Last edited by RonJ@HT; 03-15-2011 at 10:28 AM. Reason: Contact information deleted and PM contact request added.
roze1981 is offline   Reply With Quote
Old 09-05-2011, 04:28 PM   #12
95Prelude2go
My 95 prelude with h22a1 in it and i unplug my ect and car runs better
So I took a ect sensor off h22 a4 same sensor and car doesn't change but when I unplug runs better should I check wires to Ecu
95Prelude2go is offline   Reply With Quote
Old 01-23-2012, 07:06 AM   #13
CBL9
CBL9's Avatar
Send a message via AIM to CBL9
Sorry to being this back from the dead, but I searched and found this.
I have a 1995 Civic EX 145k on it bought it over the summer with 138k. Up until winter the temp gauge on the cluster never reached the "point right below half" on the cluster. It would stay at half of that approximately 1/2 between cold and where it should have been.
Now that winter is here the gauge moves 1-2mm making its way from below cold to the cold level. The car does not heat up well IMO. Today I just sort of jumped the gun, bought a gasket and thermostat and replaced it, and bled the cooling system.
I let it idle for 1/2 hour and the fan never came on. The coolant gauge on the cluster moved no more today than it did in the past, just that 1-2mm. I checked the fan fuse under the hood, that was intact. I switched the AC on and the AC fan came right on.
I do not know how long the fan has not been working for. I want to know if I have two separate issues here or one bigger issue causing these two problems of
1.) Radiator fan not working
2.) Cluster needle moving a very tiny amount
Thanks Guys!!!
2008 Pilot EX-L - Boat Hauler - Nimbus Gray Pearl
2007 BMW 335i - Weekend Toy - Crimson Red Clear
2006 Accord EX-L - Daily Driver - Alabaster Silver Metallic
1993 Accord SE - Winter Beater - Cashmere Silver Metallic (213K reliable miles)
CBL9 is offline   Reply With Quote
Old 01-23-2012, 07:13 AM   #14
grumblemarc
The Grumpiest
1996 Honda Civic
grumblemarc's Avatar
iTrader Rating: (3)
Send a message via AIM to grumblemarc Send a message via Yahoo to grumblemarc Send a message via Skype™ to grumblemarc
Does the fan actually work? Not coming on is not the same thing.
FAQs!--How to Turbocharge your Civic--Want a faster Civic?
Don't use the words "Help!" or "Best" in your threads titles. It shows everyone that you don't have a clue and that you are extremely lazy.
grumblemarc is online now   Reply With Quote
Old 01-23-2012, 07:18 AM   #15
CBL9
CBL9's Avatar
I am not sure. How can I test that?
Old 01-23-2012, 07:58 AM   #16
motegicivic
I have a feeling it is not hot enough for the fan to come on, pull the plug off the thermostat housing and use a paperclip to jump it (bend like a "U" put one end in each plug opening) turn the car to position 2 and see if the fan runs.
So you are saying the car seems to run too cool?
motegicivic is offline   Reply With Quote
Old 01-23-2012, 08:19 AM   #17
MonkeyBoy668
1997 Honda Del Sol
MonkeyBoy668's Avatar
Just want to throw this out there, but there are some lousy third party parts floating around these days. It's not unheard of to buy a new in box tstat and not have it work.
The cheapest way to check one is the stovetop method... get a medium size pot, fill it most of the way with water, place thermostat in water, place thermometer in water, turn on heat to high, and if the thermostat responds at the correct temps then it's good. Otherwise it's bad. The values for initial open & full open are in the Helm service manual.
MonkeyBoy668 is offline   Reply With Quote
Old 01-23-2012, 09:10 AM   #18
CBL9
CBL9's Avatar
Fan came on immediately when I jumped the opening. I used some spare copper wire as paper clip wouldn't stay in the connector. So then I went to put the connector on and find that on the sensor itself it appears that the little "nubb" which the female end snaps on too is broken off....
So if the female connector that I just jumped is slipping off the sensor enough to not make contact would that describe my symptoms?
So I wired the sensor as tightly as I could together to hold it in place. I went for a test drive and the gauge came up almost all the way to normal operating temperature.
I then let the car idle for another twenty minutes. But the fan still did not come on. The heat in the car felt great btw.
So what should I do next? Would that thermostat sensor with a loose connection cause my symptoms? Anyone want to unplug theirs, drive around and see what happens???? And let me know
Thanks!!
-Tony
Old 01-23-2012, 11:16 AM   #19
motegicivic
Replace the fan switch on the thermostat, sounds like it might be broke or the tab is not making a connection with the harness.
Old 01-23-2012, 01:15 PM   #20
ekhatchc5
ct sends signal for amount of fuel for the right temp
ekhatchc5 is offline   Reply With Quote
Old 01-30-2012, 12:12 PM   #21
blackbirdoor
Icon6 Re: Engine Coolant Temp (ECT) sensor questions
hi guys, first time posting here. Lately, around the cold winter weather, i notice that my '96 accord v6 would be hard to start after sitting outside overnight, found out that it was the starter that was starting to fail. new starter put in couple days later, been functioning good for the past week and a half. this morning when i started my car, it sounded like it was trying to turn over, but couldn't turn over, only after a couple of tries did the car finally starts. I had to assist with the gas pedal a couple times to get it going, but it finally went. Then CEL comes on,code is p0118 (ECT high voltage, or loose circuitry issue), autozone diagnosed it as a possible engine coolant temperature sensor that might have gone bad. Im thinking, does that have anything to do with my car having a hard start in the morning ( or any time of day)? I searched around for the engine coolant temp sensor, autozone gave a picture of what it looks like, but i can't narrow it down to which area under the hood should i be looking at, is it on top of where the thermostat housing sit? or is it below the distributor area that i should be looking at? any pictures of the thing is appreciated Coolant is full (no leaks), replaced the thermostat around last june or so, temp gauge is slightly below middle mark, indicating that thermostat is opening/closing properly.
blackbirdoor is offline   Reply With Quote
Old 01-30-2012, 12:53 PM   #22
94EG8
Honda-Tech gave me this lousy title
94EG8's Avatar
This isn't the accord section, but yes a bad ECT can cause hard starting or a no start condition.
"Bacon tendercrisp chicken, the most powerful sandwich in its class."
Per ardua ad astra
My F/S thread -> http://hondamarketplace.com/showthread.php?t=2900962
Originally Posted by Knightsport View Post
Hello,
This is Knightsport, from the internet. I will be out of the internet from June 2 and returning on June 11th. In my absence I suggest you pray as there can be only one Knightsport from the internet.
Thank you and God Bless,
-Knightsport
94EG8 is offline   Reply With Quote
Old 01-30-2012, 06:46 PM   #23
blackbirdoor
ah, i do apologize, google search took me to this page i was reading into it so much i forget that its a different section from what i wanted, also any idea where its located under the hood? thank you again for the reply!
Old 05-11-2012, 05:01 PM   #24
spoolnpsi
Where is the coolant switch located on a 91 civic dx....It's not on the therm housing.
spoolnpsi is offline   Reply With Quote
Old 05-11-2012, 05:09 PM   #25
jbpnoman
1998 Honda Civic
jbpnoman's Avatar
DblDtchRddr
Send a message via AIM to jbpnoman
Maybe you should ask in the EF section. This is the EG/EJ section.
jbpnoman is online now   Reply With Quote
1995, 2000, 2002, 2006, 94, accord, civic, coolant, ect, engine, honda, lx, rsx, sensor, switch, tempature, temperature
