Steering Knuckle, Ball Joint, and Brake Removal Write-up with Pictures
Old 05-12-2009, 04:15 PM
slychicken37's Avatar
Default Steering Knuckle, Ball Joint, and Brake Removal Write-up with Pictures
For those who have searched for an good write-up with pictures for trying to service anything in the front end, I made this and it might help.
This should work for Brake Caliper/Rotor Removal, Ball Joint Service, Wheel Bearing Service.
Howeever I have been unable to upload it with anyluck. Does anyone have any suggestions on how I can upload this file?
Thanks,
-Slychicken37
Old 05-12-2009, 06:36 PM
BBallz24's Avatar
Default Re: Steering Knuckle, Ball Joint, and Brake Removal Write-up with Pictures
photobucket is what i use. some use flickr. There are quite a few options.
Old 05-12-2009, 07:29 PM
Heat's Avatar
Are you talking about a .pdf or a publisher file? Or just how to host pictures?
Old 05-12-2009, 09:07 PM
nus_dogg's Avatar
I also use photobucket as well. It's very useful.
Old 05-13-2009, 05:06 AM
H-T Order of Merit
TouringAccord's Avatar
with the switch over to vBulletin you can now attach bmp doc gif jpg pdf png psd txt and zip files to your post.
Below the main text box where you write your post and the submit button, you'll see some other options. One of the other options is "attach files". Click on the "manage attachments" button and another window will pop up allowing you to browse your computer for a file or enter a url of a file. This window also specifies things like max file size and max picture dimensions.
Old 05-13-2009, 06:38 AM
96CD5-tilshedies's Avatar
check your PM
Old 05-13-2009, 09:52 AM
What does "Check your PM" mean?
I am uploading a 20 page PDF file that is about 5mb total size. I have already posted all the pictures, put diagrams in, and wrote discriptions within that PDF so would like to use it.
Keep the help coming.
Thanks,
-Slychicken37
Old 08-25-2009, 01:17 AM
RevengeAtLast's Avatar
thanks for getting my hopes up
Old 08-25-2009, 04:46 AM
jdmwannabee's Avatar
my sentiments exactly.
Old 08-25-2009, 06:18 AM
CDdubz5's Avatar
Originally Posted by 96CD5-tilshedies
check your PM
"PM" means personal message...basicly check your honda tech mail.
wish i could help with the upload but im a noob too.
could you put it in an email and then use the little email linky when typing a reply message?
Old 08-28-2009, 05:27 AM
See attached link for a Google Doc's version of this that should allow you to download.
Let me know if it doesnt work.
http://docs.google.com/fileview?id=0...MGRhMDU1&hl=en
Thanks,
-Rex Buchanan
Old 08-28-2009, 05:35 AM
good write up
Old 10-28-2009, 03:18 PM
shortlid's Avatar
Icon2 Re: Steering Knuckle, Ball Joint, and Brake Removal Write-up with Pictures
Is this in FAQ yet, I need to replace the front wheels bearing. Trying to decide if I should do front struts at the same time since got 158,000 mile son the car!
Old 10-28-2009, 03:21 PM
redbull-1's Avatar
Thanks,
-Rex Buchanan
His pdfs are in the link.
Old 10-28-2009, 05:30 PM
H-T Order of Merit
slychicken37, just a FYI... the 1998-2002 Accord is the 6th Generation, not the 5th Generation.
I've also added a link to this thread in the FAQ
Old 10-29-2009, 07:30 PM
shortlid's Avatar
Will I need a spring compressor to take the knuckle out? Or just if I want to take a struts out?
Old 12-01-2009, 01:49 PM
shortlid's Avatar
Can't really use the Honda hub puller on our cars either. Cause the bearing is a seperate from the hub replacment needs to be pressed into both the knuckle AND the hub!!
Old 01-12-2010, 06:39 AM
shortlid's Avatar
OK, got knucle out of my '99 EX sedan 5-speed only think that will not come loose is the ABS wheel speed sensor. Took bolt out of the back of the sensor and still will not budge any other tricks guys!!. HELP!!!
Old 01-13-2010, 07:23 PM
You should be able to "convince" the ABS sensor to come out of its socket. I used a large flat head screw driver and leveraged it out. Make sure to try and not damage the sensor though, but I found it to be stronger that imagined.
Worst case use a little PB blaster and let it sit for a while.
Hope this helps
Old 01-14-2010, 01:03 PM
shortlid's Avatar
I just ended up disconnecting in the engine bay at the connector. The back fedd all teh grommets and wire bridges on out!! My Honda repair guy said they are easier to do that way.
Old 01-19-2010, 12:42 PM
shortlid's Avatar
You can buy just the boots for the upper and lower ball joint from the stealership. Both joints were ok, just ripped boots with pickle fork I unfortunely used to seperate. Replaced the C-clips that held the grease boots in place with safety wires cause stealerwanted $8 per for stupid C-clips. Refilled with freash grease fron gun with needle adapter.
Old 01-20-2010, 06:24 AM
ken9's Avatar
Where are the photo???
uberEFtuner
10-08-2009 06:13 PM
JerryMann
06-14-2008 08:17 AM
stevescivic
Honda Civic (2001 - 2005)
04-21-2007 10:54 PM
flyinga
10-30-2004 08:14 AM
shorty0o29
02-25-2004 08:37 AM
Quick Reply: Steering Knuckle, Ball Joint, and Brake Removal Write-up with Pictures
