Main Relay Kill
Main Relay Kill
Honda Civic EX '98
I'm getting ready to install a main relay kill layer to my car alarm. I plan to have the alarm control this kill; I know I'll forget to activate a hidden switch just once and presto car stolen. I know what wire to splice, the black ground wire. Does it matter which way the relay faces? Does it matter which end of the black ground wire goes into 87a or 30? Thanks.
I borrowed the picture from the Cause For Alarm website.
http://causeforalarm.thecarthing.com...kill_relay.gif
The picture is for a fuel kill but I am taking the logic for the main relay.
This is what I have thus far:
85 - Alarms ground when armed
86 & 30 - connected
30 - main relay ground wire
87a - main relay ground wire
86 & 30 - connected
Old Fart
Re: Main Relay Kill
That will not work, you have a ground at both #85 and #86.
If your are going to use the alarm to control the PGM-FI Main Relay kill you will need to wire it like this...
#30 - to chassis ground.
#87a- to black ground lead of PGM-FI Main Relay.
#85 - to alarms GWA output, [probably orange lead].
#86 - to "true" ign. source, [hot in run and start].
And if you really want to make noise if someone tries starting the car with the alarm armed, connect #87 to cars horn lead. 94
Re: Main Relay Kill
Old Fart
Re: Main Relay Kill
The relay is not on the PGM-FI Main Relay ground, it is on the fuel pump power lead, #30 and #86 would have 12V+ when ign. is on and engine running and during priming.
The above kills only the fuel pump power, easily bypassed.
Installing a "kill" relay on the PGM-FI Main Relay ground will cut power to the fuel pump, fuel injectors, ECU and a few engine sensor/valves. 94
Re: Main Relay Kill
I should have worded my question better. I know the picture I posted was for a fuel pump kill. What I would like to know is why the fuel pump kill is wired differently than the main relay. I think I have the basics but I am looking for a better explanation that what I can give. Here's my take, I think they are different because on the fuel pump the kill relay is affecting the power to the pump and on the main relay and kill relay is affecting the ground.
Thanks for the info. I'm wiring up the main relay kill now.
Old Fart
Re: Main Relay Kill
The power for the relays coil must by a switched 12V+, either hot in run and start, [true ign.] or hot in start, [starter]. 94
Re: Main Relay Kill
I have 2 questions:
1) Would you put a diode in between #86 and #85 with the band toward #86?
2) Could I use an Aux to shut off the ground to the main relay by connecting the Aux #85 instead of the orange GWA? I have a Crime Guard 750i6 with feature 23 open with programmable relay built in. How would you wire it? The pages to the manual is below.
Here's SuspendedHatch Main relay kill link http://civic-eg.com/causeforalarm/ma...kill/index.php
Thanks.
Location: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Re: Main Relay Kill
Wow this thread is old. Bad dude i been watching your post. And if seems that you ask a question and then answer it with a link. Maybe you should take the car somewere and let someone that knows what there doing. Cause you can really mess up your car electrical system. And open up a big can of worms
Re: Main Relay Kill
I got the car wires all map out ready for the install. I just want some new fresh ideas with the alarm rather than just some thing that make noise and a starter kill.
I was just wondering of using feature 23 to do the main relay kill when activate the channel. I was trying to see if I can connect the Aux to 87 or 87a to perform this feature?
Thanks.
Re: Main Relay Kill
so you lose your remote while out or it falls off your key chain. You then get in the car thru the valet button. Now the car does not start cause you cant use a aux cause you have no remote. Or the remkte break or fails. Keep things simple.
Re: Main Relay Kill
Thanks.
Re: Main Relay Kill
Thanks. You have a point. What about if I kill the main relay instead of the starter with alarm when trigger?
Thanks.
Thanks.
You're already up to three kill relays and five sensors from the looks of your other posts. This will overtax the GWA line and you'll now need yet another relay to provide a higher current ground for all the accessories.
The GWA is usually limited to .5A, and each standard Bosch-type relay consumes roughly 175ma. When you add just a radar sensor into the mix you're right at the limit of of the GWA can handle.
Re: Main Relay Kill
That works fine too, but I agree with advice to keep it simple.
As far as tapping into the car wiring, I got both dome and door triggers to one wire; trunk and hood to one wire with diodes isolate band away from brain; I got parking lights to one wire, power I am going run a cable straight from the battery splice it to the brain then further down put the windows modules on it later; door lock and unlock, one plug 2 wires, I am leaving priority unlock off for now since I got to run wires to the door; Ignition power.
That's it simple. Like every thing else when I work on the car is the time to organize the cables for clean looks and convenient of service or addons later.
I ask a lot of questions, first to learn more, to see what I can play with.
Thanks for all of the help and advice guys. Since I am unemployed still, I just want to make use of my time to learn stuffs as I know I will get a job any time and I will never have time to do any thing after that. Just like for 4 years, I got expensive parts waiting in my storage for installation. Boom, unemployed, a little more time but no money. So I sold all of the parts just to survive. Never the less, I am still happy as I am still better off than a lot of other unfortunate people, so I am not going to die complaining.
Re: Main Relay Kill
I'm redoing some alarm wires because of a recent theft attempt. I redid the main relay kill and figured I'd try the #87 to the horn lead. I connected 87 to the gray wire on the 16-pin harness behind the radio (1998 Honda Civic EX) but the horn didn't sound. Am I missing something else? The relay is wired as directed from your original post.
Re: Main Relay Kill
What are you trying to do?
Re: Main Relay Kill
The downside of of active kills is they require the alarm be operational for them to work.
There are many ways to "take out" an alarm no matter how well hidden you "THINK" it is.
Take out the alarm the kill goes away and you can now start the car.
Passive kills work wether the alarm is connected or not. In other words the alarm needs to functioning for the car to start. The downside is if something goes wrong with the alarm or the relay goes bad your car is stuck.
You have to decide which you want and what your willing to put up with.
Re: Main Relay Kill
OK you’re going to have a fire! 87 is normally open side of this relay, meaning that it will connect with 30 when the switch is activated. What is "main"? I'm assuming that you are cutting fuel supply relays ground. This would mean that when the system is armed that your horn trigger relay would be connected to the fuel pump ground output?
I'm trying to accomplish what FCM suggested.
Re: Main Relay Kill
Most alarm systems come with a horn output that can be used for this purpose during a full trigger. If it dosn't then you can put a light flasher on the siren output. Besides, this would only function if someone turned on the ignition. You want it to draw attention to your car during a break in.
At the end of the day if someone wants to steal your car, all they have to do is call a tow truck and tow it away to where ever they want so don’t try and re-invent the car alarm. You will regret it when the system fails and its pouring down rain outside.
Re: Main Relay Kill
Cutting the fuel supply is just not a good idea. There is a reason why all alarm manufactures give you a starter kill relay with the box. It’s safe. If the relay were to ever fail while driving, you would lose power everything, brakes, steering and engine. Think if you are driving down the highway at a high speed when that happened.
It all goes back to the point that I made. If someone is going to steal it, they can. Make your car obnoxious and loud if the car is broken into. If the thief is going to tear out the ignition then they are going to pull the plastic knee panel down and defeat the security system.
If you want a badass starter disable then add the starter kill relay under the hood next to the starter and install the brain under the glove box and add a backup battery to keep the relay engaged.
Re: Main Relay Kill
Cutting the Main-Relay and/or ECU is the best kill for a Honda in my opinion.
I get what you're saying though, if someone wants the car they are just going to tow it but for maybe 75% of the people that are going to break into a Honda they won't have a tow truck so making the car not start is primary. A tow truck is really for vehicles that are left outside over night, my vehicle stays in the garage. I'm primarily concerned about protecting the car when I'm out at dinner or a movie. A thief is unlikely, though its possible, to roll-up to a restaurant or movie theater with a tow truck and steal my car. A starter kill can be bypassed regardless of where its installed. A Main-Relay and ECU kill can't be easily bypassed if hidden ect. If my car is left unattended for a few hours my primary goal is to make it impossible for a thief to drive away.
I've had the Main-Relay kill installed for over four years with no issues. I was just trying to test FCM's suggestion about adding the horn to pin 87.
Re: Main Relay Kill
Unfortunately judging any security on the fact your car hasn't been stolen is a worthless game.
Don't get me wrong I fully support making it as difficult as possible. I however would not depend on a single kill to protect yourself. A main relay is a single kill contrary to the claims made on this site. If you're a 1/2 intelligent theif you could bypass this kill with two jumper wires no matter where you hide the relay. I suspect as this becomes more popular and cars start getting stolen people will catch on.
Protect yourself with multiple layers of security. The same rules that always existed still exist The install is 90% of the security.
Re: Main Relay Kill
That's a myth. I could bypass it easily.
Has someone tried to actually steal your car? not just break in.
Protect yourself with multiple layers of security. The install is 90% of the security.
*sigh*
This is the problem with this forum, and many others, people come in and give their opinions without actually addressing the question(s) asked.
I get what you are saying, and agree, but based on the text you decided to quote from my previous post you didn't actually address what I posted.
I was commenting on Bjude1 earlier post, regarding the main relay kill being safe/dependable or not. As I stated, I've had it installed for years with zero issues; zero issues meaning the kill has not left me stranded because it failed. Also, I would rather be stranded one day in the pouring rain versus having sub-par security.
I appreciate a good opinion as well as the next guy but no one has actually answer the question at hand, or even attempted to answer the question.
I have multiple layers of security. As I stated in my post, someone attempted to steal the car but they failed; they made a mess of the wires in the progress, which is why I was going through re-doing everything.
Yes, it is possible to find and disable the main-relay kill, or any other kill, but I'm pretty sure everyone is aware that there isn't one magic kill; so this isn't news to anyone.
EDIT
I take part of my statement back. I see you did comment directly on something I said. I said the main relay can't be easily bypassed to which you responded.
I don't have the main relay out in the open with a big neon sign pointing to it saying "HERE I AM." But yes, if a thief has the time they can dig and find its location. Again, the point is to slow a thief down and make as much noise as possible; hence my original question about adding the cars horn wire to pin 87 of the main relay kill relay.
Re: Main Relay Kill
Re: Main Relay Kill
*sigh*I was commenting on Bjude1 earlier post, regarding the main relay kill being safe/dependable or not. As I stated, I've had it installed for years with zero issues; zero issues meaning the kill has not left me stranded because it failed. Also, I would rather be stranded one day in the pouring rain versus having sub-par security.
It's good you have other kills that is the way it should be.
I don't know what the question is you had. It seems to me you already had your question answered.
jdm_rb20
16
05-02-2013 09:16 PM
HiProfile
Audio / Security / Video
08-27-2009 10:06 AM
