Squeaky noise coming from under the dash
Old 04-12-2009, 07:39 PM
hotwater's Avatar
Default Squeaky noise coming from under the dash
Sup HT ! I recently acquired a problem with my teg. It seems whenever i turn the steering wheel while i'm driving there's somewhat of a low pitched squeak coming from under the dash. I'm not even sure whether its coming from the suspension or the steering column, but I can feel a tiny vibration on the steering wheel when the squeak occurs. It also sounds like the steering column makes a clicking noise whenever I go for a U-turn. It starting happening after I switched wheels with my dad and got an alignment. Answers would greatly be appreciated!!!
Thanks,
John
Old 04-12-2009, 08:06 PM
teggything's Avatar
Default Re: Squeaky noise coming from under the dash
clicking could be the axels as for the whining worst case scenario its ur rack have some one check it out or take it to a shop and have them shake it down
Old 04-12-2009, 10:08 PM
hotwater's Avatar
mmm.. ic ic.. thanks for your help ... how serious is axle problem? easy fix hard fix? lmk man i'm still new to this...
Old 04-13-2009, 11:27 PM
hotwater's Avatar
anyone else?
Old 04-14-2009, 06:45 AM
TegraD's Avatar
axels are cake... you just need a 17 socket , socect wrench for the bottom of the spindle set up and a 19 socket to take off the axel nut then bam, flat head screw driver to pry it out enuf to grad it... then you just replace it...
Old 04-14-2009, 10:39 AM
baller status's Avatar
Power steering belt is loose and your axles are bad.
crxbrad
01-31-2014 05:36 PM
transitions
Honda Civic (2006 - 2015)
10-04-2011 06:43 PM
Simmerman
09-22-2007 06:03 PM
B16Civic93
12-21-2004 08:23 AM
ice11honda
09-02-2004 12:45 PM
Quick Reply: Squeaky noise coming from under the dash
