B16 Tranny and Oil Capacities please
Old 03-04-2009, 01:36 PM
Rok_Stok's Avatar
Default B16 Tranny and Oil Capacities please
I need the manual transmission (transaxle if you want to get technical) capacity for a B16A, S4C in particular.
I need the oil capacity for a B16A. I've heard 4 quarts, I've heard 5, which is it?
This is all I need, thanks.
Old 03-04-2009, 01:40 PM
Mashimaro's Avatar
Default Re: B16 Tranny and Oil Capacities please
hey dood,
i think it should be 3.5-4 litres of oil for the motor (check the dipstick after 3.5 is poured in).
the tranny fluid should be about 2-3 bottles. fill it till it starts to come out of the hole
Old 03-04-2009, 01:44 PM
EL Vap133's Avatar
Originally Posted by Mashimaro
hey dood,
Litres? Oh wait, I just saw that you're Canadian.
Here in the US it is about 3.5-3.9 Quarts. I usually pour 3.5 and then wait a while before I check the oil level to see if it needs more.
Old 03-04-2009, 02:21 PM
Rok_Stok's Avatar
Thanks guys. I primarily wanted to know the tranny capacity to know if I should buy 2 or 3 quarts, sounds like 3.
Old 03-04-2009, 02:47 PM
SinsEvil666's Avatar
yea, buy 3. it takes about 2.5
Old 03-04-2009, 02:51 PM
trustdestruction's Avatar
(US quarts)
engine oil:
engine overhaul capacity - 5.1 quarts
oil change with filter - 4.2 quarts
oil change w/o filter - 3.9 quarts
transmission:
overhaul - 2.4 quarts
drain/refill - 2.3 quarts
EDIT: fixed the tranny capacity, thanks jdm602
Old 03-04-2009, 02:54 PM
Rok_Stok's Avatar
Where did you find the info on 2 quarts for the tranny?
Old 03-04-2009, 02:55 PM
factory service manual
it's definitely believable... i know that a D-series manual tranny is also 1.9 quarts for drain/refill.
Old 03-04-2009, 02:59 PM
Mashimaro's Avatar
i used to work at an Acura stealership
Old 03-04-2009, 03:00 PM
jdm602's Avatar
tranny is actually 2.3 us qts. per oil change. 2.4 for overhaul.
Old 03-04-2009, 03:02 PM
correct
sorry about that... i was reading the D-series tranny stuff on accident.
my engine oil info is correct though.
Old 03-04-2009, 03:53 PM
Rok_Stok's Avatar
Alright, 2.3 qts. Thanks.
Quick question: Do I use the D16 power steering pump on the B16?
Old 10-09-2009, 03:26 AM
Dramysx's Avatar
I don't know if that will bolt up. You can try it though.
Old 07-23-2010, 01:17 PM
96 civic hatch's Avatar
hi, how many quarts to fill a b16 automatic tranny? i just bought this b16a2 automatic swap and need to fill the tranny up. thanks
peep
Transmission & Drivetrain
05-10-2009 11:46 PM
DC4R27
03-14-2007 07:23 PM
kixcrx
21
12-29-2006 04:38 PM
gsxr
08-21-2002 03:53 AM
Quick Reply: B16 Tranny and Oil Capacities please
