f20c swap in civic ej9
Old 02-20-2009, 10:46 AM
dadozh22's Avatar
Default f20c swap in civic ej9
hi,this is a first swap in italy...
Old 02-20-2009, 10:53 AM
dadozh22's Avatar
Default Re: f20c swap in civic ej9
SEE YOU LATER!!!
Old 02-20-2009, 01:17 PM
voodooo's Avatar
my little civic
video for this forum
Old 02-20-2009, 01:18 PM
hondatec1's Avatar
what transmission? K
Old 02-20-2009, 01:41 PM
hybridpatient95's Avatar
yaa its f2k
what clutch flywheel and starter did you use?
Old 02-20-2009, 02:29 PM
gibsanez's Avatar
What advantage does the F20C have over the K series that makes this swap practical?
Old 02-20-2009, 03:48 PM
I'm really 2slow
2fast4u831's Avatar
I think its the advantage of being able to run bigger cams and having better flowing head along with a stronger bottom end. someone quote me.
Old 02-20-2009, 04:08 PM
k24ej8's Avatar
you could turbo the **** out of a bone stock motor.. these motors love boost
Old 02-20-2009, 10:32 PM
dadozh22's Avatar
i've in mind this swap because nothing k24...in italy...
trasmission is k series
the big problem is the motor mouth...but ....
Old 02-20-2009, 10:37 PM
voodooo's Avatar
sorry for my english is terrible...
f20c2 engine
k20a2 trasmition with jdm lsd
flywell f20c
pressure plate is k20a2
disk is f20c
relase bearing is b18c6 :asd
the engine mounth is innovative k20 swap in ek chassy
and i have designet more parts
http://www.youtube.com/watch?v=JqcqDgBHjSg
Old 02-20-2009, 10:38 PM
dadozh22's Avatar
sorry...love n.a.
Old 02-21-2009, 07:12 AM
King of the One Liners
2fastGSR's Avatar
Thats awesome. .
I like the passenger side motor mount . .
My F2K should be finished soon as well, great to see some more ingenuity out there!
These motors love boost and can make 700+ on a stock motor, but don't worry they are great for NA as well . .
Old 02-21-2009, 08:35 AM
dadozh22's Avatar
thanks,man
Old 02-21-2009, 09:33 AM
voodooo's Avatar
first start!!!!!
http://s3.photobucket.com/albums/y70...1022009002.flv
Old 02-21-2009, 02:05 PM
CronoCiccio's Avatar
and however i would to add that it's a uncommon swap in Italy, so in Europe
Old 02-21-2009, 11:38 PM
voodooo's Avatar
http://www.youtube.com/watch?v=FUXzJx7DvSM
Old 02-22-2009, 02:37 PM
88ED8's Avatar
lookin good!!!
Old 02-22-2009, 10:18 PM
voodooo's Avatar
tnx :D
Old 02-24-2009, 05:56 AM
f@sth@tch89's Avatar
Are there any modifications that need to be done to the mounts? k-series tranny bolt right up or any mods needed?
Old 02-24-2009, 06:26 AM
2fastGSR's Avatar
What did you do to the header? Is it just a regular K series header with an F20 Flange?
Is everything after the flange the same length as a K series swap ?
Old 02-24-2009, 06:56 AM
k24ej8's Avatar
mine is goin together todayy with k24 crank ...
Old 02-24-2009, 11:47 AM
dadozh22's Avatar
yes,heater for k20 with f20 flange!!
Old 02-24-2009, 11:53 AM
dadozh22's Avatar
it must pierce the motor support of the skillful change, so that it can slide!
Old 02-24-2009, 11:59 AM
sciamutanna's Avatar
Nooo!!!!!!
Ragà ma ndò ca@@o ve devo beccà
Dà, enrì, sono Claudio, vtec_inside...
Old 02-24-2009, 12:00 PM
voodooo's Avatar
all the history
this summer i have see this dream
December arrive to my house
clean
in and out
good work !!
i have use the f20c flywheel, and k20a2 pressure plate, the flywhell as modificated
3) the engine mouth INNOVATIVE http://www.innovativemounts.com/ buy over www.swapshopracing.com
Quick Reply: f20c swap in civic ej9
