B20z2/VTEC Build !
Old 02-03-2009, 08:28 AM
jdm_sir2's Avatar
Default B20z2/VTEC Build !
Hey guess well I just got a smoking deal on a 98 CRV B20z2 Block $150. I'm currently shopping for parts and having the machine shop prep the block and crank. My goal is to hit 210 + whp.
Block:
98 B20z2 Decked,Honed,Hot tanked
Balanced and Micropolished B20 Crank
Stock B20z2 Rods with YCP ITR Spec Pistons 84mm (11.9:1 CR)
ACL Bearing
ARP Studs all around
Type R Oil Pump
Type R Water Pump
B20 Crank Pulley
Head:
'99 Civic SI B16A2 Head Stock for the meantime
Stock Cams
Blox Cam Gears
Hondata Intake Manifold gasket
Blox Racing 66mm TB ( Not Installed need TPS )
Precision 440cc injectors
Walbro Fuel Pump
B&M Fuel Pressure Regulator
Integra GSR Megan Header
OmniPower Test Pipe
Apexi WS2 Exhaust
Chipped P28 ECU / Hondata S200
Tranny:
00 B16A2 Tranny
ITR flywheel
Exedy Clutch Kit
I'll try to post pics of the build when ever I get a chance right now i have the block and crank in the machine shop getting worked on so hopefully i can get some pics? Hoping to hit 13's on a 96 Civic Ex Coupe.
What do you guys think?
Update some pics what the motor look like for now....
Old 02-03-2009, 09:16 AM
b20vtech's Avatar
Default Re: B20z2/VTEC Build !
nice 2.0 vtec set-up what else can we say?
Old 02-03-2009, 09:51 AM
jdm_sir2's Avatar
I'm just hoping to break into mid to low 13's...well so far i got a deal on the tranny for $350 and the GSR head $400! picking them up this week!
Old 02-03-2009, 10:04 AM
CUTTERSPOOL's Avatar
Keep us posted. I'm still debating on a lsvtec or a b20vtec myself. So many options!
Old 02-03-2009, 11:01 AM
jdm_sir2's Avatar
Went to the machine shop to see what was going on the crank is done and he said the block should be done by friday! I'm getting everything done for $200. The crank and rods are well withing specs so i'll be order standard size bearing woohoo!
Old 02-03-2009, 01:13 PM
jdm_sir2's Avatar
I need help though on how do you guys run the pcv valve system with the B20 engine blocks?
Old 02-04-2009, 06:48 AM
jdm_sir2's Avatar
Anyone running a B20 Vtec whats ur pcv valve set up also i was looking around and every where it says that the B20z2 came on the 99+ Crv's but mine is stamped 98.
Old 02-11-2009, 03:15 PM
jdm_sir2's Avatar
Updates! Got the block back from the machine shop had the block decked so it would be straight for the head. The machine shop took off .007 thousandth of an inch looks better and give me a piece of mind. Haven't had a chance to work on it much since i'm work every single day. Going to pick up an engine stand from work and set up the block so I can clean it and prep it to spray it down with some aluminum paint and work on the honing. Still waiting on parts to come in this week. Ordered some ACL bearing standard size i'll be platiguaging the clearances to see if they're right within specs. Also waiting on my YCP ITR Spec pistons so i can send them to the machine shop to get the wrist pin pressed into the B20Z rods. ARP main bolts and rod bolts also coming in sometime this week and OEM Honda gsr water pump/tensioner/oil pump just to get a few things so i can get started assembling. Still trying to source a head and tranny. The guy with the tranny flaked on me so I have to find one elsewhere.
Old 02-13-2009, 03:01 PM
jdm_sir2's Avatar
I guess I got me an early Valentines gift!!
Old 02-13-2009, 04:09 PM
mar778c's Avatar
If you have a b16 header it may not fit on your B20 block. If I were you I would check that before you get to the end of your build.
Old 04-28-2009, 06:13 PM
jdm_sir2's Avatar
Bump posted up some pics of the progress!! Waiting on some parts to arrive! What do you guys thing of my DIY J's Racing Style Valve Cover!! Bling bling!
Old 08-06-2009, 06:17 AM
jdm_sir2's Avatar
Well finally dropped in the motor on saturday fired up first try, everything physically is good no oil leaks good oil pressure no check engine light. The only thing i'm having trouble with is getting the timing correct. I drove the car around the block and it's just really boggish from a take off from a dead stop once i get to 2.5k rpm it feels really strong from there on up. I used the timing light to get the timing set and right now on the distributor i'm fully advanced all the way and i'm pretty sure by the ways its acting that my timing is still retarded. Any suggestions?
Old 08-06-2009, 06:21 AM
1.5Slowmatic's Avatar
Timing belt slip a tooth?
Old 08-06-2009, 07:04 AM
jdm_sir2's Avatar
yeah i'm going to check that out today see what the deal is probably take the timing belt align everything all over again than put it together and give it another try. Any one else? another thing is that it's runs a bit hotter just over the half way mark right before the fan kicks in than it drop back down.
Old 08-06-2009, 09:52 AM
Broken Gearbox's Avatar
Where did you get your machine work done?
Old 08-06-2009, 12:17 PM
baggelis's Avatar
Does anybody know what is the stock fuel pressure setting on a Honda and also what is the stock injector flow rate for a stock GSR setup?
I am doing the same build but with a GSR head instead of a B16... and want to know what are the limits of the stock fuel system so I can calculate if I need aftermarket setup...
Looking good by the way...
Thanks...
Old 08-06-2009, 09:13 PM
jdm_sir2's Avatar
Finally got the timing right after taking off the timing belt and pulley off for more than 6 hours the car runs....i'm definately going to upgrade to different cam gears stupid blox cam gears...the timing marks are off by a whole tooth! So finally have it running now i'm just breaking it in before I go get it tuned. Car is definately a night and day difference from a basic b-series swap....this motor is a beast! Power all over the rpm range....
Old 08-07-2009, 10:34 PM
rare92gsr's Avatar
so i am assuming the bottom-end is not fully balanced with the rotating assembly i.e. pistons, rods, flywheel, pressure plate and crank pulley. correct me if i m wrong.
Old 08-07-2009, 10:57 PM
DustinRose's Avatar
I have a similar set up, let me know what kind of numbers you get after you go to the dyno.
Mine has been running kinda hot too, need to figure out why...hits 210 once in a while on long highway drives
183 whp, 142 tq
1990 Civic Hatch
B20Z2
Endyn Breather Kit
11.7:1 RS Machines
68mm TB, Blox Manifold, Hondata Heat Shield Gasket
Password JDM Whale ***** CAI
DC 4-1
B16A Head Stock (PR3) decked, cleaned, new LMA's and seals etc...
440cc dsm injectors
skunk 2 gears
S300 ecu
Tanabe Medallion Touring Exhaust, Magnaflow Cat (costed me some power on the dyno, but the car is pretty quiet and not smelly)
and all the necessary LSVTEC stuff on bam bam's list, went with the golden eagle stuff
PS make sure you get a bottom timing cover before you get tuned, so they can set your timing with a timing light, my cover was missing at the time
so they were scared to make my timing too aggressive. they had to set it up a little more conservatively
Old 08-08-2009, 08:33 AM
jdm_sir2's Avatar
183 whp, 142 tq
1990 Civic Hatch
B20Z2
Endyn Breather Kit
11.7:1 RS Machines
DC 4-1
440cc dsm injectors
skunk 2 gears
S300 ecu
Nice numbers man i bet with a little more tuning they can probably make ur torque curve much more flatter... Well it's been running really good. I actually do have the bottom timing cover on I have the timing set at 16degrees BTDC took me forever to finally get it set due to the problem i had with the blox cam gears...I just need to installed my catch can noticed that the car shoots a puff of smoke when i let it decelerate in gear and feather the gas it make a puff come out so i'm sure by adding a catch can running from the fitting in the back of the block should fix that problem. I think also i thinks the puff of smoke is much more visible since i'm running an testpipe. Im really driving the car to a bare minimum cuz i really need to get it tuned cuz it's running pretty rich...
Old 08-08-2009, 01:31 PM
DustinRose's Avatar
ahh when i first got to the dyno i was running really lean
i used a b18c5 map to drive it there
i havent bought a wideband yet, once on the dyno it was running super lean
almost 18:1
we spent almost three hours tuning
the car is pretty fun to drive, i have a jdm y1 tranny
the first 4 gears are pretty low, 1st is almost too low
this car NEEDS a traction bar, the wheels want to hop a lot
there are so many things that could be updated that i just dont have the money to buy
Old 08-09-2009, 11:36 AM
jdm_sir2's Avatar
I had a question I just finished putting 200 miles on my fresh motor and i'm about to do the next oil change on it but is it normal for the oil to become dark after only 200 miles on a freshly built motor? I mean isn't doesnt look even look golden brown!
Old 08-11-2009, 05:42 PM
DustinRose's Avatar
your oil should stay clean looking for quite some time
i have put 1200 miles on mine and the oil is still clean when i check it at the dip stick
changed it at 500
it should be kinda dirty looking when you drain it
Old 08-11-2009, 05:49 PM
mrgar's Avatar
blowby my friend! its contaminating the oil.
rehone and rering.
Old 08-11-2009, 08:46 PM
jdm_sir2's Avatar
rehone and rering.
Dude thats too extreme...i'm going to change my oil again tomorrow and put atleast 200miles and see what it looks like again....but I spoke to 2 different engine builders and they said it's normal...so i'll see what happens after this next new oil....started taking the motor higher on the rpms and it really moves after 3.5k rpm to 6.5k rpm specially with the JDM B16 tranny
Quick Reply: B20z2/VTEC Build !
