B20Vtec Basic Allmotor Build *Australia 12.9@108mph *4/2/09
B20Vtec Basic Allmotor Build * Update Circuit Results (Class Wins)
Hi guys,
I thought i may as well share our all motor build for the upcoming race session in Australia. Since running B16a last year for the racing session, the team has opted for a bigger engine to replace the B16a.
We are now running a B20vtec which has been built from top to bottom end. The plan is to keep the engine simple and maximise power output
Here is a quick run down of what it comprised of:
PR3 Head
Stock ITR Ports
Supertech valve train
Fully Serviced
CNC combustion cambers (Still under R&D)
Rocket M22x Cams
11.3:1 Compression
Bottom End
RS Machine 84.5mm pistons
H-beam Forged Rods
Fully balanced bottom end
Bolt-ons
TWM 50mm ITB's
Budget Big tube 4-2-1 headers
2.5inch exhaust system
E85 Fuel
Hondata S200
At the current moment, the car was tuned on Friday night producing 148.2kw ATW (199hp)(dynodynamics). The engine was run-in on the dyno and tune conservatively.
Here is the dyno sheet
There is more to come for this motor. With new set of header (SSR street sweepers) and new standalone ECU (Vipec) the team is hoping for over 155kws at the wheels (dynodynamics)
Stay tuned for further results
Note
Engine Built, devloped and Tuned By Uncle Dave
Thanks to Rocket for the great cams and valve seat angles
Update 4/2/09
Car went to the drag for a quick engine shakedown. Car was in circuit trim, running -ve 3 camber and circuit semi slicks. Car weigh in at 937kg without driver.
Car ran consistent 12.9@108mph all night long.
Here are some clips from the other night
http://www.youtube.com/watch?v=Dy2uD...e=channel_page
http://www.youtube.com/watch?v=MCobX...e=channel_page
PR3 Head
Stock ITR Ports
Fully Serviced
Rocket M22x Cams
11.3:1 Compression
Bottom End
H-beam Forged Rods
Bolt-ons
TWM 50mm ITB's
E85 Fuel
Hondata S200
Note
Update 4/2/09
Re: B20Vtec Basic Allmotor Build *Australia
why tune on e85 with the compression so low?
maybe it cheaper than gas over their?
also nice torque
also nice torque
Engine will be back on the dyno tonight I want to try pump fuel and the new Vi-PEC V88 ECU.
Regards Uncle Dave
Regards Uncle Dave
Regards Uncle Dave
After doing some very expensive mods we lost 9hp on the dyno so the rest of the tuning was only restricted to trying to tune around the mods and we did not get a chance to test the new ECU or the pump fuel.Anyway the car is in this thread when it was running our B16a engine if anyone is interested in what the car looks like
https://honda-tech.com/forums/showth...802&highlight=
Regards Uncle Dave
Regards Uncle Dave
Im waiting for at least 10kw atw out of this with the vipec after the d series results you had.
Shame those SSR headers were way to small, wouldnt think so with your comp, cam and stock ports.
very nice car. thumbs up!
so you lost power from adding a std size header over the budjet big tube?
update...
Took the setup out to the 1/4mile. We were chasing MPH so car wasnt setup for drags. Ran on circuit R compounds, with circuit wheel alignment car achieved 12.903@108.5MPH 2.0x 60ft.
Regards Uncle Dave
I was more referring to the claimed difference of the Vipec tuned D series motor that was running a hondata, unless it wasnt tuned that well to begin with, i just dont know where 10kw was going to come from between them.
I like the pat on the back for yourself in the 2nd post, too funny! lol!
Regards Uncle Dave
Here are some clips
12.9 pass
Bseries vs Kseries
12.9 pass
Bseries vs Kseries
Re: B20Vtec Basic Allmotor Build *Australia 12.9@108mph *4/2/09
Setup was back on the dyno today looking for a bit more power and to redo our header tests just to confirm our first results and it did all tests where within 1hp of the other day.
Regards Uncle Dave
Regards Uncle Dave
After a few weeks of testing we fitted a set of 1000cc Injector Dynamic's injectors into our engine for testing and yes we know they are to big for this setup but I wanted to show everyone how damn good they really are we picked up 5-6hp from 3000 to 9000rpm and making the same peak power as before and this was done using the S200 Hondata.We have now fitted the Vi-PEC ECU and found a few small problems with the TWM's I will fix them up early next week and finish the tune off and then retune the S200 so its a fair comparision.
Regards Uncle Dave
Regards Uncle Dave
