EG Shell Project...
Old 01-27-2010, 05:39 PM
  #251
boarding2008's Avatar
Default Re: EG Shell Project...
QFT carfreak. When I bought this shell and started this build I just graduated HS, was working a full time job while I took a semester off(which turned into a full year but whatever) and couldn't understand the whole I'm a broke student line. I deff see it now haha. I have to save weeks for a part instead of getting a few things every week or two. I'm still sticking to my original plans even tho its gonna take a little longer.
JdmBones I think u must not have read all the way thru lol. The original owner wanted to do a b series swap but was undecided. I'm doing a Z6 turbo build.
Old 01-29-2010, 07:50 PM
  #252
not much of an update but im bored and my dad brought me my parts home...
cap n rotor, oil pump, and plugs n wires.
Old 02-16-2010, 11:35 AM
  #253
fv8s's Avatar
wahhh
Old 03-05-2010, 11:51 AM
  #254
Small update- I bought a clutch, timing belt, tensioner, spring, water pump, water pump pipe with orings (mine was rusty), oil filter adapter, altenator, starter, lower timing belt cover and some random bolts that I needed. Ill post pics once the stuff comes in.
Old 03-09-2010, 05:46 PM
  #255
my dad brought home my altenator, starter, water pump, timing belt, tensionor, spring, water pipe o-rings, oil, and oil filter. didnt take pictures but i picked up my driveshaft shop axles
then i came home tonight after class/working out and this was sitting in my living room
it kinda felt like xmas lol. i opened the oil filter adapter up first
then the box from majestic honda
and finally my CC clutch
this thursday in between classes its supposed to be like 45-50* so im going to steel wool the block and spray it with a clear then start pulling stuff on. ill post more pics when i do that.
Old 03-10-2010, 10:30 AM
  #256
EnviedByMany's Avatar
Sweet project man, still workin on mine too.
Old 03-10-2010, 12:05 PM
  #257
Rease3's Avatar
nice project coming along quite well. what turbo setup are you going with/
Old 03-10-2010, 12:40 PM
  #258
A garrett t3/to4e. Forgot the trim size tho.
Old 03-10-2010, 01:30 PM
  #259
Flattery Will Get You Everywhere
markspan6243's Avatar
hey bud nice project. i live up in dayton, its nice to see someone else in ohio that works on cars.
Old 03-10-2010, 02:18 PM
  #260
alex_b's Avatar
i dig it! GL with the build.
Old 03-10-2010, 03:09 PM
  #261
Rease3's Avatar
post pics of said setup
Old 03-10-2010, 04:51 PM
  #262
Haven't bought the kit yet. I'm buying a real garrett turbo within a kit on ebay. Ill be switching out the wastegate and other things slowly with higher quality stuff over time. One of the first things will be the manifold. Ill post a link next time I'm on my desktop. I got cut on my cornea so I'm just resting it trying not to use my phone and not watching tv to much, which is difficult itself lol.
Old 03-11-2010, 07:53 AM
  #263
Rease3's Avatar
the money ur gonna spend on a ebay kit u can piece a kit better and around the same price imo. buy once and wont have to replace again. cheap reliable fast choose 2
Old 03-11-2010, 08:21 AM
  #264
Here is a link to the kit I was considering. If u wouldn't mind helping me piece together one, I'm cool with you throwing me a PM or email.
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
Old 03-14-2010, 05:11 PM
  #265
vtecpoweredsol's Avatar
CLEAN project man
Bump for you
Old 03-17-2010, 09:19 AM
  #266
Rease3's Avatar
i would go with a custom kit for less than that. i personally like go-autoworks. i would pm him on what u want hp wise and what type of kit you want. manifold mostly. log,ramhorn,mini ram, or cast, or get the cast top mount.
Old 03-17-2010, 09:48 AM
  #267
TRIAL USER
Lanceezy's Avatar
goodluck
  #268
TRIAL USER
Lanceezy's Avatar
clean goodluck
Old 03-17-2010, 10:15 AM
  #269
Yeah I decided to piece one together. I found a mini-log manifold and a Garrett t3to4e 50 trim for a great price.
Old 03-17-2010, 11:55 AM
  #270
Rease3's Avatar
def got lost for a moment forgot who the op was.
  #271
Rease3's Avatar
best way to build piece it together will come out cheap if u look for the right deals
Old 03-17-2010, 12:47 PM
  #272
Lol. Yeah the op sold the car to me and I continued it. I didnt feel like saving the original pics then making a new thread and everything.
Old 03-21-2010, 04:31 PM
  #273
me and my friend (fv8s aka nick) put some things on the engine today and sprayed it so it would stop oxidizing from the bead blasting. i got the new oil pump, water pump, water pipe, thermostat, timing belt, tensionor, spring, timing set (still need to do the sequence to tighten it. sprayed the block an aluminum color so it still looks like the bare metal, then cleared it, sprayed the vtec selonoid with some black paint that was laying around, put my spark plugs in, oil filter sandwhich plate, oil filter on. i think thats it. i tried replacing the cap and rotor but snapped a bolt that holds the cap on and then the rotor screw wouldn't unscrew so i cleaned up and called it quits. now to pics in someone of an order.
(in case some one uses the search on here or just stumbles across this)the timing marks on the cam sprocket at 3 and 9 are NOT supposed to be level with the head on a 1.6. those are for the 1.5! the mark around seven points to the rear upper cover(which i almost lost) it looks like this
there are two arrows up top on the plastic that will point where the 3 and 9 line up(not pictured)
Old 03-30-2010, 12:11 PM
  #274
so i have gotten a good amount of stuff done to my engine. i sprayed the intake mani, cleaned up my altenator brackets, installed the altenator and belt, put the intake and exhaust manifold on, took apart my transmission, had my friend take it to school to clean it. i still have to buy the seals and then put it back together. i think thats it.
Old 03-30-2010, 05:39 PM
  #275
fv8s's Avatar
i actually really like how the intake and exhaust manifold turned out. we will have the trans finished and rebuilt in no time. in the mean time try to figure out gear ratio/size in your Si trans compared to mine
Quick Reply: EG Shell Project...
