Cleaning Headlights
Old 01-06-2009, 06:42 PM
wegotmorrison's Avatar
Default Cleaning Headlights
I know there has probably been hundreds of Threads on cleaning your headlights, but for some reason, Honda-tech changed their site and when I search, no matter what I search for or how I search for it, it returned ZERO results.
Anyways, I rear ended some lady a few weeks ago, and I needed to get a new headlight assembly. So the body shop fixed it all up, gave me a new front bumper and new headlight assembly and it looks great, but the issue is The other side headlights are original and are not brand new, and now you can see the difference. The passenger side looks old and faded, and glazed over a bit.. wasnt really noticable till the other side was replaced. Anyone know of any effective ways to clean it up? I know its not going to look brand new, but If I can get it looking a bit better I wont be so pissed off about it. Thanks guys.
Old 01-06-2009, 07:17 PM
1SicLS's Avatar
Default Re: Cleaning Headlights
https://honda-tech.com/forums/lighting-107/plastic-headlight-restoration-pics-video-2263291/
Old 01-06-2009, 07:45 PM
steveharrmr23's Avatar
meguires plastic x and a microfiber aplicator pad works great
Old 01-06-2009, 09:19 PM
Good write up, but since I have an Integra, Im NOT taking off the bumper... Something alittle less complicated, Im not looking for absolute perfection.. Mequires Plastic X work good? anyone vouch for that?
Old 01-06-2009, 09:42 PM
dapek's Avatar
Yes it's Meguiars Plastix and it works very well as long as you know how to follow directions and take your time Is it the exterior of the headlight that is dull or has the seal broke on the original one causing the inside to collect condensation? It sounds like its the exterior and if so definately just hit it with Plastix
Old 01-06-2009, 09:43 PM
Yeah Im almost 100% sure that its just the exterior. I've never had any condensation inside of it, Im pretty sure.
Old 01-07-2009, 02:15 AM
wunfstgsr's Avatar
I love mothers mag and auluminum cleaner works great and its like $5 at wallmart..
Old 01-08-2009, 12:44 PM
mikeSONICGSR's Avatar
Sorry to ask a question in this thread, but I didnt want to start another one. I am having the same problem, the lights are like a light yellowish color and there is condensation on the inside, what should I do?
Old 01-08-2009, 01:31 PM
iM x Omar's Avatar
go to Walmart
Buy 2 things
1. Blue Shop Towels
2. Rubbing Compound (USED TO BUFF CARS)
now take a little bit of the compound and clean headlights with hand pressure...
more pressure, newer the lights get...
Old 01-08-2009, 05:29 PM
Is it hard to clean the inside of the headlight if there is condensation?
Old 01-08-2009, 06:20 PM
TunerN00b's Avatar
My stock headlamps in my GSR have a vent at the back. Check the tube to make certain that it is clear (its rubber), and any condensation should dry up without having to open the lamp and do anything by hand.
You can also toss one of those "do not eat" desiccant packs inside of the housing at the back to dry up any moisture in there.
Last fix for such things. Remove bulb, remove lamp from car, add rubbing alcohol through bulb hole, swish around the inside, let air dry.
Old 01-08-2009, 06:27 PM
beutler09's Avatar
i can vouch for that as well as all my buddies!
Old 01-08-2009, 07:30 PM
PatrickGSR94's Avatar
Sorry to disappoint, but you pretty much HAVE to remove the bumper to get any sort of decent results on an Integra, especially on a 94-97 bumper as the lenses are recessed so far in. Also, you really need a machine like a Porter Cable random orbital buffer to get the best results. Look in the thread linked in the 2nd post up top, and you'll see a couple of headlight restorations I've done. I used the same process on my car (sans bumper) and it came out great. I applied a clear film over the lenses after completing the restoration, and 4+ years later they still look fairly clear. I could stand to replace that film, though.
Old 01-08-2009, 09:43 PM
jdm91ls's Avatar
go to pep boys they have an actual headlight restore kit it includes various grits of sandpaper, a form of liquid to wetsand the headlight which removes all the film if done properly then you clean the lense and reseal it, dont just buff it and expect it not to happen again in the very near future, i used the kit made by a company called everwear on my jdm's and it cleaned them back up to almost new
Old 01-09-2009, 04:56 PM
Dirty Corey.'s Avatar
Meguire's Plastx WAS the **** in my opinion until just recently. Advance Auto is carrying a new head light buffing compound made by Blue Coral I believe...it is amazing. Way way easier to use than anything else and last quite a bit longer.
Old 01-09-2009, 05:18 PM
95DC2GS-R's Avatar
The bumper isn't hard at all to take off.. It's easier with it off, so you can fully get all the headlight.
Old 01-09-2009, 05:24 PM
1SicLS's Avatar
take pictures of your headlights we could help you more by seeing them
Old 01-12-2009, 06:23 PM
IgnitionZ055's Avatar
Use plastx. If its really cloudy use 3M's headlight restoration kit. It works perfectly.
Pmartos24
03-16-2015 06:04 PM
agati
Honda Civic (2001 - 2005)
10-28-2008 01:06 PM
Roybal 3
08-18-2008 12:37 PM
jr408
03-01-2008 12:02 PM
PRoJecTSLeePaLoT
10-23-2006 11:52 AM
Quick Reply: Cleaning Headlights
