crank pulley torque specs
Old 01-03-2009, 02:36 PM
hspoon's Avatar
Default crank pulley torque specs
what's the torque spec for cranck pulley for b18b1
Thanks in advance
Old 01-03-2009, 02:39 PM
mouab18c1's Avatar
Default Re: help needed asap
at least 85lbs...my gsr is torqued at 85lbs...start with 25 then go to 50 and then 80....
Old 01-03-2009, 03:59 PM
hspoon's Avatar
thanks
Old 01-03-2009, 04:10 PM
Global Moderator
Jimmy's Avatar
my service manual says 130 ft-lbs for the crank pulley bolt.
Old 01-03-2009, 04:32 PM
mouab18c1's Avatar
thats right...but mines at 85+lbs...it'll tightened up as it goes...
steveo135's Avatar
werd jimmy
breaking that bolt loose for the first time can be a bish
Old 01-03-2009, 04:35 PM
Global Moderator
Jimmy's Avatar
Originally Posted by steveo135
werd jimmy
my lord.. yes it can be a bish
steveeeeooo
Old 01-03-2009, 04:38 PM
mouab18c1's Avatar
steveeeeooo
thats why theres tire shops with impact guns to break em loose.... at no COST
Old 01-03-2009, 04:49 PM
Global Moderator
Jimmy's Avatar
Why not do it yourself with your own air compressor/impact?
Old 07-06-2010, 03:43 PM
CRXguy_88's Avatar
I know this threads old but.. OMG that bolt was a bitch to get off. my friends impact couldnt get it off, wet to my local tire shop and boom it came off.. for free too! It was not as bad as the bitch pin though, but close.. but i figured out the easiest way to get that off garanteed!!!
Old 06-25-2016, 09:40 AM
tealteggsr's Avatar
Default Re: crank pulley torque specs
Lol I didn't even use an impact! I took parachute strap tied in a sinch knot wrapped it around a couple of times tied it to the tow hook and broke I loose with a rachet less than 3 minutes!
California98Civ
08-09-2014 10:14 PM
justin_s
07-12-2009 03:17 PM
Superdragr45
01-26-2006 09:27 PM
HonCiv
11-17-2002 06:51 AM
Quick Reply: crank pulley torque specs
