98 accord problem code p1456
Old 12-27-2008, 07:04 AM
em1blk2000's Avatar
Default 98 accord problem code p1456
I replace the gas cap and the light is still on. I toke it to the dealer and told me to change the purge value and cansiter . I want to know were the location. Of the purge value and cansiter in the car,so I can change it my self. Thank you
Old 12-27-2008, 07:25 AM
GhostAccord's Avatar
Default Re: 98 accord problem code p1456
I think it's part #9 that your looking for circled in red.
Looks to be located next to the fuel tank on the drivers side.
Old 12-27-2008, 07:52 AM
em1blk2000's Avatar
Will this be under the back seat or under the car?
Old 12-27-2008, 11:39 AM
Mr Yamada's Avatar
Under the Car , BESIDE the gas tank
Old 12-28-2008, 08:17 AM
market525's Avatar
Just an FYI - I've done this job before on a 98 Accord. Car had spent all of its life in Vermont, and was a rusty mess underneath. Not only did I need the pruge valve, but had to replace the cannister, as well as the cannister mounting bracket too. (screws were so rusty on the purge valve, they would not budge)
Once the job was complete, code was cleared & the car was fine. I see you are in TX, so rust might not be an issue. Also, I think there is/was a TSB from Honda on this issue?
Good luck,
Steve
Old 12-30-2008, 04:49 PM
model x's Avatar
The problem is the canister vent shut valve, but its hard to replace because of how its mounted to the charcoal canister,metal nuts in plastic just spin. So we normally replace the canister and CVS.
The canister vent shut valve is number 8
BTW I've replaced around 20 of these
Old 05-14-2013, 10:19 AM
osageit's Avatar
My 1998 Accord EX Cp V6 has this code now (P1456), I replaced the gas cap, also replaced the entire EVAP assemble next to gas tank (canister, pressure sensor, and shut-valve) from a doner car that just passed smog. ??What should I do next, I'm at a loss??
Old 06-01-2013, 12:51 AM
osageit's Avatar
Icon6 Re: 98 accord problem code p1456
After researching, found that Honda OBD2 Code P01456 is an EVAP Code for fuel tank pressure loss between filler port to tank. Common cause for this code is bad fuel cap, or bent lip of metal fuel port. The other causes can be the connections between the tank, and filler port such as plastic fill tube behind (L) quarter panel, inside (L) rear wheelwell, or the return/over flow tube conections.
I replaced my OEM fuel cap, inspected fuel port lip, inspected conections behind cover in (L) rear wheel well, all was fine. I then removed the cover in the trunk that gives access to the fuel pump, and return vapor lines, found it to very dirty in there, and the connections for the return line to caked with dirt also damp in appearance with a slight odor of fuel. I'm attaching a URL picture of this finding, could someone with the expert knowlage of this type of issue please confirm my findings to be the cause of my OBDII Code of P01456.
Thanks you reading this, and any assistance.
Old 06-01-2013, 09:28 AM
doc500's Avatar
It would appear that the connectors are leaking indeed. Hence the wet dirt.
Old 06-01-2013, 11:28 AM
osageit's Avatar
Then it would be safe to say, this the most likely cause of my EVAP Code of P1456, yes?
Old 06-01-2013, 11:45 AM
doc500's Avatar
More than likely a safe place to start. Leaking fuel at any rate, just isn't safe. Start there, and see what happens. Hopefully it will fix the problem.
Old 06-01-2013, 11:59 AM
osageit's Avatar
Thank you,
For your input, and time, I do appriciate it.
Old 06-01-2013, 03:42 PM
doc500's Avatar
Not a problem. Just paying it forward, so to speak.
Old 06-02-2013, 05:14 PM
osageit's Avatar
Icon2 Re: 98 accord problem code p1456
Is it possible to clean/repair these fuel line connections to stop the fuel vapor leak (cause of my EVAP Code of P1456), or do I have to replace the entire line?
Old 10-11-2013, 01:22 PM
breds2k's Avatar
Did anyone ever solve the issue?
Old 10-11-2013, 05:10 PM
doc500's Avatar
I don't know... Crap!!! I never got an alert that he had responded. Osageit, were you able to fix the problem?
98honda51
12-31-2016 05:31 PM
Muhammad Mian
12-01-2015 04:05 PM
Fl018
01-12-2013 06:17 AM
Fl018
01-11-2013 02:53 PM
hyrum
07-22-2008 02:51 PM
Quick Reply: 98 accord problem code p1456
