Can Someone tell me what is this sensor called? on a 1994 Accord
Old 12-04-2008, 02:49 PM
jose310's Avatar
Default Can Someone tell me what is this sensor called? on a 1994 Accord
Well, this sensor is broken and full of oil and has my car acting up when i try to turn it on...i just got another one from the junkyard to replace it...Im just wondering what is it called...as soon as i remove it or touch it, I get the check engine light on and the D4 Flashing with out stopping. 1994 acord LX auto...4cl
CHECK OUT THE LINKS...THANKS!
http://img229.imageshack.us/my.php?i...img4092er6.jpg
http://img155.imageshack.us/my.php?i...img4090jg2.jpg
Old 12-04-2008, 03:46 PM
redbull-1's Avatar
From your pictures, it is still very hard to see the location. But, since I see the distributor, is it the sensor on top of the transmission? If so, it is the Vehicle Speed Sensor (VSS), which would cause the D4 to flash.
Check this link out to see if that is what you are referring to:
http://techauto.awardspace.com/vss.html
Old 12-04-2008, 04:00 PM
jose310's Avatar
Yes is riught under the distributor...
Old 12-04-2008, 04:09 PM
He knows where you live!
TheMuffinMan's Avatar
VSS is on the tranny and facing updates, that looks like the plug comes in from the side. From around the engine block.
Old 12-04-2008, 04:10 PM
jose310's Avatar
I Believe its on the left side of the engine...not on the tranny...
Old 12-04-2008, 05:37 PM
jose310's Avatar
Can anybody help? It connected to the block...on the left side...
Old 12-04-2008, 06:11 PM
hondadude's Avatar
The 2 pin connector in the head under the distributor is a temp sensor ;
The single pin connector is for the temp gauge sending unit;
If you make the pictures a little smaller and darker I'm sure you'll get some more wild guesses.
Old 12-04-2008, 06:36 PM
Haha I had a hard enough time determining the orientation of the pics.
Old 12-04-2008, 06:40 PM
jose310's Avatar
Its right under the distributor Cap its connected to the engine on the left side..
Old 12-05-2008, 11:51 AM
hondadude's Avatar
The single pin connector is for the temp gauge sending unit.
Old 12-05-2008, 12:40 PM
jose310's Avatar
THANKS, i got the oring fixed on the distributor and the 2 pin connectors replaced..does the temp sensor affect the transmission also...?
Willy1971
03-25-2019 06:32 AM
Babong
17
09-20-2011 08:35 AM
r.etheridge
02-13-2011 02:59 AM
refman102
10-25-2007 05:24 AM
mayflower
11-18-2005 05:33 PM
Quick Reply: Can Someone tell me what is this sensor called? on a 1994 Accord
