'92 Accord EX fluid leak from the rear?
Old 11-30-2008, 08:05 PM
ChemBot's Avatar
Default '92 Accord EX fluid leak from the rear?
I was making a quick trip today when someone drove up next to me telling me I was leaking gas. I pulled over to check, and there was indeed a good amount of liquid leaking out of the bottom of the car right below the trunk. I did a sniff test on the liquid, but it wasn't gas. It smelled like slightly mildewy water, which would make sense if some rainwater pooled there since we just had a rainstorm the other day. I don't think it was coolant, but I've never known my car to collect rainwater like that before. I even checked my coolant levels, which were normal. It seems like it only leaks out when the engine is running.
I think I'm worried over nothing, but can anyone confirm my suspicion that it's just rainwater and not something else?
Old 11-30-2008, 08:14 PM
P_Adams's Avatar
You have nothing in the rear of the vehicle which would leak anything else but gasoline.
More than likely you've got either a leaking Trunk Seal, a leaking Tail Lamp assembly or a leaking Rear Window.
If you pull up the spare tire cover, you may find your reservoir; in the spare tire well.
P
Old 11-30-2008, 09:27 PM
ChemBot's Avatar
Oh, yeah that makes sense. Thanks for the input! Although, I still worry that I may be leaking blinker fluid. I hear that stuff can get expensive...
Old 12-01-2008, 02:58 AM
91EX4dr's Avatar
There is brake fluid in the rear, but you didn't mention anything about not being able to stop. So that's not your problem. Probably just water.
Old 12-01-2008, 04:43 AM
P_Adams's Avatar
Have you changed over to Winter Air for the tires yet? Summer Air can leak over time (it's thinner) :-)
P
faran
09-05-2010 03:11 PM
1baddcivicsi
06-07-2010 07:01 PM
1986
08-05-2007 01:56 PM
FIDIRO
09-03-2006 10:04 AM
eWock
12-25-2005 07:37 PM
Quick Reply: '92 Accord EX fluid leak from the rear?
