DIY Car ramps for lowered vehicles.
I was on HT site looking for good car ramps for repairs, oil change, maint, etc. I didnt find anything that would help us since we are all pretty much super low. So I did a google search and came across this site. Please disregard the vehicle used.
For slammed stangs and the DIY'er
If your stang is lowered more than 2 inches, or you just find it a PITA to lift the front of your car then you might need to make yourself some MW ramps :-)
(DIY means "Do it yourself" of course)
One of the key things in getting motivated to do your own oil changes or modding your stang is being able to easily, quickly and safely lift your stang. If it's going to take 15 minutes for you to jack up the front end of your stang one side at a time with a jack and jack stands, chances are you won't be too motivated to install that supercharger you had sitting in your garage for the past 5 months :-)
The next problem is if your stang is already slammed (lowered), then you have a real challenge lifting the front end with probably only 1" - 2" of clearance.
Other Ramps
We reviewed Rhino Ramps a few years back which is probably the best store bought alternative (for the price), but the things we don't like about them and other ramps were that on a lowered stang, you still scrape the black lower portion, and most ramps are a single incline ramp, which means any mishap and that stang is rolling down to the ground in one shot. Also most store ramps are very light weight, which means they can slide on a smooth floor when trying to drive up onto them.
We wanted ramps that addressed all these problems that were the same price or less to make than some store bought ramps.
Let's Build
MW Ramps sketch. Cost to make: Around $30 in wood
Materials: 2" x 10" x 10 foot (two), 2" x 10" x 8 foot (two) and a 2" x 3" x 10" piece.
This isn't New Yankee Workshop, so just a quick overview.. :-)
Go to your local lumber store and buy the pieces of wood mentioned above. You can get them in different lengths. Try to find dry wood that's not warped. You might buy 20 foot long pieces and cut them according to our sketch. We made at least an 18" stretch between steps to accommodate the stang's long nose and to avoid scraping ground effects on most slammed stangs. Building is easy, simply nail the pieces together as shown, taking care to pre-drill a slightly smaller hole for the nails, so you don't run the risk of splitting the wood. Bend the nails over at the bottom of each ramp if they stick out.. You may also glue the parts together to boot.
Finished Ramps.
10" wide is good for wide tires.. Got wider ? You can get 2 x 11's if need be
Drive on up
ON A FLAT LEVEL SURFACE, just drive up the ramps. The stopper piece will prevent you from driving off and each step is easily rolled onto. Then lay a wheel stop "behind" the front wheels and you are ready to work. Each ramp weighs enough so they should not slide when driven onto slowly.
If you are on an uneven surface, you might need to shim the ramps to get them level and to ensure they lay flat. You can also place jackstands as a backup if you wish.
What kind of lift
It raises the stang about 6" (a little higher than rhino ramps as an example) and it's high enough to do most under chassis engine / h-pipe work. Need higher ? You can add an extra step (before the rear tire hits the ramps even).
Access is from the front. You can swap an H-pipe and easily access the lower engine. For more space or for oil changes you can lift the rear to level out the stang. You can also now lift one side of the stang at a time up front (a tiny amount) easily with a floor jack for changing the front tires for example.
Is wood strong enough ?
Let just say laid flat the wood can lift your entire house (many tons) with no worry. The only worry we have (way back in our minds) is wood splitting, but if you pre-drilled your nails and / or glued your wood together, you should have absolutely no problems.
The "stepped" nature of the ramps
The stepped nature of the ramps also means that if for some reason you forgot to put a wheel stop behind your tires and you start jacking up the rear, your stang may only roll down one step, NOT roll down the entire ramp. Most other store ramps are single incline or 2 piece ramps, not stepped like these home made units :-)
Only 1.5" clearance needed
For most lowered stangs (or other cars) lifting is no problem, because we only need 1.5" in front of the tires. We have 18" of space before each step which covers the lower edges on many body kits. If you need more room, you can extend the step interval to 20+ inches. You can see there is plenty of room left before the ramps hit our rear tires.
The bottom line...
If you could not find yourself the "right" set of ramps in stores or are tired of jacking up the front end one side at a time or bending your center crossmember with your jack, or can't get a jack under your front end... you can see making a set of home ramps is fairly easy and you can make them to your very own specs.
The cost of the wood can vary, so these are not really "poor mans" ramps in some cases home made may cost a few dollars more, but since it's to your own specs, we like that :-)
We gave our ramps a coat of paint after these shots were taken.
Extra notes:
These ramps will weigh 30 - 40 pounds each depending on how dry the wood is, so they are mainly for home use (not really portable). We still have all our other ramps (Rhino, metal, 2 stage, etc) and use them when we can for different jobs.
Other Ramps
Let's Build
Finished Ramps.
Drive on up
What kind of lift
The bottom line...
Extra notes:
Not bad I guess.
But for around the same price I pay for all the materials, couldn't I just get a pre-made car ramp made from better material?
If you goggle "Low profile car ramp" you get tons of companies that make car ramps for race inspired and lowered cars for around the same cost.
Import Alliance
I got a set of Tomiaka Racing Super Slopes from Brad at Nukabe for our ImportAlliance project civic.
They are awesome!
Here is a pic from their website.
They are awesome!
I drive a G35, it's silver, surprised?
That wood ramp is a nice DIY, I guess. But as others mentioned you can get some low profile ramps instead. They look nice and wont grow mildew from being out in the rain. =P
yea cause that mustang's gonna need a low profile ramp cause of how low it is lol...im low and suck it up with a good old 3 ton jack and 2X4's
I think that the low profile ramps are perfect for wheel ****** that change wheels a lot.
Most floor jacks can't get under (even low profile floor jacks) the front end of a car, even worst with front lips so getting the front end of the car up about 3" is good enough. Using the stock OEM jack is too tedious in my opinion.
Have you?
I'd like to know how you get a floor jack under the front half of a car when you cannot get to the sides and without messing up a front lip? I already stated it was too tedious to use the OEM jack.
I was kidding with you, you didn't mention driving onto the ramp and then jacking it up
