99-00 Civic Fog Light Install
Old 11-25-2008, 01:04 PM
  #26
Frost7177's Avatar
i dont have that wire on mine i believe. They dont fire up at all? Try buying one bulb and put it in one fog light you may have blown them.
Old 11-25-2008, 01:22 PM
  #27
04silvep3's Avatar
Originally Posted by MilanoRedEk99
^ what he said, and you only use that plug with oem fogs don't need to use it with the depo ones.
theebay fogs were oem replica had all the same **** as honda oem fogs so thats all i needed to know thanx im gunna see if i have the plug behind the fuse box i hope its there
Old 11-25-2008, 01:24 PM
  #28
HonduhDave's Avatar
It should, I know mine did and I rock a sedan...
Old 11-25-2008, 01:26 PM
  #29
04silvep3's Avatar
ok cool thanx for all da help im gunna check it wen i get home from school
Old 11-25-2008, 02:48 PM
  #30
EK_kidd's Avatar
I had the same problem. This is that u do. That male connector under your hood connects to your fog light harness.. Behind your fuse box there's another connector in BLUE TAPE. Connect that to your relay.. Ground the relay then the other 2 male connectors plug into your fuse box. I think is 1 and 3.. They should turn on when your car is fully on engine running and everything.. Pm if anything..
Old 11-25-2008, 03:38 PM
  #31
04silvep3's Avatar
ite cool ust gotta get my fat *** under the dash to look behind and find it
Old 11-25-2008, 03:44 PM
  #32
wudini's Avatar
i'm pretty sure what you are looking for is the factory plug that is under the power steering resevior behind the drivers side headlight. it's tricky to locate, but it's there. it's got blue tape on it i think and it's tucked away pretty good.
Old 11-25-2008, 06:54 PM
  #33
EK_kidd's Avatar
Get your *** up and find that connector. Behind the fuse box
Old 11-26-2008, 09:10 AM
  #34
04silvep3's Avatar
i found it thanx for the help now i gotta find a template to cut the bumper thanx
Bert209
Honda Civic (2001 - 2005)
03-29-2018 09:48 PM
cleanHONDA619
10
01-15-2017 05:10 AM
Frost7177
04-03-2008 05:52 PM
AMF Racing
24
02-13-2005 03:18 PM
Quick Reply: 99-00 Civic Fog Light Install
