'04 Accord - high-pitched whine when backing up
Old 11-18-2008, 04:07 PM
JerseyGirl474's Avatar
Icon2 '04 Accord - high-pitched whine when backing up
Hoping someone here can help me figure out what's wrong with my car ... I have an '04 Accord EX, and whenever I go in reverse without using either pedal, the car makes a high-pitched whining sound (not squeaking); the sound is coming from the rear of the car. Can anyone tell me why this is happening?
Thanx!
Old 11-18-2008, 06:35 PM
chinochanginc's Avatar
wheel bearing?
Old 11-19-2008, 04:43 AM
impound's Avatar
rear pads
Old 11-19-2008, 04:59 AM
But wouldn't it make that noise when the car is going forward also if it were the pads?
Old 11-19-2008, 10:09 AM
6poundsdaily's Avatar
is this your first honda? they all whine in reverse
Old 11-19-2008, 12:48 PM
impound's Avatar
it will soon enough.
Old 11-19-2008, 12:51 PM
impound's Avatar
it will soon enough. just my opinion. if i could see it i could tell you for sure.
Old 11-19-2008, 01:16 PM
No, it's my second - had a 2000 Civic before this car - and that one NEVER made this noise (or any noise in reverse, for that matter), and I've had the Accord for a year and it only started making this noise a week ago.
Old 11-19-2008, 01:31 PM
LittleRat's Avatar
Try jacking the car up and rotate each rear wheel individually to see IF its just one side or the other. Then I'd take the caliper off to see if it is a bearing, as was previously stated. I'd replace the pads anyway....especially the way they drive in Pennsyl-Jersey.
Old 11-19-2008, 02:02 PM
MustangLX6.0's Avatar
Not on the rear, espically on that accord if your backing up and hear a loud high pitched noise then you have a pad on the indicator. Wheel bearings dont make high pitch noise the noise is more like a droning type tire noise at highway speeds
Old 11-19-2008, 02:30 PM
1grex's Avatar
Rear brake pads
Old 01-24-2013, 11:10 AM
pmlawrence's Avatar
Default Re: '04 Accord - high-pitched whine when backing up
I also have an 04 Honda Accord EX V6 that has just started making this whining noise when I back up. I do not have my foot on the brakes when it happens so I am baffled by what it might be. Has anyone else found out what the problem is? Thanks.
Old 02-04-2013, 09:05 AM
bladi3990's Avatar
a whimning gear noise is normal in reverse. a groaning noise isnt normal.
Posted from Honda-tech.com App for Android
Old 02-19-2013, 09:22 PM
Cogent Argument Enthusiast
Uncle Ben's's Avatar
My Accord only made a high-pitched noise in reverse when a rear caliper was seized. And that is a VERY common issue with these cars.
bigjoncoop
03-12-2018 05:06 PM
willowcairns
12
10-06-2013 05:50 PM
StickyOut
08-15-2013 02:48 AM
hondaracer4vtec
08-19-2008 07:43 AM
richmojm
06-27-2005 10:02 PM
Quick Reply: '04 Accord - high-pitched whine when backing up
