05 honda accord stereo removal.
Old 10-28-2008, 12:30 AM
88ernie88's Avatar
Default 05 honda accord stereo removal.
ok so i want to remove my stock stereo and put a new one in. i've tried looking for hidden screws or something holding the stereo but i cant seem to find it. i dont wanna remove it and have a big gap. how do i remove the stereo...if u can help i'd greatly appreciate it.
Old 10-28-2008, 12:49 AM
racebum's Avatar
Default Re: 05 honda accord stereo removal. (88ernie88)
you're in the integra section
Old 10-28-2008, 12:50 AM
Global Moderator
Jimmy's Avatar
Default Re: 05 honda accord stereo removal. (idrivesideways)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by idrivesideways &raquo;</TD></TR><TR><TD CLASS="quote">you're in the integra section</TD></TR></TABLE>
lol.. moved to accord forum
88ernie88's Avatar
and that means?
Old 10-28-2008, 06:28 AM
In a Junkyard near you.
Ross 2.0's Avatar
You posted in the wrong section.
You have to remove the vents from the top of the dashboard by pulling towards you and up.
Pop off the shifter trim (pull up)
Then remove the cointray (pop it out with a screwdriver) and the two screws below it.
Remove the two screws holding in the storage compartment and remove that too.
Once you get that out you can remove the two 8mm bolts from the bottom of the radio.
Then you just have to pull the radio out from it's clips.
But beware the aftermarket radio and a/c controls are garbage.
Old 01-05-2009, 03:14 PM
MDBdad's Avatar
Icon2 Re: 05 honda accord stereo removal.
Will those same instructions work on my 07 Accord with Navigation?
I assume they do. I've gotten to the two bolts in the bottom of the radio, but the vent doesn't budge. The radio connection is not visible from the lower compartment.
Old 04-04-2009, 04:40 PM
briq4's Avatar
Anyone have more insight to removing the vents/top area above the stereo? I couldn't get it to move either.
Old 04-04-2009, 06:03 PM
K24power07's Avatar
ull have to use a flathead screw driver very gently or a pair of pliers to pull it ...
ive taken it apart many times as u can see...
Old 04-04-2009, 06:06 PM
briq4's Avatar
do you mean pull the vents themselves and pull straight out towards the back of the car?
Old 04-04-2009, 06:12 PM
K24power07's Avatar
here you go ,hope this helps..........
Old 04-04-2009, 07:46 PM
soon2bdropped's Avatar
thats it?? dont remove the console? shifter trim panel? cointray?
Old 04-04-2009, 07:58 PM
K24power07's Avatar
no thats the last part, he asked about how to remove the vents.....
Old 04-04-2009, 08:16 PM
K24power07's Avatar
STEP 1 - 4
STEP 5-8
STEP 9-12
TO re-install follow steps in reverse..........
Old 04-05-2009, 12:31 AM
asnstyle22's Avatar
that dircetion is not 100% accurate for vent removal. you actually have to press the hazard button in and there is a slot infront of it for you to put in a flat head, thats the release for you to remove the vent by pulling it out towards you, if you dont press it, i doubt you can remove the vent.
yomayo
11-22-2006 05:11 PM
accord06
09-03-2006 01:17 PM
quantum_05em2
Honda Civic (2001 - 2005)
07-22-2006 03:46 PM
Quick Reply: 05 honda accord stereo removal.
