Honda D series engine
Old 10-14-2008, 10:11 PM
guysensei's Avatar
Default Honda D series engine
I just felt this needed to be posted here.So hopefully this helps you guys out. Well at least those of us that use the search button.This is taken from wikipedia.
The Honda D engine is a family of inline 4-cylinder engines used in a variety of compact Honda models, most commonly the Honda Civic, CRX, Logo, Stream, and first-generation Integra. Its displacement ranges between 1.2 and 1.7 liters and is available in SOHC and DOHC versions; with some SOHC models equipped with VTEC. Power range started from 62 hp (46 kW) to 130 hp (97 kW). The D-series was introduced in 1984 and ended production in 2005 with the introduction of the 8th generation Honda Civic.
JDM D15B VTEC Swap into US-market 1988 CRX DX (slightly modified).
Although the availability of used D-series engines at low prices makes it somewhat popular among those who modify it for high performance (as well as a popular item for swapping into earlier or less powerful Civics for an instant and trouble free power upgrade), the unmodified engine won't survive quite as much power enhancement by use of such external modifications as turbochargers, superchargers, or nitrous oxide as the more powerful, somewhat more robust, and more expensive B-series in the Integra.
The Achilles heel of the D-series seems to be its connecting rods, which will withstand a power increase up to a certain point but will break if that limit is exceeded. Generally, a D-series motor can handle up to about 220 bhp (160 kW), as long as care is taken to avoid detonation through careful spark and fuel management. Of course, the connecting rods, pistons, and other internal parts can be replaced with more durable after market parts that can handle more power, but many choose to swap to a B-series motor to avoid the potential risks of engine building. In all practicality though, the B series is much more expensive to swap in than most D-series engine builds with forced induction or nitrous combined. The D-series also has the ability to swap some parts between different motors and some B-series parts as well. When employing forced induction on a D16, at a minimum the stock hypereutectic pistons should be replaced as well as the connecting rods if the commonly used "stock parts" limit of 220 hp (164 kW) is to be exceeded, although the D series crankshaft in particular has been found to reliably handle up to 600 hp (450 kW).
High compression OEM pistons are a quick way to gain power in a naturally aspirated motor. All D-series motors run the same bore (75 mm), however most factory motor variations (i.e. D16A1, D15B7, D16Y7) have used a different piston compression height as well as a different dome or dish. In general, the older D motors have a higher compression height and a larger combustion chamber which create around a 9.1:1 - 9.4:1 compression ratio from the factory. The newer variants have slightly lower compression height combined with a much smaller combustion chamber to create a compression ratio of 9.4:1 - 9.9:1. Now if you combine an older D16 motor's piston with that of a newer D16 head you can end up with a compression ratio of about 10.7:1 with no other work (i.e. D16A1 piston, D16A6 head). There are a few websites that have compression ratio calculators for Honda motors.
* D16 and D17 cranks share the same size main bearing diameters.
* D16 and D17 rods all have the same major dimensions. The D15 rod is shorter (in general) and has a smaller bearing size, although the wrist pin bore is the same.
* D15Z1 and D15B motors have a rod that is the same length as a D16. Other than the rod length, the rest of the bottom end is D15 spec (i.e. rod and crank bearings). D15B has D16 sized rod journals. D15B uses the same p28 rods that the D16z6 does. All other D15s have smaller rod journals.
* The B18A/B Rod has the same bearing bore as a D16. It is 0.044" wider, so the sides of the "big end" of the rod have to be shaved down for use in a D16/17. The wrist pin bore is larger so a conventional D15/16/17 piston can only be used if the stock "small end" bushing in the rod is replaced with one of the proper size. These affordable rods are generally considered to be able to handle up to 300 hp (220 kW).
* There is a D16 motor that runs on compressed natural gas (96-98 Civic GX). The pistons from that motor have a 12.5:1 CR. The wrist pin bore in the 98-00 D16B5 is 21 mm, like the B18B rod. D17A7 01-05 Civic GX uses 19 mm wrist pins.
* Interestingly enough, the Suzuki Vitara has a 75 mm bore as well, so engine builders have occasionally used these pistons in the D16 motor. These pistons are commonly referred to as Vitaras, and they provide an 8.5:1 compression ratio, and thicker ring lands. Lowering the stock compression ratio lowers compression heat, which raises the detonation threshold and is useful when employing forced induction. There have been reports of over 400 hp (300 kW) to the front wheels utilizing these.
Mini-Me
One of the most popular and effective methods of achieving greater power from a D-series motor is replacing the cylinder head with one from a more powerful D-series motor. This is usually done between D16A6 and D16Z6 or D16Y7 and D16Y8 engines, however, can be performed in other combinations as well; such as a D16Z6 head on a D16Y7 or D15B2/B7 block. The Z6 and Y8 heads are VTEC (Variable Valve Timing and Lift Electronic Control) equipped, and increase power significantly over stock levels. This operation is known as a "Mini Me" or partial swap. Mini Me's are popular because they offer a substantial performance upgrade by adding VTEC to the motor at a relatively low cost. Simply adding a VTEC head to a non-VTEC block will not increase power alone. This is because the VTEC circuit must be activated and accompanied by a new 'high cam' fuel map from the car's ECU.
Engine Specs
D12 Series Engines (1.2 Litre)
D12A
* Found in:
o 1986-1988 Honda Civic & City GG G-Mark Special (Japanese Market) + Displacement : 1237 cm + Bore and Stroke : 72 mm x 76 mm + Compression : 9,5 : 1 + Power, Torque : 56 kW @6500 rpm , 98 @4000 rpm + Valvetrain : SOHC, 4 valves per cylinder + Fuel Control : Single Carburetor
there are some locally distributed units that start with JHM, these are the 1200 cc EF sold in 1991. all 1000+ units were imported from Japan (SKD)
D13 Series Engines (1.3 Litre)
D13B1
* Found in:
o 1988-1991 Honda Civic DX (European Market)
+ Displacement : 1343 cm³
+ Bore and Stroke : 75 mm X 76 mm
+ Compression : 9.5:1
+ Power, Torque : n/s (Not stated in Owners Manual)
D13B2
* Found in:
o 1992-1995 Honda Civic DX (European Market)
+ Compression : 9:1
+ Power, Torque : 75 hp (56 kW) @ 5300 rpm
D13B4
* Found in:
o 1998-2003 Honda City EXI/DX
+ Displacement : 1300 cc
+ Bore and Stroke: 75mm x 76mm
+ Compression : 9.75:1
+ Power, Torque : 70 kW (95 HP) at 6.500 min−1
+ Valvetrain :
+ Fuel Control : Multi-point fuel Injection, PGM-FI
D13B7
* Found in:
o 1998-2001 Honda Logo 5D
+ Displacement :
+ Bore and Stroke:
+ Compression :
+ Power, Torque :
+ Valvetrain :
D13C
* Found in:
o 1989-1994 Honda City CE, CE Fit, CE Select, CG, CR-i, CR-i limited, CZ-i, New Fit (Japanese Market)
+ Displacement :
+ Bore and Stroke:
+ Compression :
+ Power, Torque :
+ Valvetrain :
+ Fuel Control :
D14 Series Engines (1.4 Litre)
D14A1
* Found in:
o 1987-1991 Honda Civic GL and 1990 CRX (European Market)
+ Displacement : 1396 cm³
+ Bore and Stroke : 75 mm X 79 mm
+ Compression : 9.3:1
+ Power, Torque : 90 hp (90 bhp) @ 6300 rpm, 112Nm @ 4500 rpm
+ Valvetrain : SOHC, 16 valves
+ Fuel Control : Dual Carburetor
D14A2
* Found in:
o 1995-1996 Honda Civic MA8 (European Market)
+ Bore and Stroke : 75.0 mm X 79.0 mm
+ Compression : 9.2:1
+ Torque, Power : 117 Nm @ 5000 rpm, 66 kW @ 6100 rpm
D14A3
* Found in:
o 1996-1999 Honda Civic EJ9 (European Market)
+ Compression : 9.1:1
+ Power : 75 hp (civic i)
+ Valvetrain : SOHC non VTEC 16v
+ Redline : 7200 rpm
+ Fuel Control : Multi-point fuel Injection (PGM-FI)
+ Transmission: S40
D14A4
* Found in:
+ Power : 66kW (90 hp) (civic is)
+ Transmission: S40
The D14A3 and D14A4 engines are identical, the difference is found in the valves, this is the reason the D14A4 produces 15 hp more then the D14A3
D15 Series Engines (1.5 Liters)
D15A2
The JDM spec engine model of one of the EW series
motors, used in later years of the third-gen Civic.
D15A3
* Found in:
o 1985-1987 Honda CRX Si and 1987 Civic Si (AU/NZ)
+ Displacement : 1488 cm³
+ Bore and Stroke : 74 mm X 86.5 mm
+ Compression : 8.7:1
+ Power : 91 hp (68 kW) @ 5500 rpm & 93 ft·lbf (126 N·m) @ 4500 rpm
+ Valvetrain : SOHC, 3 valves/cylinder
+ Fuel Control : pgm-fi2
D15B
* VTEC
* Found in:
o 1991-1999 Honda Civic VTi EG4 (Japanese Market)
o 1992-1998 Honda CRX VXi EG1 (Japanese Market)
+ Displacement : 1493 cm³
+ Bore and Stroke : 75 mm X 84.5 mm
+ Rod Length : 137 mm
+ Compression : 9.6:1
+ Power : 128.22 hp (130 ps) @ 6800 rpm & 101.9 ft·lbs (14.1kg/m) @ 5200 rpm
+ Fuel Cut : 7411 rpm
+ Valvetrain : SOHC VTEC
+ Head Code : P08
+ Fuel Control : OBD-1 MPFI
D15B (D15Z7) (with 3 stage VTEC)
* 3-stage VTEC
* Found in:
o 1996-1999 Honda Civic VTi EK3 and Ferio Vi
+ Power : 128 hp (130 ps) @ 7000 rpm & 102 lb·ft (14.2kg/m) @ 5300 rpm
+ Fuel Control : OBD-2 MPFI
D15B1
(Same as the D15B2 engine, but with a mild camshaft, and a restrictor plate between the throttle body and intake manifold)
* Found in:
o 1988-1991 Honda Civic Hatchback
+ Bore and stroke : 75 mm X 84.5 mm
+ Power : 71 hp (53 kW) @ 5500 rpm & 82.6 ft·lbf (112.0 N·m) @ 3000 rpm [1]
+ Valvetrain : SOHC (4 valves per cylinder)
+ Fuel Control : OBD-O DPFI
D15B2
* Found in:
o 1988-1991 Honda Civic GL/DX/LX
o 1988-1991 Honda CRX DX
o 1992-1995 Honda Civic LSi Hatch/Saloon (European Market)
o 1990-1995 Honda Concerto (European Market)
+ Rod Length : 134 mm
+ Power : 92 hp (69 kW) @ 6000 rpm & 119 Nm @ 4500 rpm
+ Cam Gear : 38 tooth
+ Piston Code : PM3
+ Fuel Control : PGM-FI Dual Point (OBD0)
+ Redline : 6500 rpm (6000 rpm honda concerto)
D15B3
* Found in:
o 1988-1989\ Honda Civic EX
o 1988-1995 Honda Civic Shuttle GL
o 1992-1995 Honda Civic LX (NZ model)
+ Compression : 9.9:1
+ Power : 95 hp (71 kW) @ 6000 rpm
+ Fuel Control : Carburetor
D15B4
* Found in:
o 1989-1991 Honda Civic GL (Australian Market)
+ Power : 90 hp (70 kW) @ 5200 rpm & 122 Nm @ 3800 rpm
+ Valvetrain : SOHC (2-4 valves per cylinder, depending on year)
D15B6
* Found in:
o 1988-1991 Honda CRX HFx
+ Power : 62 hp(88-89) 72 hp(90-91)@ 4500 & 83 ft·lbf (113 N·m) @ 2800 rpm
+ Valvetrain : SOHC (2 valves per cylinder)
+ Fuel Control : OBD-0 MPFI
+ Head Code : PM-8
D15B7
* Found in:
o 1992-1995 Honda Civic CX (Canadian model)
o 1992-1995 Honda Civic DX/LX
o 1993-1995 Honda Civic del Sol S
o 1992-1995 Honda Civic LSi Coupe (European Market)
+ Power : 102 hp (76 kW) @ 6200 rpm & 98 ft·lbf (133 N·m) @ 3800 rpm
+ Piston Code : PM3
+ ECU: P06
D15B8
* Found in:
o 1992-1995 Honda Civic CX (U.S. model)
+ Displacement : 1500 cm³
+ Power : 70 hp (52 kW) @ 4500 rpm & 83 ft·lbf (113 N·m) @ 2800 rpm
+ Fuel Control : OBD-1 MPFI.
D15Z1
* VTEC-E
* Found in:
o 1992-1995 Honda Civic VX
o 1992-1995 Honda Civic VEi (European Market)
+ Power : 90 hp (67 kW) @ 5600 rpm & 98 ft·lbf (133 N·m) @ 4800 rpm
+ Valvetrain : SOHC VTEC-E (4 valves per cylinder)
+ ECU Code : P07
D15Z4
* Found in:
o 1996-2000 Civic Exi and SA Ballade & Civic 150i
o Displacement : 1493 cm3
o Power : 90 hp (67 kW) and 105HP(82Kw) @ 5800 rpm
o Torque (lb·ft@rpm): 99 (140 N·m) @ 4200 rpm
o Valvetrain : SOHC non-VTEC 16v
D15Z6
* VTEC-e
* Found in:
o 1995-2000 Honda Civic 1.5 iLS (European Market)
+ Power : 115 hp (86 kW) @ 6500 rpm
+ Torque : 100 lb·ft (141 Nm) @ 4800 rpm
+ VTEC Switchover : 2500 rpm
+ Fuel Control : PGM-FI MPFI
D15Z7
* 3-stage VTEC
* Found in:
D15Z8
* VTEC-E
* Found in:
o 1997-2000 Honda Civic LS (European Market)
+ Power : 84 kW (114 hp) @ 6500 rpm
+ Torque : 134 Nm (95 lb·ft) @ 4500 rpm
+ VTEC Switchover : 4700 rpm
+ Fuel Control : OBD2 MPFI
D16 Series Engines (1.6 Liters)
D16A1
* Found in:
o 1986-89 Acura Integra (USA)
+ Displacement : 1590 cm3
+ Bore and Stroke : 75 mm X 90 mm
+ 1986-1987 Compression : 9.3:1 1988-1989 Compression : 9.5: 1
+ 1986-1987 Power : 113 hp (84 kW) @ 6250 rpm Torque : 99 ft·lbf (134 N·m) @ 5500 rpm
+ 1988-1989 Power : 118 hp (88 kW) @ 6250 rpm Torque: 101 ft·lbf (137 N·m) @ 5500 rpm
+ Valvetrain : DOHC
+ Piston Code 1986-87 : PG6
+ Piston Code 1988-89 : P29 (PM7 is ZC equivalent/same piston)
D16A3
* Found in:
o 1986-89 Acura Integra (Australia)
+ Displacement : 1590 cm³
+ Power : 118 hp (88 kW) @ 5600 rpm & 103 ft·lbf (140 N·m) @ 4800 rpm
+ Valvetrain : DOHC
D16A6
Also known as D16Z2.
* Found in:
o 1988-1991 Honda Civic Si, CRX Si, Civic Wagon RT4WD
o 1990-1991 Honda Civic EX Sedan
o 1988-1995 Honda Civic Shuttle RT4WD (UK/Europe/Asia/AU/NZ)
o 1989-1996 Rover 216/416 GSi (UK/Europe)
+ Power : 115 hp (86 kW) @ 5600 rpm & 100 ft·lbf (140 N·m) @ 3,800 rpm, redline 7200 rpm (USA)
# Note: 1988 engines were 105 hp (78 kW)
+ Valvetrain : SOHC
+ Fuel Control : OBD-0 four-point PGM-FI
+ Head Code : PM3
+ ECU Code : PM6
D16A7
Basically a D16A6 that came without a catalytic converter, like the European version of the D16A6.ex US 4 Door
* Found in:
o 88-89 Civic models in Europe(ED4,ED7)
o 88-95 Models in South Africa
o Ballade SH4 and SR4 ( D16A7 / EE4 )
+ Power : 115 hp (86 kW) @ 5900 rpm & 100 ft·lbf (140 N·m) @ 4800 rpm
+ Valvetrain : SOHC
+ Fuel Control : OBD-0 Multi-point PGM-FI
D16A8
* Found in:
o 1988-1995 Civic/CRX/Concerto (UK/Europe/Australia)
o 1990-1995 Rover 216/416 GTi(UK/Europe)
o 1990-1995 Rover 216 Coupe (Europe)
+ Power : 122 hp (91 kW) @ 6800 rpm & 108 ft·lbf (146 N·m) @ 5900 rpm
+ Valvetrain : DOHC
+ ECU Code: PP5
D16A9
(Same as D16A8 but without a catalytic converter)
* Found in:
o 1988-1991 Concerto (UK/Europe)
o 1988-1991 CRX 1.6i-16(UK/Europe/South Africa)
o 1988-1991 Civic 1.6i-16(UK/Europe/South Africa)
o 1989-1996 Rover 216/416 GTi (UK/Europe)
o 1992-1995 Civic Si (Peruvian version)
+ Power : 130 hp (97 kW) @ 6.800 rpm & 108 ft·lbf (146 N·m) @ 5.900 rpm
+ Valvetrain : DOHC 16v
+ Redline: 7.200 rpm
+ Limit: 7.500 rpm
+ Fuel Control : OBD-0 MPFI (92-95 OBD-1)
+ ECU Code: PM7 (92-95 P29)
+ GearBox : L3 Cable type (92- 95 S20)
D16B5
(Identical to the D16Y5. Main differences are Pistons, Rods, Camshaft, Head Gasket, Intake Manifold, and Exhaust Manifold are PDN rather than P2M)
* Found in:
o 1998-2000 Honda Civic GX
+ Compression : 12.5:1
+ Combustion Chamber Volume : 32.8 cc per cylinder
+ ECU Code: PDN-A02
D16W7
* Vtec-E
* Found in:
o 2005-2007 Honda Civic Vti-L/ Vti (Asia)
+ Displacement:1590 cm3
+ Compression : 10.9:1
+ Power : 115hp 5600 rpm & 152Nm 4300rpm
+ Valvetrain : SOHC
+ Redline 6100 rpm
+ Limit 6200 rpm
+ ECU Code: PM12
* Also found in 2001-2005 Honda Civic (Europe)
o Same as above, except:
o Power: 110hp (81kW) @ 5600 rpm & 152 Nm @ 4300 rpm
o Redline 6100 rpm
o Limit 6200 rpm
D16Y3
* Found in:
o 1995-1997 Honda Civic MB1 LS (UK/Europe)
+ Power :83 kW /115 HP @ 6800 rpm, redline 7000 rpm
+ Valvetrain : SOHC,16 valves
D16Y4
* Found in:
o 1996-2000 EK1 Civic CXi,GL,GLi (Australia)
o 1998 EK4 Civic ES (Turkey)
+ Displacement: 1590
+ Power: 83Kw (115hp)
+ Vavletrain: SOHC
D16Y5
* VTEC-E
* Found in:
o 1996-2000 Honda Civic HX
o 1996 Honda Civic EX(sedan Peruvian version)
+ Compression : 9.4:1
+ Power : 115 hp (86 kW)@ 5600 rpm & 104 ft·lbf (141 N·m) @ 4500 rpm
+ Head Code : P2J
o 1996-2000 VTi (Phils. & NZ)
+ Compression :
+ Power : 127 hp (95 kW)@ 5800 rpm
+ Head Code : P2J
+ ECU Code : P2M
+ Piston Code : P2MY
D16Y7
* Found in:
o 1996-2000 Honda Civic DX/VP/LX/CX hatchback
o 1999-2000 Honda Civic Special Edition - SE(Canada)
o 1996-97 Honda del Sol S
+ Displacement : 1593 cm³
+ Power : 106 hp (79 kW) @ 6400 rpm
+ Torque (lb·ft@rpm): 103 @ 4,600 rpm
+ RPM Redline : 6800 rpm 7200 gov. kicks in
+ Valvetrain : SOHC 16 valves
+ Head Code : P2F
+ Piston Code : P2E
+ ECU Code : P2E
D16Y8
VTEC
Also available in New Zealand under the code D16Y6
* Found in
o 1999-2000 Honda Civic SE 1.6 Vtec (UK)
o 1997-1998 Honda Civic EX Sedan
o 1996-1998 Honda Civic EX Coupe
o 1996-2000 Honda Civic EX (US)
o 1996-2000 Honda Civic SI (Canada Only)
o 1997-2000 Acura 1.6EL (Canada Only)
o 1996-1997 Honda del Sol Si
+ D16Y8 1.6 16V SOHC VTEC PGM-FI 1590
+ 127 hp@6600 rpm 108tq@5500 rpm
+ Head Code : P2J
+ Piston Code : P2P
+ Redline 6900 rpm
+ ECU Code : P2P
D16Y9
non vtec
* Found in:
o 1996-2000 Honda Ballade,Venezuela and Civic in South Africa
+ Power, Torque : {{Auto hp106 / 89kw} @ 5900 rpm 146nM @ 4000 rpm
+ Valvetrain : SOHC, 4 valves per cylinder non - VTEC
+ Fuel Control : OBD2A MPFI
D16Z5
(Basically the same engine as the D16A9, but now with a catalytic converter and lambda sensor)
* Found in:
o 1988-1992 Honda CRX (European Market)
+ Power : 124 hp (92 kW) @ 6800 rpm
+ Valvetrain : DOHC
+ Cam Gear : 34 tooth
+ Fuel Control : OBD-0 PGM-FI
+ Head Code : P7
+ Piston Code : PM7
+ ECU Code: PM7
D16Z6
* Found in
o 1991-1992 Honda civic si
o 1992-1995 Honda Civic EX, EX-V and SI
o 1992-1995 Honda Civic ESi (European Market)
o 1993-1995 Honda Del Sol Si (US)
o 1993-1995 Honda Del Sol ESi (European)
+ Power : 125 hp (93 kW) @ 6600 rpm & 106 ft·lbf (144 N·m) @ 5200 rpm
+ Redline : 7300 rpm
+ Head Code : P08
+ ECU Code : P28
D16Z9
* Found in:
o 1994-1995 Civic Coupe (EJ1) 1.6i Esi European
+ Fuel Cut : 7500 rpm
+ ECU Code : P28
D17 Series Engines (1.7 Liters)
D17A 2001-2005 (Japan) honda civic Displacement : 1668 cm³ bore and stroke n/a valve ttain : Sohc Vtec power: 115hp,lean burn,130 hp please find more info, there is also a D15B Vtec from this family with coils
D17A1
* Found in:
o 2001-2005 Honda Civic DX/LX/VP
+ Displacement : 1668 cm³
+ Bore and Stroke : 75 mm X 94.4 mm
+ Power : 115 hp (86 kW) @ 6100 rpm & 110 ft·lbf (150 N·m) @ 4500 rpm
+ Valvetrain : SOHC
D17A2
* SOHC VTEC-E
* Found in:
o 2001-2005 Honda Civic EX
o 2001-2005 Honda Civic LX (Europe)
o 2001-2005 Honda Civic Si (Canada only)
o 2001-2005 Acura 1.7 EL (Canada only)
+ Bore and Stroke : 74.98 mm X 94.4 mm
+ Power : 127 hp (95 kW) @ 5800 rpm & 114 ft·lbf (155 N·m) @ 4800 rpm
+ Valvetrain : SOHC VTEC-E (Single Cam)
D17A5
* SOHC VTEC
* Found in :
o 2000-2005 HONDA CIVIC & CIVIC FERIO (JAPAN)
o 2004-2005 HONDA CIVIC VTi & VTi-S (INDONESIA), EX (Brazil)
o 2004-2005 HONDA STREAM (INDONESIA)
+ DISPLACEMENT : 1668 cm³
+ BORE N STROKE : 74.98 mm X 94.4 mm
+ COMPRESSION RATIO : 9.5:1
+ POWER : 0 hp (0 kW) @6500 rpm & 0 NM @ 4500 rpm
D17A6
* VTEC-E
* Found in:
o 2001-2005 Honda Civic HX
+ Power : 125 hp (93 kW) @ 5800 rpm & 111 ft·lbf (150 N·m) @ 3800 rpm
+ Valvetrain : SOHC VTEC-Ec
D17A7
* Found in:
o 2001-2005 Honda Civic GX
o Uses CNG (Compressed Natural Gas)
+ Power : 100 @ 6100 rpm & 98 ft·lbf (133 N·m) @ 4000 rpm
+ Valvetrain : SOHC
ZC(similar to D15Z4, D16Z6, D16A1, D16A3, D16A6, D16A8, D16A9 and D16Z5 engines)
A few D-series variants are labelled "ZC" (usually JDM), but they are not truly a different series.
There are both SOHC and DOHC ZC engines.
The non-VTEC SOHC ZC is similar to the D15Z4 and D16A6 engine, but with more aggressive cam timing.
The VTEC SOHC ZC is identical to the D16Z6, and the DOHC ZC is similar to the D16A1, D16A3, D16A8, D16A9 and D16Z5 engines.
DOHC ZC
*Found in 1988-91 (JDM) Crx si
* Displacement : 1590 cm³
* Bore and Stroke : 75 mm X 90 mm
* 1986-1987 Compression : 9.3:1 1988-1989 Compression : 9.5: 1
* 1986-1987 Power : 113 hp (84 kW) @ 6250 rpm Torque : 99 ft·lbf (134 N·m) @ 5500rpm (US)
* 1988-1989 Power : 118 hp (88 kW) @ 6250 rpm Torque: 101 ft·lbf (137 N·m) @ 5500rpm (US)
* 1988-1991 Power : 130 bhp (97 kW) @ 6800 rpm Torque : 106 @ 5700 (JDM)
* Valvetrain : DOHC
* Piston Code 1986-87 : PG6
* Piston Code 1988-89 : PM7
* Fuel Control : OBD-0 MPFI
Euro Mk1 (85-87) 1.6 CRX's are fitted with an engine designated "ZC1" which is a higher spec 130 bhp (97 kW) version of the D16a1. Which were later to be switched out with the D16A8 or B16A depending on which model.
o 1st Gen ZC
Identified by: External coil, small dizzy, dual butterfly TB, cam cover bolts on top, brown/gold cam cover. Large cam pullys. +3cc PG6B pistons, non-pent roof combustion chamber. As a ZC it appeared in JDM AV integra Si and JDM E-AT civic/crx Si. Commonly produced at the time but now over 20 years old and getting harder to find. D-series version D16a1 86-87
o 2nd Gen ZC (rarest)
Identified by: Internal coil, large dizzy, single butterfly TB mounted on slight angle forward, bolts on top of cam cover, black cam cover, large cam pullies. +7cc PM7 pistons, 43cc Pent roof combustion chamber. As a ZC appeared in JDM facelift AV bodied integra Si did not appear in civic or CRX, rarest ZC only produced for less than one year. D-series version D16a1 88 - 89 (sometimes +7cc P29 pistons)
o 3rd Gen ZC
Identified by: Internal coil, large dizzy, single butterfly TB. Black cam cover. Cam cover bolts on the sides. Small cam pullies. Inlet Manifold stamped PM7. +7cc PM7 pistons, 43cc Pent roof combustion chamber. As a ZC appeared in JDM EF3 civic and EF7 crx, did not appear in an integra body. Most commonly produced ZC, manufactured in Japan from end of 87 through to early '91 D-series version D16a8/9 (euro civic Si) (sometimes +7cc P29 pistons
o 4th Gen ZC
Identified by: Internal coil. OBD1 efi system (grey plug). No cam angle sensor on exhaust cam, now located in Dizzy. Rubber plug where cam angle sensor would mount. Black cam cover. No PGM-EFi plate on the inlet manifold, replaced with three ribs instead. P29 stamped on inlet manifold. MAP sensor on TB. +7cc PM7 pistons, pent roof combustion chamber. As a ZC only appeared in EG5 civic bodies, no integra or CRX received this engine. Reasonably common produced from 92 to 94. (20th Anniversary edition & Japanese car of the year) D-series version D16a8/9 (Euro & Australia civic Si & NZ civic Gti) (sometimes +7cc P29 pistons)
Modified by guysensei at 11:23 PM 10/14/2008
Modified by guysensei at 11:25 PM 10/14/2008
Modified by guysensei at 11:27 PM 10/14/2008
guysensei is offline
Old 10-15-2008, 09:07 AM
DCFerris's Avatar
Thank God maybe we will see a decrease in whats the diff between this d and that d post your a good good person guysensei
DCFerris is offline
Old 10-15-2008, 09:14 AM
SovXietday's Avatar
Default Re: (DCFerris)
So um... bookmarked because there is awesome info in here.
SovXietday is offline
Old 02-23-2009, 12:13 PM
CivicF4Ihead19's Avatar
Default Re: Honda D series engine
Answered one of my questions... thanks
CivicF4Ihead19 is offline
Old 02-23-2009, 05:25 PM
Marcos Barrios's Avatar
this really helped me out with some questions I had
thanks dude
Marcos Barrios is offline
Old 02-23-2009, 06:38 PM
D16SiHatch's Avatar
really? there are that many people who couldn't find this info on their own?
D16SiHatch is offline
Old 08-02-2009, 11:43 AM
2k1customcivic's Avatar
good post. will help alot of d series users
2k1customcivic is offline
Old 08-02-2009, 12:26 PM
Vietnamese!
ALLxMOTOR EG's Avatar
ALLxMOTOR EG is offline
Old 08-02-2009, 12:27 PM
its crazy to see how little power some of the older honda motors have
Old 08-03-2009, 01:29 AM
killercrx91's Avatar
Well I know that the D-series don't make that much HP. But I still love them. D16A6 LOVE that engine
killercrx91 is offline
Old 08-03-2009, 03:08 AM
sw96's Avatar
Nice. Now to identify which ZC is in my EF. All I can remember right off is that the block is stamped ZC.
sw96 is offline
Old 08-03-2009, 05:30 AM
Reject Papi
jhammond_82's Avatar
man, i've used wikipedia for all kinds of ****. that info is out there, if you search. omg, this thread is a year old at that. lmao.
jhammond_82 is offline
Old 08-03-2009, 05:55 AM
EFB055
~sp33~'s Avatar
Just remember that the information posted on Wikipedia isn't alway correct. There are a bunch of errors in what's been copied. Though as a general guide it suites pretty well.
For real.
EDIT: I just went to Wikipedia to fix some of the information, but it appears it's already been mended.
Then i notice this thread is from last year. Figures.
~sp33~ is offline
Old 08-03-2009, 06:44 AM
low&slow's Avatar
d16z6 chea chea
low&slow is offline
Old 08-03-2009, 08:20 AM
Slomo_civic's Avatar
i never tried to look up this info but i didnt know there were so many D varitations. nice work!
Slomo_civic is offline
Old 08-15-2009, 02:30 AM
z5mova's Avatar
i hav a d16a8 does that mean if i drill the guts out of the cat converter id get that few exra kw lol?
z5mova is offline
Old 08-15-2009, 02:37 AM
EFB055
~sp33~'s Avatar
AFAIK the only difference between the d16a8 and the d16a9 is that the latter has no cat.
I've removed the cat on my D16a8, and i didn't notice any HP difference.
~sp33~ is offline
Old 09-09-2009, 07:12 AM
psjones13's Avatar
Has anyone on here mated a D15b2 block with a D15z6 head for the VTEC, and Multi point injection, and higher comp. levels? I'm thinking about doing this to my D15b2 But I noticed the rods are longer in z6 so i was wondering if that causes any problems? Any info will help, thanks!
psjones13 is offline
Old 09-09-2009, 07:15 AM
psjones13's Avatar
The D16a9 has a different ECU code. Maybe you need to change yours to get the mope hp?
Old 09-09-2009, 08:25 AM
WTeFdriver's Avatar
finally some good zc info!!
WTeFdriver is offline
Old 09-09-2009, 02:05 PM
Tyson's Avatar
This part on ZC's can be summed up better.
"ZC means 1.6L D series, regardless of VTEC, number of cams or intake (eg. carburated or MPFI)."
To say the non-VTEC SOHC ZC is similar to the D15Z4 is wrong, since it is not a 1.6L engine. It is pretty much identical to the D16A6, but while cams are slightly different, its not accurate to say its more aggressive cam timing. The carburated SOHC cam is has a bit different timing and the MPFI cam has a very slightly higher intake lobe, thats really it. not much of a difference to speak of really.
i realize this information was simply copy and pasted from an inaccurate wikipedia article over a year ago. but i see it bumped and ppl should know whats wrong. from what i remember, there are some other minor details that are wrong, but with this much info and numbers, its typical.
just dont blindly follow all this information posted above.
Tyson is offline
Old 09-09-2009, 05:03 PM
EFB055
~sp33~'s Avatar
I think that information is incorrect, my ECU is a PM7.
~sp33~ is offline
Old 09-09-2009, 09:36 PM
psjones13's Avatar
Oh ok, must be one of those wikipedia mess ups again
Old 09-10-2009, 09:30 AM
kowcain's Avatar
lol along with the d16z6 being in a 91 civic lol.
nice copy and pasting there lol.
and we all can agree on one thing.. if you wanna know about a d-series engine go to the pros
d-series.org
/thread.
kowcain is offline
Old 10-07-2009, 09:15 PM
98hx/ex's Avatar
i am a total noob.. and i know a lil bit.. but i need help and i tried d-series but they have me many mixed results and i tried the cylinder head code forum no luck..
so i have a 98 honda civic hx and the cylinder head code is p2j-3. and it had an EX transmission. i want to know if this is an ex head (mini-swap preformed on it) or just a normal vtec-e head. plz help.
oh and i found another 98 hx and the head code was p2j-2 so it gave me some hope that i have more than 115 hp.
98hx/ex is offline
Quick Reply: Honda D series engine
