| Welcome to Honda-Tech! | ||
#1 |
| Garage is empty, add now |
Title says it all... I searched, but I could only find info about 5th gen Si's with ABS... does the 95 coupe have it or not?
I ordered some new hawk pads from tire rack, but I believe I ordered the wrong ones... doh.
Can you feel the pulse? Can you feel the heat rising from below? Can you feel the energy gaining strength, oh so slowly? Can you see the signs? Can you see the changing of the winds? Can you see the stillness in the air? Calm will remain...oh so shortly. |
#2 |
Here is how you check for ABS
1. Get in your car 2. Start car and proceed to the nearest long, straight stretch of road. 3. Get up to about 40 or so MPH. 4. SLAM on the brakes as hard as you can. If they lock up... chances are you dont have ABS Or if this way seems too "extreme" for your tastes.. simply open up your fuse box and check to see if you have a ABS fuse inside!!
[B]2002 Blue WRX[/B] Perrin Air Filter |
#3 |
some of them did some did not . If you have four rotors than you do have ABS (except for the si's 99-00
) If you have two rotors and two drums you don't have ABS. I think it may have been a special order but not sure.
-John 1999 FBP Civic SI - Sold, 2004 SSM S2000 - Sold, 2008 OB Evolution X GSR - Sold, 2010 DB Civic SI 4DR - Sold, 2011 AS Fit |
#4 |
stuckatworksi is corect. You can also check for orange wire harness plugs. They used orange for ABS.
Pictures of my EH2: [url="http://www.honda-tech.com/zeropost?cmd=tshow&id=792249"]http://www.honda-tech.com/zero...92249[/url] funny **** [url="http://www.y2khai.com"]http://www.y2khai.com[/url]/ |
#5 |
it is an option for the 92-95 civics. not standard.
look under your hood, on the same side as the battery look for the big fuse box, (right below the bat.) follow the fender down there is 1 more fuse box below the strut tower, if there is one there. it has abs. |
#6 |
some did, some dont.
https://www.facebook.com/pages/Donke...40110546142063 |
| Tags |
| 2000, 95, abs, anti, antilock, brakes, checking, civic, coupe, del, dx, ej1, honda, lock, make, sols |
